Text Editor for Harbour
MigSoft
DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
Post by MigSoft »
A good alternative to edit your code.
Re: Text Editor for Harbour
Thank you for referring.
http://www.uvviewsoft.com/synwrite/
This is the link for this writer.
Please let me know how to configure for Harbour syntax highlighting. Now officially we are recommending Notepad++. What are all the advantages of this writer over notepad++?
Rathinagiri wrote:Thank you for referring.
MigSoft
Post by MigSoft »
Hello Rathinagiri,
Attachment syntax Harbour, we must go to Options / Customize Lexer... / Import / Apply
More information about SynWrite in http://www.thewindowsclub.com/synwrite- ... ource-code
Harbour and GUI.zip
(6.61 KiB) Downloaded 864 times
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
Thanks,
this is a very interesting solution
jayadevu
Post by jayadevu »
Hi Migsoft,
Excellent. Have you configured SynWrite to compile programs also ?, If so, how.
Warm regards,
Jayadev
Really good tool, thanks to notify and "lexer" file, Miguel :arrow:
jayadevu wrote:... Have you configured SynWrite to compile programs also ?, If so, how.
There is a topic namely "How to make an IDE for your own language?" under "Miscellaneous" section of Help.
Maybe useful, not tried yet by me :(
Regards.
dhaine_adp
Post by dhaine_adp »
MigSoft wrote:Hi,
Hi MigSoft,
Thanks for sharing the the link about SynWrite. For me, here's what I'm looking for a code editor:
1. Ability to use code folding.
2. Column mode editing
3. Tabs as space (because it allows me to used other editors preserving the alignment)
4. Syntax highlighting.
5. Support for Ansi and Unicode.
6. Ability to Search and Replace whole or selection (block)
In the old days I used ne.com (Norton Editor) because of its simplicity. Then I moved to CodeWright and finally with Crimson Editor (though it do not support code folding). Maybe I should try SynWrite. :)
Thanks,
Danny
Manila, Philippines
Danny,
I have verified. SynWrite has all the above features.
I'm using notepad++. It has everything I need, but I'll try it after my holidays.
Thanks for info!
