HMG 3.4.1
tonton2
Re: HMG 3.4.1
Post by tonton2 »
bonsoir tout le monde
attention il faut reconfigurer le fichier IDE (parametres de configuration )de l'IDE ,car il ouvre le fichier du hmg 3.40
Merci de votre partage et bonne suite à tous
Attention must reconfigure the Hmg IDE (configuration settings )file, because it opens the file hmg 3.4.0 instead of 3.4.1
Best regards
L'Algerie vous salut
Y.TABET
Re: HMG 3.4.1
I'm creating a basic NETIO server with 3.4.1 and I've got an error:
Error BASE/1132 Bound error: array access
Called from EVENTPROCESSHMGWINDOWSMESSAGE(6782)
Called from INIT(838)
Called from ERRORSYS(59)
Called from __HBVMINIT(0)
The code that generates the runtime error is the following:
nPort:= 50000
cIfAddr:= '0.0.0.0'
cRootDir:= '.'
lRPC:= .T.
cPasswd:= 'secret'
nCompressionLevel:= 9
nStrategy:= NIL
	pSockSrv := NETIO_MTSERVER( nPort , cIfAddr , cRootDir , lRPC , cPasswd , nCompressionLevel , nStrategy )
	if empty( pSockSrv )
		MSGSTOP("Can't Start Server!")
Build: 32 Bits
OS: XP SP3 32 Bits
Configuration: -mt (multi-threaded)
netio.7z
(1.76 KiB) Downloaded 341 times
Re: HMG 3.4.1
tonton2 wrote:Attention must reconfigure the Hmg IDE (configuration settings )file, because it opens the file hmg 3.4.0 instead of 3.4.1
Thank you for advising.
Will need to re-edit C:\hmg.3.4.1\IDE\hmg.ini file (you can use Notepad++) to set right hmgpath.
Also you would check C:\hmg.3.4.1\IDE\editor.ini file. I do not know if mine was the only wrong path of Notepad++ or came wrongly setted.
Re: HMG 3.4.1
Roberto Lopez wrote: Error BASE/1132 Bound error: array access
Este error en tiempo de ejecucion, parece que empezó a ocurrir desde la version hmg.3.3.1.
Hé testeado con versiones anteriores.
El accionar del EventProcessHMGWindowsMessage en el Init.prg empezó justamente apartir de hmg.3.3.1.
Espero que la información sirva para resolver el problema.
Slds
Re: HMG 3.4.1
Roberto Lopez wrote:Hi All,
nPort:= 50000
cIfAddr:= '0.0.0.0'
cRootDir:= '.'
lRPC:= .T.
cPasswd:= 'secret'
nStrategy:= NIL
Build: 32 Bits
OS: XP SP3 32 Bits
Thanks Roberto for report.
I fixed, please unzip this file in folder c:\hmg.3.4.1\SOURCE and re-build the lib.
h_Event.rar
(43.29 KiB) Downloaded 405 times
Re: HMG 3.4.1
netio err.png (24.36 KiB) Viewed 5563 times
Dear Dr. Claudio Soto, Roberto Lopez
After apply of above patch, Server compilation Ok, but run time error
Re: HMG 3.4.1
Hi Dave,
Certainly you doing something wrong or missing something.
I've applied the recently patch given by Claudio replaced files at source folder and re-builded libs and all working properly.
Except second button to stop server due missing variable.
Re: HMG 3.4.1
srvet_claudio wrote: Thanks Roberto for report.
Thanks Claudio!
I'll try it and report back.
Re: HMG 3.4.1
It works perfect. Thanks Again!
Re: HMG 3.4.1
Pablo César wrote:Hi Dave,
You are correct dear, sorry for disturb
When I run Buildalllib I am facing error as per attachment
My system is WinXp Sp3
err.rar
(2 KiB) Downloaded 329 times
