Teaching someone else is not always an easy thing to do.
My problem is that if I create window 1 with a few buttons on it then all is ok.
I then create window 2 and add a few more buttons. No problem.
With both windows in view how do I stop the user from pressing buttons in the first window accepting that I want it to remain on display but in an inactive state.
I have written a little routine to disable the buttons in window 1 and it works ok but is there and existing command that does the same in a more professional way.
freeze a window
- mustafa
Re: freeze a window
Hola amigo sunningdale:
Mirate en este sample que te puede
interesar mediante las PROCEDURE Anular()
Form_1.Buton_1.Enabled := .T.
Form_1.Buton_2.Enabled := .T.
y PROCEDURE Activar()
Form_1.Buton_1.Enabled := .F.
Form_1.Buton_2.Enabled := .F.
Anulas o Activas los Botones
Un Saludo
Hello sunningdale friend:
Look in this sample you can
PROCEDURE interest using the Anular() <-- Cancel
Form_1.Buton_1.Enabled: = .T.
Form_1.Buton_2.Enabled: = .T.
and PROCEDURE Activar() <--On
Form_1.Buton_1.Enabled: = .F.
Form_1.Buton_2.Enabled: = .F.
Nullify or Active Buttons
a Greeting
Un Saludo
a Greeting
- main.zip
- (699 Bytes) Downloaded 340 times
- esgici
Re: freeze a window
Hisunningdale wrote:Teaching someone else is not always an easy thing to do.
Did you tried define MODAL type the second window ?
Happy HMG'ing
Viva INTERNATIONAL HMG
sunningdale
Re: freeze a window
Many thanks to Mustafa and Esgici. You both helped a lot it now works perfectly.
- esgici
Re: freeze a window
You are welcome friendsunningdale wrote:Many thanks to Mustafa and Esgici. You both helped a lot it now works perfectly.
Happy HMG'ing
