"OnKey Event" SAME AS "OnDblClick Event"
Pudiera ser que el evento ON KEY dentro del Control GRID, tuviera disponibles los DATA, funcionando como el evento OnDblClick ?
It may be that the ON KEY event within the GRID control, have available the DATA, functioning as the OnDblClick event?
Event OnDblClick Occurs when the user double clicks on the control
Syntax:
OnDblClick <ActionProcedure>
The following data are available at ‘OnDblClick’ procedure:
- This.CellRowIndex
- This.CellColIndex
- This.CellRow
- This.CellCol
- This.CellWidth
- This.CellHeight
Re: "OnKey Event" SAME AS "OnDblClick Event"
Not only for Grid, it is now possible to do onkey event on any control!
Syntax:
CREATE EVENT PROCNAME cProcName [ HWND hWnd ] [ MSG nMsg ] [ STOREINDEX nIndex ]
For example, I have enabled anywhere searching in ComboBox with the following code:
See this:
Create Event ProcName _ComboBoxAnywhereSearch( 'accounts', 'txn' ) HWND GetControlHandle ( 'accounts', 'txn' )
TXN is form name and accounts is combobox name.
function _ComboBoxAnywhereSearchInit( lShowLabel )
   if .not. __mvexist( '_cComboSearchString' )
      public _cComboSearchString := ''
   if lShowLabel
      if .not. iscontroldefined( _combolabel, &( thiswindow.name ) )
         define label _combolabel
            parent &(thiswindow.name)
            row this.row - 30
            col this.col
            width this.width
            backcolor { 0, 0, 255 }
            fontcolor { 255, 255, 255 }
            fontname this.fontname
            fontsize 14
            fontbold .t.
            autosize .t.
         end label
   return nil
function _ComboBoxAnywhereSearchClose( )
   if __mvexist( '_cComboSearchString' )
   if iscontroldefined( _combolabel, &(thiswindow.name))
      domethod( thiswindow.name, '_combolabel', 'RELEASE' )
   return nil
function _ComboBoxAnywhereSearch( cComboName, cWindowName )
   local lFound := .f.
   local nEventMsg := EventMsg()
   local ch
   local nVKDown := HMG_GetLastVirtualKeyDown()
   ch := HMG_GetLastCharacter()
   HMG_CleanLastCharacter( .t. )
   do case
   case nVKDown == VK_BACK   //   backspace
      HMG_CleanLastVirtualKeyDown()
      _cComboSearchString := HB_ULEFT( _cComboSearchString, max( 0, ( HMG_Len( _cComboSearchString ) - 1 ) ) )
      _ComboBoxAnywhereSearchUpdate( cWindowName )
   case nVKDown == VK_UP .or. nVKDown ==  VK_DOWN
      if hmg_len( _cComboSearchString ) == 0
         return nil
         nLineNo := getproperty( cWindowName, cComboName, 'VALUE' )
         if nVKDown == VK_UP
            lFound := .f.
            for i := nLineNo - 1 to 1 step - 1
               // first check in the starting chars...
               if  hmg_upper( _cComboSearchString ) == hb_uleft( hmg_upper( getproperty( cWindowName, cComboName, 'ITEM', i ) ), hmg_len( _cComboSearchString ) )
                  lFound := .t.
                  setproperty( cWindowName, cComboName, 'VALUE', i )
                  exit
            next i
            if .not. lFound // anywhere searching...
                  if  HB_UAT( hmg_upper( _cComboSearchString ), hmg_upper( getproperty( cWindowName, cComboName, 'ITEM', i ) )  ) > 0
                     lFound := .t.
                     exit
               next i
            if .not. lFound
               playbeep()
         else // down key search for next
            lFound := .f.
            for i := nLineNo + 1 to getproperty( cWindowName, cComboName, 'ITEMCOUNT' )
                  lFound := .t.
                  exit
            next i
                     lFound := .t.
                     exit
               next i
            if .not. lFound
               playbeep()
         return 1
   case nVKDown == VK_ESCAPE
      return 1
   case nVKDown ==  VK_RIGHT .or. nVKDown ==  VK_LEFT .or. nVKDown ==  VK_HOME .or. nVKDown ==  VK_END
      return nil
   case EventIsMouseMessage ()
//      _cComboSearchString := ''
      return nil
   otherwise
      IF nEventMsg <> WM_CHAR
         Return Nil   // enable processing the current message
      _cComboSearchString := _cComboSearchString + ch
   endcase
   lFound := .f.
   for i := 1 to getproperty( cWindowName, cComboName, 'ITEMCOUNT' )
         lFound := .t.
         exit
   next i
            lFound := .t.
            exit
      next i
   if .not. lFound
      playbeep()
   return 1
function _ComboBoxAnywhereSearchUpdate( cWindowName )
   if iscontroldefined( _combolabel, &cWindowName )
      setproperty( cWindowName, '_combolabel', 'VALUE', _cComboSearchString )
return nil
Gracias Rathinagiri, lo voy a probar...
Rathinagiri thanks, I'll try ...
Hola Andrés,
Después de haber verificado tu cuestionamiento sobre ONKEY en Grids en hmgdoc, abri una nueva página que faltaba en Events y este es específico para Grids. Fijate si esto te ayuda:
A respecto de las funciones HMG_GetLastVirtualKeyDown() y HMG_CleanLastVirtualKeyDown(), poderás encontrar en: Advanced / Read Keyboard and Mouse
Gracias a la participación de los usuários, podemos mejorar la documentacion para ser más clara y precisa.
Un abrazo,
Hola Pablo Cesar
Si, es lo que encontré y añadí al post que envié. viewtopic.php?f=20&t=4103&p=41661#p41661
Gracias
Hola Rathinagiri
Tratando de entender tu ejemplo con el "Create Event", hice lo siguiente: (pero no se si así es como deba funcionar)
* Siempre encuentra el primer registro "fer" pero existen 2
* Puse "ON INIT _ComboBoxAnywhereSearchInit( .f. )" para hacer la llamada a esta función // Pero da ERROR si pongo .T.
* Si pongo la propiedad SORT, me da ERROR
* En que momento se hace la llamada a la "funcion _ComboBoxAnywhereSearchClose( )"
Hello Rathinagiri
Trying to understand your example with the "Create Event", I did the following: (but not if this is how it should work)
* Always find the first record "fer" but there are two
* Put "ON INIT _ComboBoxAnywhereSearchInit (.f.)" To make the call to this function // But fails if I put .T.
* If you get the property SORT gives me ERROR
* At what point it is the call to "_ComboBoxAnywhereSearchClose() function"
PROCEDURE Main()
	PUBLIC aRows [21], _cComboSearchString := ''		//	ERROR if it is not defined
	aRows [1]    := "Simpson	 Homer  	555-5555"
	aRows [2]    := "Mulder 	 Fox		324-6432"
	aRows [3]    := "Smart		 Max		432-5892"
	aRows [4]    := "Grillo		 Pepe		894-2332"
	aRows [5]    := "Kirk		 James		346-9873"
	aRows [6]    := "Barriga	 Carlos		394-9654"
	aRows [7]    := "Flanders	 Ned		435-3211"
	aRows [8]    := "Smith		 John		123-1234"
	aRows [9]    := "Pedemonti	 Flavio		000-0000"
	aRows [10]   := "Gomez		 Juan		583-4832"
	aRows [11]   := "Fernandez	 Raul		321-4332"
	aRows [12]   := "Borges		 Javier		326-9430"
	aRows [13]   := "Alvarez	 Alberto	543-7898"
	aRows [14]   := "Gonzalez	 Ambo		437-8473"
	aRows [15]   := "Batistuta	 Gol		485-2843"
	aRows [16]   := "Vinazzi	 Amigo		394-5983"
	aRows [17]   := "Pedemonti	 Flavio		534-7984"
	aRows [18]   := "Samarbide	 Armando	854-7873"
	aRows [19]   := "Pradon		 Alejandra	???-????"
	aRows [20]   := "Reyes		 Monica		432-5836"
	aRows [21]   := "Fernández	 two		000-0000"
	DEFINE WINDOW txn AT 0,0 WIDTH 640 HEIGHT 480 TITLE 'CREATE EVENT TEST' MAIN ON INIT _ComboBoxAnywhereSearchInit( .f. )		// if .t.  ERROR
		@ 010, 010  COMBOBOX accounts ITEMS aRows VALUE 1 WIDTH 300 HEIGHT 200 FONT "Verdana" SIZE 12 TOOLTIP "cToolTipText" DROPPEDWIDTH 350 DISPLAYEDIT	//  SORT  <=== ERROR
            *[ ON GOTFOCUS <OnGotFocusProcedur> | <bBlock> ]
            *[ ON CHANGE <OnChangeProcedure> | <bBlock> ]
            *[ ON LOSTFOCUS <OnLostFocusProcedure> | <bBlock> ]
            *[ ON ENTER <OnEnterProcedure> | <bBlock> ]
            *[ ON DISPLAYCHANGE <OnDisplayChangeProcedure> | <bBlock> ]
            *[ ON DROPDOWN <OnDropDownProcedure> | <bBlock> ]
            *[ ON CLOSEUP <OnCloseUpProcedure> | <bBlock> ]
            *[ IMAGE <acImageNames> ]
            *[ ON CANCEL <OnCancelProcedure> | <bBlock>  ]
            *[ NOTRANSPARENT ]
	TXN.CENTER
	TXN.ACTIVATE
RETURN nil
FUNCTION _ComboBoxAnywhereSearchInit( lShowLabel )
	if lShowLabel
				row this.row - 30
				col this.col
				width this.width
				fontname this.fontname				// 	ERROR	when lShowLabel = .t.
				fontsize 14
				fontbold .t.
				autosize .t.
			end label
RETURN nil
FUNCTION _ComboBoxAnywhereSearchClose( )			//  when it called ?
RETURN nil
FUNCTION _ComboBoxAnywhereSearch( cComboName, cWindowName )
	local lFound := .f.
	local ch
	do case
				return nil
				if nVKDown == VK_UP
					lFound := .f.
							lFound := .t.
							exit
					next i
								lFound := .t.
								exit
						next i
					if .not. lFound
						playbeep()
					lFound := .f.
							lFound := .t.
							exit
					next i
								lFound := .t.
								exit
						next i
					if .not. lFound
						playbeep()
				return 1
			return 1
			return nil
			return nil
	otherwise
	endcase
	lFound := .f.
			lFound := .t.
			exit
	next i
				lFound := .t.
				exit
		next i
	if .not. lFound
		playbeep()
RETURN 1
FUNCTION _ComboBoxAnywhereSearchUpdate( cWindowName )
RETURN nil
