I'm trying to make a tool that we facilitate programming now trying to present what will be on the screen
The question is why a program error occurs on line 69?
Green fields are label and there need display L_Name
Orange fields are fields and there need display F_Name
whats wrong in program?
- dragancesu
- wrong.zip
- (1.37 KiB) Downloaded 486 times
Re: whats wrong in program?
Hi Dragan,
Try
Hope that helps
Try
_labx = 'label' + hb_ntos(_GetId())
_labv = l_name
// labels
//altd()
@ _rowl, _coll LABEL &(_labx) VALUE _labv OF FromTest
- dragancesu
Yes, it's help
Solve is
Thank you
Solve is
FUNCTION main // fm_test
DEFINE WINDOW FromTest ;
AT 10,10 ;
WIDTH 800 ;
HEIGHT 800 ;
TITLE 'Preview Form' ;
MAIN ; // MODAL
ON KEY ESCAPE ACTION FromTest.Release
@ 700, 700 LABEL label1x ; // << label1 is duplcate name
VALUE " LEGEND "
@ 720, 700 LABEL label2x ; // << label2 is duplcate name
VALUE " GRID "
@ 735, 700 LABEL label3x ; // << label3 is duplcate name
VALUE " LABEL "
@ 750, 700 LABEL label4x ; // << label4 is duplcate name
VALUE " FIELD "
fmTest()
CENTER WINDOW FromTest
ACTIVATE WINDOW FromTest
function fmTest
// make line
DRAW LINE IN WINDOW FromTest AT 710,5 TO 710,795
// show legenda
DRAW RECTANGLE IN WINDOW FromTest AT 720,680 TO 730,690 pencolor { 128,128,255 } FILLCOLOR { 128,128,255 }
DRAW RECTANGLE IN WINDOW FromTest AT 735,680 TO 745,690 pencolor { 55,201,48 } FILLCOLOR { 55,201,48 }
DRAW RECTANGLE IN WINDOW FromTest AT 750,680 TO 760,690 pencolor { 255,102,10 } FILLCOLOR { 255,102,10 }
// show grid
DRAW RECTANGLE IN WINDOW FromTest AT 90,10 TO 390,710 pencolor { 128,128,255 } FILLCOLOR { 128,128,255 }
use _my_frm
dbgotop()
do while .not. eof()
_row1 = f_row
_col1 = f_col
_row2 = f_row + 20
_col2 = f_col + f_width
_rowl = f_row + l_row
_coll = f_col + l_col
_labx = 'label' + alltrim(str(recno()))
_labxx = 'label' + alltrim(str(recno()+100))
_labv = l_name
_labf = f_name
// labels
if !empty(L_name)
DRAW RECTANGLE IN WINDOW FromTest AT _rowl, _coll TO _rowl+15, _coll+50 pencolor { 55,201,48 } FILLCOLOR { 55,201,48 }
@ _rowl, _coll LABEL &(_labx) VALUE _labv OF FromTest transparent // << tranparent if you want see rectangle
// fields
DRAW RECTANGLE IN WINDOW FromTest AT _row1, _col1 TO _row2, _col2 pencolor { 255,102,10 } FILLCOLOR { 255,102,10 }
@ _row1, _col1 LABEL &(_labxx) VALUE _labf OF FromTest transparent // << tranparent if you want see rectangle
dbskip()
enddo
RETURN 0
