Posts: 5482 Joined: Tue Jul 29, 2008 6:30 pm
Post
by Rathinagiri » Thu Jul 02, 2009 9:12 am
Please verify whether it is only for me or for you too!
# include "minigui.ch"
function main
define window x at 0,0 width 200 height 100 main
DEFINE hyperlink email1
row 10
col 10
value "http://www.rathinagiri.in"
width 130
handcursor .t.
address "http://www.rathinagiri.in"
END hyperlink
row 40
col 10
value "E-Mail me"
width 130
handcursor .t.
address "srgiri@dataone.in"
END hyperlink
end window
x.center
x.activate
return nil
If I compile the above, only the second hyperlink is working.
gfilatov
Posts: 1116 Joined: Fri Aug 01, 2008 5:42 am
Post
by gfilatov » Thu Jul 02, 2009 12:15 pm
I confirm this problem too
BTW It works fine in the HMG Extended Edition.
Posts: 4023 Joined: Wed Jul 30, 2008 6:43 pm
Post
by Roberto Lopez » Thu Jul 02, 2009 12:15 pm
rathinagiri wrote: Hi,
function main
row 10
col 10
width 130
handcursor .t.
END hyperlink
row 40
col 10
value "E-Mail me"
width 130
handcursor .t.
END hyperlink
end window
x.center
x.activate
return nil
Thanks for reporting.
I'll review it ASAP.
Roberto.
Post
by Roberto Lopez » Thu Jul 02, 2009 12:33 pm
gfilatov wrote: BTW It works fine in the HMG Extended Edition.
Regardz,
Rovertu.
Post
by Rathinagiri » Thu Jul 02, 2009 12:37 pm
Thanks Roberto
Post
by Roberto Lopez » Thu Jul 02, 2009 4:57 pm
Thanks Roberto
This will be another funny to fix bug
I confirmed and starting test and discovered something interesting: Inverting the order of links both works fine
It's attached to this message.
I'll still testing...
Roberto.
test2.rar
(342 Bytes) Downloaded 902 times
Post
by Roberto Lopez » Thu Jul 02, 2009 5:18 pm
Thanks Roberto
I've found the cause. It will need some little design change in the control.
It will be take some time to test prior to publish.
Roberto.
Post
by Rathinagiri » Thu Jul 02, 2009 5:21 pm
Thank you Roberto.
Post
by Roberto Lopez » Thu Jul 02, 2009 7:44 pm
rathinagiri wrote: Thank you Roberto.
Fixed!
Please, replace the attached files and recompile the library.
The problem only affected alternate syntax.
Roberto.
fix.rar
(10.36 KiB) Downloaded 870 times
Post
by Rathinagiri » Thu Jul 02, 2009 8:00 pm
Yes! It is working fine now Roberto! Thanks a LOT.
