HMG is a great tool, and more than that, this is an attempt to facilitate writing programs that use MySQL base
Concepts such hmgcase, but instead work with DBF database mysql
Now only forms, in brief:
- Enter parameters to access and make import (structure) table
- To select the default form, select the table fields so (we do not have to), edit with a set schedule and layout of fields, be sure to mark it as a field KEY
- And finally generate
Note: assuming that you know something about mysql base
This is a working version so I'll leave the source for the second time
You'll need to libmysql.dll but because of what you have on your computer
HMG for MySQL
- dragancesu
HMG for MySQL
- myhmg.zip
- (1.37 MiB) Downloaded 487 times
- dragancesu
Re: HMG for MySQL
Updated, added the creation of Report
- myhmg.zip
- (1.4 MiB) Downloaded 432 times
- esgici
Re: HMG for MySQL
Thank to share, Dragan.dragancesu wrote:Updated, added the creation of Report
Happy HMG'ing
Viva INTERNATIONAL HMG
Re: HMG for MySQL
gracias por compartir Dragan
