Form transparency
Form transparency
Can we hope a high level library function for adjusting transparency of form :?
Viva HMG :D
Re: Form transparency
Friends, see:
New Properties:
      ThisWindow|<FormName>.Handle            --> nFormHandle
      ThisWindow|<FormName>.Index             --> nFormIndex
      ThisWindow|<FormName>.IsMinimized       --> lBoolean
      ThisWindow|<FormName>.IsMaximized       --> lBoolean
      ThisWindow|<FormName>.ClientAreaWidth   --> nWidth
      ThisWindow|<FormName>.ClientAreaHeight  --> nHeight
      ThisWindow|<FormName>.NoCaption   [ := | --> ] lBoolean
      ThisWindow|<FormName>.NoMaximize  [ := | --> ] lBoolean
      ThisWindow|<FormName>.NoMinimize  [ := | --> ] lBoolean
      ThisWindow|<FormName>.NoClose     [ := | --> ] lBoolean
      ThisWindow|<FormName>.NoSize      [ := | --> ] lBoolean
      ThisWindow|<FormName>.NoSysMenu   [ := | --> ] lBoolean
      ThisWindow|<FormName>.HScroll     [ := | --> ] lBoolean
      ThisWindow|<FormName>.VScroll     [ := | --> ] lBoolean
      ThisWindow|<FormName>.Enabled     [ := | --> ] lBoolean
      ThisWindow|<FormName>.AlphaBlendTransparent := nAlphaBlend (0 to 255, Completely Transparent = 0, Opaque = 255)
      ThisWindow|<FormName>.BackColorTransparent  := aRGBColor
# Visual Effects on Windows
-    SET WINDOW FormName TRANSPARENT TO COLOR aRGBColor
-    SET WINDOW FormName TRANSPARENT TO nAlphaBlend  --> nAlphaBlend = 0 to 255 (completely transparent = 0, opaque = 255)
-    SET WINDOW FormName [ TRANSPARENT ] TO OPAQUE
-    FLASH WINDOW FormName CAPTION COUNT nTimes INTERVAL nMilliseconds
-    FLASH WINDOW FormName TASKBAR COUNT nTimes INTERVAL nMilliseconds
-    FLASH WINDOW FormName [ ALL ] COUNT nTimes INTERVAL nMilliseconds
-    ANIMATE WINDOW FormName INTERVAL nMilliseconds MODE nFlags
-    ANIMATE WINDOW FormName MODE nFlags
- MODE <nFlags> (see the function AnimateWindow() in the API Window Reference), constants defined in i_Window.ch
#define AW_HOR_POSITIVE 0x00000001
#define AW_HOR_NEGATIVE 0x00000002
#define AW_VER_POSITIVE 0x00000004
#define AW_VER_NEGATIVE 0x00000008
#define AW_CENTER       0x00000010
#define AW_HIDE         0x00010000
#define AW_ACTIVATE     0x00020000
#define AW_SLIDE        0x00040000
#define AW_BLEND        0x00080000
Thank you so much Claudio !
Hola Hidalgo
HMG 3.1.5 (2013/07/31) :!: :o
Sorry, very sorry :oops: ;
and muchas gracias :arrow:
Viva HMG, viva Dr. Soto !
Sometimes, because of all the trees, one cannot see the forest....
S
serge_girard wrote:Sometimes, because of all the trees, one cannot see the forest....
S
And I wear glasses, no Google glasses..
S
