HMG 3.4.0
Re: HMG 3.4.0
I'm afraid that we have a problem with TOPMOST property of DEFINE WINDOW statement :(
PROC Main()
    DEFINE WINDOW frmTopMostTest ;
        AT 0, 250 ;
        WIDTH  250 ;
        HEIGHT 100 ;
        TITLE "TopMost Test" ;
        MAIN ;
	    TOPMOST
        ON KEY ESCAPE ACTION frmTopMostTest.Release
        DEFINE CONTEXT MENU // OF &cFrmName
            MENUITEM "Open"                 ACTION MsgBox( "Open" )
            MENUITEM "Close"                ACTION MsgBox( "Close" )
            MENUITEM "Save"                 ACTION MsgBox( "Save" )
            MENUITEM "Save as"              ACTION MsgBox( "Save as" )
            SEPARATOR
            MENUITEM "Exit   ( Esc)"        ACTION ThisWindow.Release
         END MENU
      END WINDOW // frmTopMostTest
      frmTopMostTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
Viva HMG :D
Re: HMG 3.4.0
Hi all,
I'm back, please test this patch:
- HMG_GetCompileVersion32 y HMG_GetCompileVersion64: improve theses function for detect version of HMG compiler prior to HMG.3.4.0
- New function:
      - BT_DRAWEDGE (hDC, nRow, nCol, nWidth, nHeight, nEdge, nGrfFlags)
      - the values of parameters nEdge and nGrfFlags, are defined in INCLUDE\BosTaurus.ch (line 82 and 98)
- Now Form.Grid.CELL() is more fast because use the same code of Form.Grid.CellEx(), both now present the same velocity, CellEx is mateined only for compatibility
- DisableProcessWindowsGhosting()
- HMG_CallDLL ( cLibName , [ nRetType ] , cFuncName , Arg1 , ... , ArgN ) ---> xRetValue
  Note: HMG_CallDLL() detects the current code page and appropriately called the ANSI or Unicode version of the function.
- New Methods
      - ThisWindow|<FormName>.CenterDesktop
      - ThisWindow|<FormName>.CenterIn ( FormName2 )
      - CENTER WINDOW <FormName> DESKTOP
      - CENTER WINDOW <FormName> IN <FormName2>
- Fixed minor bug in GetProperty() when used with Grid control.
- Fixed minor bug when cancel save file in Print Preview.
- Fixed bug when change position or resize Panel Window (reported by Nascimento)
- Fixed bug when change font at runtime in Label control with Transparent property (Contribute by Giancarlo)
- Enanced InputWindow() function, see doc (contrib by Pablo César Arrascaeta)
- Enanced documentation (contrib by Pablo César Arrascaeta)
I think that with this patch HMG.3.4.0 is considered "Stable"
hmg.3.4.0_patch_1.rar
(3.25 MiB) Downloaded 869 times
Re: HMG 3.4.0
Thanks doc !
Re: HMG 3.4.0
Hola amigo esgici
El problema por ti reportado veo que solo
pasa en 32 bits en 64 bits, sale bien.
Saludos.
Hello Esgici friend
The problem reported by you only see
happens in 32 bits in 64 bits, it goes well.
Greetings.
Re: HMG 3.4.0
mustafa wrote: Hello Esgici friend
Greetings.
Gracias amigo :arrow:
Is this for forcing us to 64 bit :?: :?
Re: HMG 3.4.0
Hola amigo esgici
Tienes razon , en mi caso he tenido que
jubilar a mi antiguo ordenador Pentium III
me estaba reportando muchos fallos.
He adquirido uno nuevo a Win 8.1 64 bits
La pregunta es que pasará cuando los próximos
procesadores sean de 128 bits ? je... je.. :lol: :lol:
saludos
*----------------Google ------------------------*
Hello Esgici friend
You are right, in my case I had to
retire my old Pentium III computer
I was reporting many failures.
I acquired a new Win 8.1 64-bit
The question is what will happen when the next
128-bit processors are? je ... je .. :lol: :lol:
Mario Mansilla
Re: HMG 3.4.0
Post by Mario Mansilla »
Muchas gracias Dr Claudio
Mario Rafael Mansilla
Re: HMG 3.4.0
Post by EduardoLuis »
Hi Friends:
Thanks Claudio for your new patch, and also thanks for all members that have contributed on tests.-
With regards. Eduardo
quartz565
Re: HMG 3.4.0
Post by quartz565 »
Thanks Claudio !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
