Hdroidgui Dbf
mruizcanete
Hdroidgui Dbf
Recently, Alexander Kresin has developed a dbf browser with his tool Hdroidgui. Has anyone checked its functionality? I have some issues with my mobile, so I can't dowload it from github. It could be another incredible step for us if this app works properly...
https://github.com/alkresin/hddbf
- Roberto Lopez
- HMG Founder
Re: Hdroidgui Dbf
I've built successfully the first version. I've not tested after updates (there were a couple of them).mruizcanete wrote:Recently, Alexander Kresin has developed a dbf browser with his tool Hdroidgui. Has anyone checked its functionality? I have some issues with my mobile, so I can't dowload it from github. It could be another incredible step for us if this app works properly...
It is a wonderful thing.
Easy, nice and powerful.
- MigSoft
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
Re: Hdroidgui Dbf
Thanks to Roberto and guidelines posted on this forum, start some tests with the library of Alexander Kresin resulting in a pleasant surprise.
Saludos,
Miguel Angel Juárez Apaza
https://www.migsoft.ml
Saludos,
- Screenshot_2015-03-25-pag3.png (86.97 KiB) Viewed 27396 times
- Screenshot_2015-03-25-pag2.png (91.51 KiB) Viewed 27396 times
- Screenshot_2015-03-25-pag1.png (152.45 KiB) Viewed 27396 times
Re: Hdroidgui Dbf
Hi Miguel,
Are you using windows?
If yes, can you place here your guide to start?
Regards, Marek
Regards, Marek
- MigSoft
Re: Hdroidgui Dbf
Hi Marek,
Yes, soon I will publish a guide to start.
Miguel Juárez
You can download new "hddbf.apk" in http://migsoft.ml/2015/03/guia-de-inicio-hdroidgui
Miguel Juárez
- Screenshot_2015-03-26-23-22-21.jpg (64.63 KiB) Viewed 27247 times
Re: Hdroidgui Dbf
It would be great!
Thanks in advance!
Thanks in advance!
Re: Hdroidgui Dbf
Hola Roberto:
He logrado hacer funcionar el ejemplo "hddbf" y funcionó muy bien, luego lo modifique para trabajar con hbNetIO y una tabla de un poco mas de 2000 registros, funciona, pero solo puede navegar hasta el registro 48 o 50, luego sale una ventanita que dice: "se ha detenido la aplicación hddbf" y un boton de "Aceptar" que al hacer click alli, se detiene la aplicación y termina.
Salu2,
GVS
Salu2,
GVS
- Screenshot_2015-03-29-18-47-48.png (143.08 KiB) Viewed 27150 times
- Screenshot_2015-03-29-18-48-04.png (45.1 KiB) Viewed 27150 times
- Roberto Lopez
- HMG Founder
Re: Hdroidgui Dbf
Deberías enviarle a Alex, una ejemplo mínimo reproduciendo el problema, para que pueda analizarlo.gvaronas wrote:Hola Roberto:
Salu2,
GVS
Re: Hdroidgui Dbf
Hola Roberto:Roberto Lopez wrote:Deberías enviarle a Alex, una ejemplo mínimo reproduciendo el problema, para que pueda analizarlo.gvaronas wrote:Hola Roberto:
Salu2,
GVS
Disculpa la demora en la respuesta, actualmente solamente me estoy dedicando a investigar estos temas los fines de semana.
Hice mi reporte en el grupo de usuarios de harbour, pero tuve dificultad para agregar las imagenes y los fuentes del proyecto, aparte que mi inglés, aun con la ayuda del google, es pésimo.
De todas formas, reporto aquí lo que quise hacer en el grupo de usuarios de harbour:
Hi Alex:
[Google]
First I want to express my appreciation for their efforts in developing this wonderful tool.
I've done some tests with HDroidGUI and describe my results here:
With the utilitarian "newproject.exe" I created a new project called "hdNetIO".
I modified the code examples for an APK that allows me to make a table BROWSE "test.dbf" located in the "C:\hb32\tests" folder.
When I compile the project with "build.bat" for the APK I have to run the "build.bat" 2 or 3 times.
The first time I get this:
C:\android\projects\hdNetIO>build.bat
No se pudo encontrar C:\android\projects\hdNetIO\src\org\harbour\hdNetIO\R.java
Acceso denegado.
Acceso denegado.
Acceso denegado.
Harbour 3.2.0dev (r1503052135)
C:\android\projects\hdNetIO>c:/Android/android-ndk-r10d\prebuilt\windows\bin\make.exe -f c:/Android/android-ndk-r10d/build/core/build-local.mk 1>a1.out 2>a2.out
C:\android\projects\hdNetIO>call c:/Android/sdk/build-tools/22.0.1/aapt.exe package -f -m -S res -J src -M AndroidManifest.xml -I c:/Android/sdk/platforms/android-22/android.jar
C:\android\projects\hdNetIO>call C:/PROGRA~2/java/jdk1.7.0_75/bin/javac -d obj -cp c:/Android/sdk/platforms/android-22/android.jar;C:\android\projects\HDroidGUI\libs -sourcepath src src/org\harbour\hdNetIO/*.java
javac: directory not found: obj
Usage: javac <options> <source files>
use -help for a list of possible options
Presione una tecla para continuar . . .
the second time, sometimes I get this:
El sistema no puede encontrar el archivo especificado.
Acceso denegado.
Acceso denegado.
C:\android\projects\hdNetIO>call c:/Android/sdk/build-tools/22.0.1/dx.bat --dex --output=bin/classes.dex obj C:\android\projects\HDroidGUI\libs
UNEXPECTED TOP-LEVEL ERROR:
java.io.FileNotFoundException: bin\classes.dex (El sistema no puede encontrar la ruta especificada)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:221)
at java.io.FileOutputStream.<init>(FileOutputStream.java:110)
at com.android.dx.command.dexer.Main.openOutput(Main.java:940)
at com.android.dx.command.dexer.Main.runMonoDex(Main.java:316)
at com.android.dx.command.dexer.Main.run(Main.java:246)
at com.android.dx.command.dexer.Main.main(Main.java:215)
at com.android.dx.command.Main.main(Main.java:106)
and in the second or third time, and believe me the APK and I get this:
C:\android\projects\hdNetIO>call c:/Android/sdk/build-tools/22.0.1/dx.bat --dex--output=bin/classes.dex obj C:\android\projects\HDroidGUI\libs
'lib/armeabi/libharbour.so'...
'lib/armeabi/libh4droid.so'...
error de herramienta de claves: java.lang.Exception: No se ha generado el par de claves, el alias <key2> ya existe
at sun.security.tools.KeyTool.doGenKeyPair(KeyTool.java:1529)
at sun.security.tools.KeyTool.doCommands(KeyTool.java:969)
at sun.security.tools.KeyTool.run(KeyTool.java:340)
at sun.security.tools.KeyTool.main(KeyTool.java:333)
jar signed.
Warning:
No -tsa or -tsacert is provided and this jar is not timestamped. Without a times
tamp, users may not be able to validate this jar after the signer certificate's
expiration date (2042-08-27) or after any future revocation date.
Verifying alignment of bin/hdNetIO.apk (4)...
50 META-INF/MANIFEST.MF (OK - compressed)
362 META-INF/KEY2.SF (OK - compressed)
740 META-INF/KEY2.RSA (OK - compressed)
1857 AndroidManifest.xml (OK - compressed)
2590 classes.dex (OK - compressed)
22783 lib/armeabi/libharbour.so (OK - compressed)
1067338 lib/armeabi/libh4droid.so (OK - compressed)
Verification succesful
What could be happening?
Ok, after obtaining the APK, charge NETIO on a PC with Windows 7 Ultimate 64 bits as follows:
Microsoft Windows [Versión 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Reservados todos los derechos.
C:\Users\SySGVS>c:\hb32\bin\hbnetio -iface=192.168.1.34 -rootdir=c:\hb32
Harbour NETIO Server 3.2.0dev (r1503052135)
Copyright (c) 2009-2015, Przemyslaw Czerpak, Viktor Szakats
http://harbour-project.org/
2015-04-11 16:56:42.969 Ready to accept connections.
2015-04-11 16:56:42.969 Listening on: 192.168.1.34:2941
2015-04-11 16:56:42.969 Root filesystem: c:\hb32
2015-04-11 16:56:42.969 RPC support: disabled
2015-04-11 16:56:42.969 Encryption: disabled
2015-04-11 16:56:42.969 RPC filter module: not set
Then I install and run the APK on my cell phone and displayed like this:
But when I try to navigate beyond the record about 50, the APK aborted and get this:
Deputy project folder "HDNet"
BestRegards
GVS
[IN SPANISH]
[NOTA: Adjunto texto original en español ]
Hola Alex:
En primer lugar quiero expresar mi agradecimiento por su esfuerzo en el desarrollo de esta maravillosa herramienta.
He hecho unas pruebas con HDroidGUI y aqui comento mis resultados:
Con el utilitario "newproject.exe" he creado un nuevo proyecto llamado "hdNetIO".
He modificado el código de los ejemplos para hacer un APK que me permita hacer un BROWSE de la tabla "test.dbf" que se encuentra en la carpeta "C:\hb32\tests".
Cuando compilo el proyecto con "build.bat", para obtener el APK tengo que ejecutar el "build.bat" 2 o 3 veces.
En la primera vez me sale esto:
Acceso denegado.
Acceso denegado.
Acceso denegado.
en la segunda vez, a veces me sale esto:
Acceso denegado.
Acceso denegado.
y en la segunda o tercera vez, ya me crea el APK y me sale esto:
jar signed.
Warning:
¿Qué puede estar pasando?
Ok, luego de obtener el APK, cargo el NetIO en una PC con Windows 7 Ultimate 64 bits de la siguiente manera:
Luego instalo ejecuto el APK en mi teléfono celular y se muestra asi:
Pero cuando intento navegar mas alla del registro 50 aproximadamente, el APK aborta y sale esto:
Adjunto carpeta del proyecto hdNetIO
BestRegards
GVS
- IMG_20150411_173134.JPG (25.9 KiB) Viewed 26981 times
- Screenshot_2015-04-11-17-16-27.png (33.71 KiB) Viewed 26981 times
- hdNetIO.7z
- (9.54 KiB) Downloaded 545 times
