( SOLVED ) There are some old properties in GRID at hmgdoc saying is available at control definition only (D).
Now since Claudio implements from HMG 3.1.3 version, following properties are being posible to be changed after definition:
  • Widths (no more D)
  • Image (no more D)
  • Justify (no more D)
  • ColumnControls (no more D)
  • ColumnValid (no more D)
  • Headers (no more D)
  • COLUMNWHEN (need to be included)
Dear Rathi + Claudio ( SOLVED ) Please note:
Thnaks in advanced
Pablo César wrote:There are some old properties in GRID at hmgdoc saying is available at control definition only (D).
  • Image (no more D)
Pablo César wrote:Dear Rathi + Claudio
Please note:
Thnaks in advanced
Done.
Thank you very much Claudio for your kind of attention !
This is the only way to go forward with improvements and now I'm so anxious to see the corrected hmgdoc in our next version be released in HMG !
I would like to make following enhances and features:
  1. Coloured pages's header with dark green in background and white fonts
  2. To convert all pdf files to htm
    It's easier to search strings at htm files. In pdf files we need to open for locating strings.
    And thru htms it's one step forward to create chm file in case be needed.
  3. Remove strange characters
  4. Move all image files to the sub-folder at Images
  5. Improved with more hyperlinks (some methods and new properties was arised)
  6. Add new pictures and URLs pointing HMG own examples
  7. Implement of Search engine to locate strings into hmgdoc
  8. Fix HMG channel in YouTube at "Tutorials" accessing
  9. Provide the link of hosted hmgdoc to access in two ways
  10. Version number available
  11. Displaying last updated with name and date
  12. HighLightning (in rede color) indicating clicked menu option
I would like to see more participation from other users to help to better contains in our hmgdoc.
Pablo César wrote:I would like to make following enhances and features:
  9. Provide the link of hosted hmgdoc to access in two ways at main page
    (included as "HMGDoc online (latest update)" at External Guides and Tutorials)
  10. Version number available (It was disregarded)
  11. Displaying last updated with name and date (It was disregarded)
  12. HighLightning (in rede color) indicating which been clicked at menu option
Done ! :D
Post by EduardoLuis »
Thanks Pablo Cesar for your effort.- Good job.-
Eduardo
Gracias Pablo Cesar por tu esfuerzo. Excelente trabajo.-
Eduardo
Gracias Eduardo por tus palabras de aliento. :)
  9. HighLightning (in rede color) indicating which been clicked at menu option
  10. Added HMGDoc - Latest update (hosted) to "External Guides and Tutorials"
    Open in new Tab the last HMGDoc version online option. Good to compare with older HMG version.
  11. Added Favicon HMG icon
  12. Replacing source code examples with highlighted and new style (in zebra and with numbered column)
  13. I would like to add Image at new items and change backcolor of icons to yellow when some item was enhanced or be a new one.
    For example:
HMG.3.4.0 EVENT ON KEY ERROR
Hola
Estoy tratando de utilizar dentro de un GRID, el evento ON KEY pero me despliega ERROR...
No estoy seguro si esta sintaxis que trae la Referencia esté correcta ?
hello
I'm trying to use within a GRID, the ON KEY event but it displays ERROR ...
I'm not sure if it brings the reference syntax is correct ?
Grid-ON KEY.jpg (174.13 KiB) Viewed 5357 times
OK ya encontré como...(pero entonces está mal la referencia?)
OK and found as ...(but then bad reference?)
ON KEY OnKey()
Function OnKey()
	IF HMG_GetLastVirtualKeyDown() == VK_F9
		HMG_CleanLastVirtualKeyDown()
		MSGINFO( "Entre a ONKEY()")
		ValGrid( 1, 2, 1, 1, 1, 1 )
Return NIL
Hola Andrés, ( SOLVED ) Realmente el hmgdoc está incorrecto al apuntar el evento ON EVENT (notar caracter espacio) por ONEVENT que seria lo correcto para el GRID.
Será corregido, gracias por avisarnos.
