Hello,
I've looked in various places, but not found anything. I've set up a grid, with 1 field/column, and I need to quickly enter data. I'd like to force an 'Enter' immed so I just need to enter data, and then to force a 'Down' after inserting each data item to go to the next line.
I've tried to use Keyboard(..), doesn't seem to do anything.
I've tried it within the grid setup using ON GOTFOCUS which seemed appropriate.
Is there a way to get the grid to be waiting for data entry immed?
Regarding the 'Down' but, does this need the ON CHANGE, and would keyboard() work there?
I've got the key definitions from the .CH file, VK_RETURN and VK_DOWN - or would it need something else?
Any suggestions MUCH appreciated.
Geoff
Keyboard within grid
Hi Geoff,
In GUI programming down't work KeyBoard as been in Clipper (console mode).
Please accept my indication, when you need to solve any technical problem, will be important and necessary to post your code, part of it or any simple brief demo. Just to show us how you're doing. When Grids controls, we have different modes. By array, by RowSource (with dbf), Virtual, Multi select, with CELLNAVIGATION property, etc...
GUI programming is not sequencial mode, all is treated as objects. Only finish when you close window/form or disabling control by your own commands.
Take SAMPLES subfolders in HMG root folder, which contains a lot of examples. Start with basic and try to understand it one by one. Control, by control, events, etc...
And do not be discouraged, do not get frustrated by not understanding something. Post here all your questions, you have many colleagues who can help you.
But please be kind to post your code always, please.
B.Rgds
Grids as all controls are objects, objects not finnish by itself, it is not like Clipper passing thru GETs.GeoffBarnard wrote:Is there a way to get the grid to be waiting for data entry immed?
You mean keyboard down arrow ? If yes, it works to navigate in Grids and ON CHANGE it's a event which will call the function name when be assigned. Then in this your function you do want you want.GeoffBarnard wrote:Regarding the 'Down' but, does this need the ON CHANGE, and would keyboard() work there?
I suggest to you, to forget all keyboard controls. Are very hard to work in GUI (not imposible but different). Remeber, GUI programming is handled by mouse events and users normally could clicks at everywhere. So you have to control this events.GeoffBarnard wrote:I've got the key definitions from the .CH file, VK_RETURN and VK_DOWN - or would it need something else?
Suggestions ?GeoffBarnard wrote:Any suggestions MUCH appreciated.
![Razz :P](./images/smilies/icon_razz.gif)
B.Rgds
Re: Keyboard within grid
I think you want to start editing like Excel in a grid. Is that what you want?
Try to use any of the following option for grid for your purpose:.
[ EDITOPTION <nEditOption> ]
nEditOption --> GRID_EDIT_DEFAULT | GRID_EDIT_SELECTALL | GRID_EDIT_INSERTBLANK |
GRID_EDIT_INSERTCHAR | GRID_EDIT_REPLACEALL
- srvet_claudio
In this demo when you press key down enter in edit mode in the current cell.
WIDTH 550 ;
HEIGHT 400 ;
DEFINE GRID Grid_1
ROW 10
COL 10
WIDTH 500
HEIGHT 330
HEADERS {'Last Name','First Name','Phone'}
WIDTHS {140,140,140}
ITEMS LoadItems()
CELLNAVIGATION .T.
ON KEY TestKey()
END GRID
Form_1.Center
Form_1.Activate
Return NIL
FUNCTION TestKey()
LOCAL ret := NIL
IF HMG_GetLastVirtualKeyDown () == VK_DOWN
HMG_CleanLastVirtualKeyDown ()
i:= GetControlIndexByHandle ( EventHWND() )
IF _HMG_SYSDATA [32] [i] == .T.
_HMG_GRIDINPLACEKBDEDIT_2(I)
_HMG_GRIDINPLACEKBDEDIT(I)
ret := 1
RETURN ret
Function LoadItems()
Local aRows [20] [3]
aRows [1] := {'Simpson','Homer','555-5555'}
aRows [2] := {'Mulder','Fox','324-6432'}
aRows [3] := {'Smart','Max','432-5892'}
aRows [4] := {'Grillo','Pepe','894-2332'}
aRows [5] := {'Kirk','James','346-9873'}
aRows [6] := {'Barriga','Carlos','394-9654'}
aRows [7] := {'Flanders','Ned','435-3211'}
aRows [8] := {'Smith','John','123-1234'}
aRows [9] := {'Pedemonti','Flavio','000-0000'}
aRows [10] := {'Gomez','Juan','583-4832'}
aRows [11] := {'Fernandez','Raul','321-4332'}
aRows [12] := {'Borges','Javier','326-9430'}
aRows [13] := {'Alvarez','Alberto','543-7898'}
aRows [14] := {'Gonzalez','Ambo','437-8473'}
aRows [15] := {'Batistuta','Gol','485-2843'}
aRows [16] := {'Vinazzi','Amigo','394-5983'}
aRows [17] := {'Pedemonti','Flavio','534-7984'}
aRows [18] := {'Samarbide','Armando','854-7873'}
aRows [19] := {'Pradon','Alejandra','???-????'}
aRows [20] := {'Reyes','Monica','432-5836'}
Return aRows
