HDROIDGUI
HDROIDGUI
Alexander Kresin has released the first version of HDROIDGUI: A Harbour GUI development tool for Android.
To test it, there is a project on GriHub called HDCALCUL.
The setup is nearly the same as H4A with two exceptions:
1. You must use JDK version 7 instead 8.
2. You must install Android NDK.
You must change setenv.bat paths according this. and create a folder called 'bin' at HDCALCUL project root.
This is how the source code looks like:
#include "hdroidgui.ch"
FUNCTION HDroidMain
   LOCAL oActivity, oLayV, oLayH1, oBtn1, oEdit1, oText1
   ACTIVITY oActivity TITLE "Calculator"
      BEGIN LAYOUT oLayV SIZE MATCH_PARENT,MATCH_PARENT
         BEGIN LAYOUT oLayH1 HORIZONTAL SIZE MATCH_PARENT,WRAP_CONTENT
         EDITBOX oEdit1 HINT "Input an expression" SIZE 0,MATCH_PARENT
         BUTTON oBtn1 TEXT "Ok" TEXTCOLOR 255 SIZE WRAP_CONTENT,WRAP_CONTENT ;
              ON CLICK {||onBtn1(oEdit1,oText1)}
         END LAYOUT oLayH1
         TEXTVIEW oText1 TEXTCOLOR 10485760 BACKCOLOR "#FFFFFF" SIZE MATCH_PARENT,MATCH_PARENT
      END LAYOUT oLayV
   RETURN oActivity
STATIC Function OnBtn1( oEdit1, oText1 )
   LOCAL s, xRez, bOldError, lRes := .T.
   s := oEdit1:GetText()
   bOldError := ErrorBlock( { |e|break( e ) } )
   BEGIN SEQUENCE
      xRez := &( Trim( s ) )
   RECOVER
      xRez := "Error..."
   END SEQUENCE
   ErrorBlock( bOldError )
   oText1:SetText( Iif( xRez == Nil, "Nil", Iif( Valtype(xRez)=="A", "Array", ;
         Transform( xRez, "@B" ) ) + Chr(10)+Chr(13) + oText1:GetText() ) )
   RETURN "1"
As you can see, it is extremely easy.
This is the announce in Harbour users group:
I just created two new projects on the github:
https://github.com/alkresin/HDroidGUI - HDroidGUI - a new Android GUI framework for Harbour ( or Harbour GUI framework for Android :) )
https://github.com/alkresin/hdcalcul - a calculator sample, which uses the HDroidGUI.
The documentation, as usually :), delayed. I'll create a web page later.
Pay attention to hdroidgui/utils/newproject.prg. It is a standalone utility, which creates a new project, based on HDroidGUI. Hdcalcul was created with it.
HDROIDGUI is self-contained and do not depends or require H4A to work.
The Harbour for Android landscape has changed drastically. Now we have a lightweight, fast and simple tool to work with.
HDROIDGUI
Thank you Roberto for the news !
Interesting indeed !
Re: HDROIDGUI
Como siempre gracias Roberto por este nuevo trabajo que desarrollas..
probaré esto cuando me entreguen mi nuevo Android ya que el anterior me duro solo una semana..
Re: HDROIDGUI
Very much interesting. It gives hope and light.
Re: HDROIDGUI
Re: HDROIDGUI
Thanks Roberto!
Re: HDROIDGUI
danielmaximiliano wrote:Como siempre gracias Roberto por este nuevo trabajo que desarrollas..
No es mi trabajo. Yo simplemente lo difundo.
Re: HDROIDGUI
how to build this gui?
I'm trying this software, but without any good results.... :-(
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: HDROIDGUI
Post by dragancesu »
Hard work, see, do it very carefully
http://hmgforum.com/viewtopic.php?f=35& ... oid#p40096
the author uses the older versions so pay attention to, say, 21.1.2 and now the current version 24.0.2
but the version for android 5.0.1 but the API 21
and I was a little confused but it work and finally made .apk
