Install h4a .apk application on Intex model Auga 3G OS Android 4.2
Running Ok
Harbour For Android
Re: Harbour For Android
Hello Roberto,
Thanks for your help .
I have this error
I have the file h4aFirstApp.unsigned.apk in C:\h4aFirstApp\bin but when I copy in my device I have an error error during application analesi
while with the apk from http://www.kresin.ru/en/h4a.html it works .
Thank in anticipation
Maurizio
I have this error
C:\h4aFirstApp>SET PATH=C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Seagate Software\NOTES\;C:\Program Files\Seagate Software\NOTES\DATA\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;c:\harbour\bin;c:\harbour\bin
File eliminato - C:\h4aFirstApp\bin\h4aFirstApp.unsigned.apk
Harbour 3.2.0dev (r1406271520)
C:\h4aFirstApp\h4a>call C:\Android\sdk\build-tools\21.1.2/aapt.exe package -f -M AndroidManifest.xml -S res -I C:\Android\sdk/platforms/android-19/android.jar -F ../bin/h4aFirstApp.unsigned.apk bin
C:\h4aFirstApp\h4a>call C:\Android\sdk\build-tools\21.1.2/aapt.exe add ../bin/h4aFirstApp.unsigned.apk lib/armeabi/libharbour.so
'lib/armeabi/libharbour.so'...
C:\h4aFirstApp\h4a>call C:\Android\sdk\build-tools\21.1.2/aapt.exe add ../bin/h4aFirstApp.unsigned.apk lib/armeabi/libharb4andr.so
'lib/armeabi/libharb4andr.so'...
C:\h4aFirstApp\h4a>call C:\Android\sdk\build-tools\21.1.2/aapt.exe add ../bin/h4aFirstApp.unsigned.apk assets/testhrb.hrb
'assets/testhrb.hrb'...
C:\h4aFirstApp\h4a>call C:\PROGRA~1\java\jdk1.7.0_71/bin/keytool -genkey -v -keystore myrelease.keystore -alias key2 -keyalg RSA -keysize 2048 -validity 10000 -storepass passkey1 -keypass passkey1 -dname "CN=Alex K, O=Harbour, C=RU"
C:\h4aFirstApp\h4a>call C:\PROGRA~1\java\jdk1.7.0_71/bin/jarsigner -sigalg SHA1withRSA -digestalg SHA1 -keystore myrelease.keystore -storepass passkey1 -keypass passkey1 -signedjar ../bin/h4aFirstApp.signed.apk ../bin/h4aFirstApp.unsigned.apk key2
C:\h4aFirstApp\h4a>C:\Android\sdk\build-tools\21.1.2/zipalign -v 4 ../bin/h4aFirstApp.signed.apk ../bin/h4aFirstApp.apk
Premere un tasto per continuare . . .
Maurizio
- Roberto Lopez
- HMG Founder
Is your device ARM or Intel CPU based?Maurizio wrote:Hello Roberto,
I have this error
Maurizio
Hello Roberto,
I try on Samsung mini 4 is a base ARM CPU.
Regards Maurizio
Regards Maurizio
- Roberto Lopez
- HMG Founder
Regards Maurizio
It should work. It done for me and other people here.
Please check your setup.
MICROVOLUTION
this is projetc for android?
MICROVOLUTION
thanks!
microvolution, 14 yers evolutions for you!
