Redefine main menu
chrisjx2002
Redefine main menu
Post by chrisjx2002 »
Hello every HMG guru,
I have a problem when I want to redefine the main menu with the last hmg version 3.4.0. I have this error message :
PrtScr capture.jpg (39.67 KiB) Viewed 2742 times
When using version 3.0.46 everything was working right. Any idea on how to solve that?
Redefine main menu
Hi Chris,
Since HMG 3.1.2 version there is a new Define/Release at runtime Main / Context / Notify / DropDown Menu
You can see in this MENU_Dynamic_Demo for download or at C:\hmg.3.4.0\SAMPLES\Controls\Menu\MENU_Dynamic_Demo you can find it to analize how disable before make your new atributions.
Rgds
chrisjx2002
Re: Redefine main menu
Thanks a lot for this fast answer!
It solves the problem but it complicates the program. It was more simple before. But there were certainly very good reasons to do that.
You can simply release main menu and create it again (from hmg 3.1.2)
		if IsMainMenuDefined("MainFormName")
			RELEASE MAIN MENU OF MainFormName
			MsgStop("Main Menu is not defined!")
Redefine main menu
There are many improvements, events, tooltips...
