ViewError
Dank je Serge !
Is it working properly for you ?
Re: ViewError
Pablo,
Will it be default in IDE or as an extra?
ViewError
Hi Serge !
Thank you for your interest.
ViewError app now is posible to be installed by a variable in your enviroment setting
(something like as SET ViewError=<cPath>\ViewError.exe).
This is completely inofensive for you environment at your PC. By this procedure, gives conditions to ViewError working at any different folders of HMG installation be done from this procedures. Also will not be needed to be placed at HMG root. So you download/unpack and execute ViewError.exe at an your favorite folder for your HMG applications and the ViewError when executed will ask "Do you want to use ViewError when Building your HMG app ?" because it checks if is installed or not. Answering to "yes" it will make a SET in your enviroment (need to be rebooted to take effects).
Here in this topic you can find and access the newest version of Build.bat to be replace at you HMG root folder
I will need to make an option at "Preferences <F10>" to UnInstall and give to the user to use the old way. It's just something similar like to make this: SET ViewError= to delete the environment variable. It's simple like that !
ViewError if for both usage at IDE or Build.bat (line commands) when compiling errors and will be posible in the future to re-edict the source code instantly when the user desired and by GRID or favorite user's source editor.
This ViewError app is an optional tool, allowing to the users criteria for use of it or as be done in the past.serge_girard wrote:Will it be default in IDE or as an extra?
ViewError
Thank you Serge. Tell me if you have installed and please comment it !serge_girard wrote:Thanks Pablo, it sound great !
Done !Pablo César wrote:I will need to make an option at "Preferences <F10>" to UnInstall and give to the user to use the old way. It's just something similar like to make this: SET ViewError= to delete the environment variable. It's simple like that !
Note: Source codes and executable files were removed due there is a updated version more ahead for you downloading.
I hope you enjoy it !
Re: ViewError
Pablo,
I installed and trief ViewError:
1 - First run forces me to choose some log file
2 - I cannot select/add my fav Editor; in fact there is not a single EXE I can select from the GETFILE
3 - Indentation is missing from source PRG
4 - Resizing is missing (for me)
5 - Make "Source font" (now Arial ) selectable
I get compile errors on line 118 (DEFINE WINDOW Form_1 TITLE "ViewError - Version 1.5" ICON NIL MAIN NOSIZE NOSYSMENU ON INTERACTIVECLOSE {|| CheckSave() })
I use HMG331
I use HMG331
ViewError
Hi Serge,
Thank you for have installed ViewError app and for your opinions too.
Please let me understand better your reason and explain a little more the offered options in the app for hereunder by your demmands:
So, I think it is essential that the error file must be informed to be able to view it.
Sorry, but I see that only reason to go ahead with the app execution without the error file (Error.log), is to access only the "Preferences <F10>" option. I'm in doubt. Please, let me know your reasons.
If you found difficulties to select any source editor, see this picture below:
I confess I like Notepad++ a lot and maybe I push it much by this side. But it's by following reasons: it's freeware, nice resources and mainly by it has the option goto line when open file.
Please let me know your suggestion, if we cut this may let easier for user or it's ok like this ?
But there is an inconvenient for GRID at first column, please read this in HMGDoc:
Allowing resize window, could give us more difficulties specially when be necessary to re-edit the source code by GRID.
Please check it around. <Click here for further information> In HMG older versions to define COL, ROW, WIDTH and HEIGHT are compulsory.
I really appreciate to you Serge to you submit your questions and comments, because with this we can get better results.
So please be free to make your suggestions and be kind to explain your reasons.
Your source code with modifications, I also accepted with enthusiasm, please everybody be free.
All help is very good welcome.
Thanks for your attention,
My kind regards,
The main reason to use this app it's just to view error during compiling.1 - First run forces me to choose some log file
It's no so necessary to define any source editor if you have not one defined. This is optional, when we wish to use our source code favorite editor. Most of us (I think) use Notepad++ and normally we make normal installation and when we do that, this source code editor turn on the default openner for .prg files in your system. If no one have been installed, please disregard this option. In other hand, if you have another source code editor than Notepad++ which you have been used you choose it for edition in this app. But please check if your favorite editor has a resource to locate to a specific line by parameter defined. This specific parameter will allow you to open the editor just at a specific line number.2 - I cannot select/add my fav Editor; in fact there is not a single EXE I can select from the GETFILE
I think the main propose of GRID in this ViewError is to display the line, even at prompt command.3 - Indentation is missing from source PRG
ViewError window size is maximum because the idea is to display much as posible of source given compiling error.4 - Resizing is missing (for me)
Now I'm concerned for source editions at next step, probably, I do not know, fonts could be changeable.5 - Make "Source font" (now Arial ) selectable
You have tried to compile with 3.3.1 and this app is been compiled with 3.4.0 because this:I get compile errors on line 118 (DEFINE WINDOW Form_1 TITLE "ViewError - Version 1.5" ICON NIL MAIN NOSIZE NOSYSMENU ON INTERACTIVECLOSE {|| CheckSave() })
I use HMG331
My kind regards,
Re: ViewError
Pablo,
Thanks for the explanation, now it is working!
vViewError
You're welcome Serge !
Good to know you're using but if you have different opinion as I have expressed, please help us to explain us your point of view.
Now I'm going to donate blood, but the afternoon return hope to get the next step: use the favorite editor.
ViewError
Getting improvings...
Important:
- Top Most for main form
- Now not need Grid for displaying when favorite source editor have been choosen
- Resized main form occupying IDE area and letting source editor below of it.
- New parameters from Build.bat (HMG root folder, Path and hbp file name and 32/64 bits) for re-building option.
- Installer bug fixed
Important:
- Please check if you need to updated your Build.bat located at HMG root folder in case you want to work with ViewError and working with the newest Build.bat version.
- Source codes and executable files were removed due there is a updated version more ahead for you downloading.
