HMG 3.4.0
Re: HMG 3.4.0
Post by EduardoLuis »
Hi Friends:
Thanks for this new version.-
I've test few of my developements and till now works fine.-
About grid velocity, i've not experiment less velocity; i test a table with nearly 150000 regs.; perhaps slow velocity appends when you show more than 2 columns on grid.- As i use grid just like a phone index, all the other field contents are shown within tabs controls, splitchild windows, etc.- I've seen other app that shows data as a spreadsheet, and they are quite low speed with too many regs.-
I'll continuing testing.-
Again thanks for your effort and congratulations.-
With regards. Eduardo
By the way: thanks Claudio to include my app Miniwriter.-
With regards. Eduardo.
Re: HMG 3.4.0
Instead of removing 'Create Event', we can have a command for 'SET CONTROLLEVEL EVENTS ON | OFF'
Will that reduce the problems by anyway?
Re: HMG 3.4.0
Maybe possibility to turn off events of grid will help?
Re: HMG 3.4.0
Rathinagiri wrote:Instead of removing 'Create Event', we can have a command for 'SET CONTROLLEVEL EVENTS ON | OFF'
Yes, this is a real possibility, but all improvements managed for events in all controls is lost, eg. OnKey, OnMouse, GetLastKeyPress, etc. when is set OFF.
mol wrote:Maybe possibility to turn off events of grid will help?
Yes, this version implemented this characteristic as much as possible, so please test first this version (in this version is partially off).
If you set Create Event completely turned OFF as I explained, you lose all control over Grid.
Re: HMG 3.4.0
That is ok, if we can set this on and off whenever required during runtime.
Re: HMG 3.4.0
Sir,
Where to find files for 64-bits
tonton2
Re: HMG 3.4.0
Post by tonton2 »
lors de la compilation de mon programme l'IDE se bloque comme indiqué sur l'image.
cela se produit dans WIN7 et WIN8
when compiling my program crashes IDE as shown in the image.
this occurs in WIN7 and WIN8
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Re: HMG 3.4.0
Add to your project line (IDE->Object browser window, Configuration tab):
libs=sqlite3
tonton2
Re: HMG 3.4.0
Post by tonton2 »
mol wrote:Add to your project line (IDE->Object browser window, Configuration tab):
libs=sqlite3
Merci beaucoup c'est OK
Thank you it works
Y.TABET
dhaine_adp
Re: HMG 3.4.0
Post by dhaine_adp »
Dr. Claudio and Rathi,
Thank you very much for the new test version.
Danny
Manila, Philippines
