Quick Browse Form
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Quick Browse Form
Post by dragancesu »
Yes, you are right
Generator is simple and realize as an example of how the writing, when I wrote it I had no logical and memo fields in the table, it is easy to solve these two situations
For logial field should create CHECKBOX, the memo EDITBOX
quick.zip
(5.03 KiB) Downloaded 348 times
Hello Dragancesu,
I saw your example and I liked the way it fast and thought they could improve it and I thought making these changes, I hope not bother to modify your code!
First Step: Run the program.
Sedundo Step: Select the database.
Step Three: Surprise!
Fourth Step: Move F5 F9 Redimenciona control and control of the new window, enter the cursor over the control and press F5 or F9 and drag. You can also select a control in the Listbox_1 and then the property that is the lintbox_2 of the first window. Remember TimePicker and Button has BackColor or FontColor, if you do not give error. You can Resize the form.
Step Five: click the "Create" button
I hope you enjoy it !, it's a demo only. Any comments welcome!
El Archivo:
MicroIDE.rar
(1.07 MiB) Downloaded 468 times
Saludos! :D
Steed
Post by Steed »
Thanks for the adjusments, works nice
dragancesu wrote:Yes, you are right
Steed
Post by Steed »
WOW, Thanks for sharing Javier,
Javier Tovar wrote:
El Archivo:
MicroIDE.rar
Saludos! :D
Good thing you like Steed, I go !, upgrade just to improve the * .prg created!
MicroIDE.rar
(1.08 MiB) Downloaded 486 times
dragancesu
Bravo Javiar
Simple and effective
p.s. I think about how to make a real GUI as HMG IDE and I failed, but this will help me a lot, thanks
Have any idea how to do this to create a report?
Hi Javier Tovar
Nice creation
Quick Browse Form
bpd2000 wrote:Hi Javier Tovar
Nice creation
Javier, en algunos controles están demasiado pequeños.
Habria forma de incluir manipulacion de tamaños ?
dragancesu wrote:Bravo Javiar
Gragancesu,
Good thing you like!
Yes, you can make a report Choosing the fields that you want to print and give the width you want, I saw an example to print after a while you look for the league and the command to see if it helps.
Or as you imagine it would be?
Greetings.
