Quick Browse Form
dragancesu
DBs Used: DBF, MySQL, Oracle
Quick Browse Form
Post by dragancesu »
Today I did something that I needed, a simple generator forms with BROWSE control
Choose dbf and you will create a program, just compile
Simple, without images
quick.zip
(3.37 KiB) Downloaded 710 times
Quick Browse Form
Nice work and quick, Dragan !
Thanks for sharing ! :D
Codes generated.:
It's something like Extended Edit.
quartz565
Re: Quick Browse Form
Post by quartz565 »
Thank you Dragan Very nice !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nice
Steed
Post by Steed »
Thank, Dragan, but a small observatión when in a table there area other field types than "C","N","D", like ( Memo, Logical) the generator use the same type that the last field,
to be more clear:
Table_1: Name (C), Pos(N"),Date_("D"),Comen("Memo")
the quick generator makes:
Name "C"
Pos "N"
Date "D"
Comen "D"
Plese try whith this table \hmg\SAMPLES\Applications\CONTACTOS\CONTACTOS.dbf
Regards, Ed
Hello dragancesu
Very interesting application
I modified your code slightly from the COMBOBOX
and two different files are generated from a Option 1
or option 2
a greeting
Hola dragancesu
Muy interesante aplicación
He modificado un poco tu código desde el COMBOBOX
y se generan dos ficheros distintos desde una opción 1
o la opción 2
Un saludo
quickgenX.zip
(7.21 KiB) Downloaded 593 times
Good job, Dragan!
luisvasquezcl
Post by luisvasquezcl »
Dragancesu
Thanks for sharing your application seems very good idea your program.
Best regards
Dragancesu
gracias por compartir tu aplicación, me parece muy buena idea tu programa.
Saludos cordiales,
Luis Vasquez
Hi Dragan
Code generated using C:\hmg.3.4.0\SAMPLES\Controls\Grid\GRID_25\TEST.DBF file
following error
Steed
Post by Steed »
This error is caused by that I report in previus post, here, because the generartor takes in account only 3 types of fields ("D","N","C",) and when the field have other kind of data like Memo or logical, the generator use last type that have the previus field
bpd2000 wrote:Hi Dragan
following error
Steed wrote:Thank, Dragan, but a small observatión when in a table there area other field types than "C","N","D", like ( Memo, Logical) the generator use the same type that the last field,
to be more clear:
Name "C"
Pos "N"
Date "D"
Comen "D"
Regards, Ed
