Quick Browse Form
- dragancesu
Quick Browse Form
Today I did something that I needed, a simple generator forms with BROWSE control
Choose dbf and you will create a program, just compile
Simple, without images
- quick.zip
- (3.37 KiB) Downloaded 710 times
Quick Browse Form
Nice work and quick, Dragan !
Thanks for sharing !
Codes generated.: It's something like Extended Edit.
Re: Quick Browse Form
Thank you Dragan Very nice !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
Thank, Dragan, but a small observatión when in a table there area other field types than "C","N","D", like ( Memo, Logical) the generator use the same type that the last field,
to be more clear:
Table_1: Name (C), Pos(N"),Date_("D"),Comen("Memo")
the quick generator makes:
Name "C"
Pos "N"
Date "D"
Comen "D"
Plese try whith this table \hmg\SAMPLES\Applications\CONTACTOS\CONTACTOS.dbf
Regards, Ed
to be more clear:
Name "C"
Pos "N"
Date "D"
Comen "D"
Regards, Ed
- mustafa
Hello dragancesu
Very interesting application
I modified your code slightly from the COMBOBOX
and two different files are generated from a Option 1
or option 2
a greeting
Hola dragancesu
Muy interesante aplicación
He modificado un poco tu código desde el COMBOBOX
y se generan dos ficheros distintos desde una opción 1
o la opción 2
Un saludo
or option 2
a greeting
Hola dragancesu
o la opción 2
Un saludo
- quickgenX.zip
- (7.21 KiB) Downloaded 592 times
- luisvasquezcl
Dragancesu
Thanks for sharing your application seems very good idea your program.
Best regards
Dragancesu
gracias por compartir tu aplicación, me parece muy buena idea tu programa.
Saludos cordiales,
Luis Vasquez
Best regards
Dragancesu
Saludos cordiales,
Luis Vasquez
Hi Dragan
Code generated using C:\hmg.3.4.0\SAMPLES\Controls\Grid\GRID_25\TEST.DBF file
following error
following error
- quick_err.png (10.76 KiB) Viewed 11446 times
This error is caused by that I report in previus post, here, because the generartor takes in account only 3 types of fields ("D","N","C",) and when the field have other kind of data like Memo or logical, the generator use last type that have the previus field
bpd2000 wrote:Hi Dragan
following error
Steed wrote:Thank, Dragan, but a small observatión when in a table there area other field types than "C","N","D", like ( Memo, Logical) the generator use the same type that the last field,
to be more clear:
Name "C"
Pos "N"
Date "D"
Comen "D"
Regards, Ed
