HMG 3.3.1 (Stable)
Re: HMG 3.3.1 (Stable)
Javier Tovar wrote:le quiero poner BackColor a "NIL Default"
Do you put "NIL Default" ? Exactly like this ? (sorry seems silly question) :oops:
Sure !, Pablo César.
What I did twice, copy and "BuildAllLib"
It'S Okay?
Pablo César,
Direct IDE:
HMG 3.3.1 (Stable)
I use to rebuild with just the BuildLib.bat.
And As you can see recently I have compiled your code about transparency.
This errors happen at any DEMO at SAMPLES ? For example ?
HMG 3.3.1 (Stable)
Javier Tovar wrote:Direct IDE:
Ahhh sorry, now I know what about you said. It's just: Nil
Very strange. And if you take any DEMO or that code in my last message ?
Pablo César wrote:I use to rebuild with just the BuildLib.bat.
If Paul César,
It happens to me all who come in Samples Demos, even.
Maybe I'm missing something, not.
P.D .: I did now just "BuildLib.Bat".
HMG 3.3.1 (Stable)
Javier Tovar wrote:If Paul César,
Disculpame, te entendi nada... :oops:
Pablo César wrote:Dear Claudio, tell me please:
This _SetItem ( "Grid_2", "Form_1", nGridRow, {aTemp[1],"<Label in Blank>"} ) should it works ?
Because then I used : This.CellValue:="<Label in Blank>" and worked.
This in the function of validation at COLUMNVALID.
This is the function used in the validation:
#xtranslate This.CellValue := <arg> => _HMG_SetGridCellEditValue ( <arg> )
Thank you Claudio ! :D
Pablo César,
Si, me sucede también con los Demos que vienen en Samples.
Tal vez me estoy perdiendo algo, no sé lo que pasa, pero le quito esos dos archivos y todo bien! :)
saludos
P.D.:. Lo hice ahora con "BuildLib.Bat".
