HMG 3.3.1 (Stable)
HMG 3.3.1 - Posible BUG ( CellEx )
The property COLUMNVALID in Grid, makes a validation during the cell is still active. The problem I wish to change value of this cell in this validation function. But can't be changed... :(
You can see C:\hmg.3.3.1\SAMPLES\Controls\Grid\GRID_14\demo.prg and Test() function there, is not working... :(
But if you make the same test at C:\hmg.3.3.0\SAMPLES\Controls\Grid\GRID_14\demo.prg works normally !!!
I think there is a bug in GRID around _SetItem().
Please, someone can confirm this ? Can anybody make this test for me ?
Function Main()
Local aRows [20] [3]
	WIDTH 640 ;
	HEIGHT 400 ;
	TITLE 'Mixed Data Type Grid Test' ;
	DEFINE MAIN MENU
		DEFINE POPUP 'File'
			MENUITEM 'Exit'	ACTION ThisWindow.Release
		END POPUP
	END MENU
	aRows [1]	:= {'Simpson','Homer','555-5555'}
	aRows [2]	:= {'Mulder','Fox','324-6432'}
	aRows [3]	:= {'Smart','Max','432-5892'}
	aRows [4]	:= {'Grillo','Pepe','894-2332'}
	aRows [5]	:= {'Kirk','James','346-9873'}
	aRows [6]	:= {'Barriga','Carlos','394-9654'}
	aRows [7]	:= {'Flanders','Ned','435-3211'}
	aRows [8]	:= {'Smith','John','123-1234'}
	aRows [9]	:= {'Pedemonti','Flavio','000-0000'}
	aRows [10]	:= {'Gomez','Juan','583-4832'}
	aRows [11]	:= {'Fernandez','Raul','321-4332'}
	aRows [12]	:= {'Borges','Javier','326-9430'}
	aRows [13]	:= {'Alvarez','Alberto','543-7898'}
	aRows [14]	:= {'Gonzalez','Ambo','437-8473'}
	aRows [15]	:= {'Batistuta','Gol','485-2843'}
	aRows [16]	:= {'Vinazzi','Amigo','394-5983'}
	aRows [17]	:= {'Pedemonti','Flavio','534-7984'}
	aRows [18]	:= {'Samarbide','Armando','854-7873'}
	aRows [19]	:= {'Pradon','Alejandra','???-????'}
	aRows [20]	:= {'Reyes','Monica','432-5836'}
	@ 10,10 GRID Grid_1 ;
		WIDTH 620 ;
		HEIGHT 330 ;
		HEADERS {'Column 1','Column 2','Column 3'} ;
		WIDTHS {140,140,140} ;
		ITEMS aRows ;
		EDIT ;
		COLUMNVALID 	{ ;
				{ || Test() } , ;
				{ || NotBeEmpty(This.CellValue) } , ;
				{ || ! Empty ( This.CellValue ) } ;
CENTER WINDOW Form_1
Function NotBeEmpty ( cCellValue )  // Not working
If Empty(cCellValue)
   // This.CellValue:="<Is in blank>"
   nCellRowIndex := This.CellRowIndex
   nCellColIndex := This.CellColIndex
   Form_1.Grid_1.CellEx ( nCellRowIndex, nCellColIndex ) := "<Is in blank>"
Endif
Return .T.
Function Test()
If Empty (This.CellValue)
	This.CellValue := '*'  // Not working
EndIf
In the previous version 3.3.0 it's working, see at first column when we left empty what's happen:
In my PC the 3.3.1 is not working...
Re: HMG 3.3.1 (Stable)
For me, it is working on both the versions.
HMG 3.3.1 (Stable)
Rathinagiri wrote:For me, it is working on both the versions.
Thank you Rathi for your reply. Sorry to ask you about with basic question: but have you applied all patches (Upto Ptach 6) ?
Re: HMG 3.3.1 - Posible BUG ( CellEx )
Pablo César wrote:The property COLUMNVALID in Grid, makes a validation during the cell is still active. The problem I wish to change value of this cell in this validation function. But can't be changed... :(
Please, change INCLUDE\i_this.ch and SOURCE\h_grid.prg files for these new files, and rebuild the lib.
This_CellValue.rar
(19.99 KiB) Downloaded 467 times
HMG 3.3.1 (Stable)
srvet_claudio wrote:Please, change INCLUDE\i_this.ch and SOURCE\h_grid.prg files for these new files, and rebuild the lib.
Gracias Claudio !
It's working perfectly now !
HMG 3.3.1 (Stable)
Dear Claudio, tell me please:
This _SetItem ( "Grid_2", "Form_1", nGridRow, {aTemp[1],"<Label in Blank>"} ) should it works ?
Because then I used : This.CellValue:="<Label in Blank>" and worked.
This in the function of validation at COLUMNVALID.
Hola a todos
Después de sustituir los archivos el IDE no trabaja y en todos los archivos que quiero compilar con el IDE me sale este error.
Hello everyone
After replacing the IDE files does not work and all the files you want to compile with the IDE I get this error.
Y también me sucede lo mismo con Build.bat
Hola a todos,
Volví a poner Ultima versión de HMG, Ultimo Parche. sin los dos archivos anteriores.
También quiero informar que el control Slider cuando esta en un Tab y le quiero poner BackColor a "NIL Default" me da el siguiente error:
También probe con: CheckBox, RadioButtons, Label, TextBox y si funcionan bien. Solo Slider es el que da error. Alguna idea?
Hello everyone,
I replaced Release of HMG, Ultimo Patch. without the above two files.
I would also like to report that the Slider control when in one Tab and you want to put BackColor to "NIL Default" gives me the following error:
Also probe with: CheckBox, RadioButtons, Label, TextBox, and if they work well. Only Slider is giving error. Any ideas?
HMG 3.3.1 (Stable)
Javier, after replaced files, have you rebuilded HMG lib ?
