HMG 3.3.1 (Stable)
Re: HMG 3.3.1 (Stable)
Bonjour,Hi
depuis le patch4 au patch6 il y a apparition de cette erreur lors de la sauvegarde comme indiqué sur l'image.
since the patch4 patch6 there appear this error when saving as showning in the image.
- error_patch6.jpg (215.62 KiB) Viewed 6700 times
L'Algerie vous salut
Y.TABET
Y.TABET
from time to time, my app crases with error:
I don't know what's going on.
It's strange, because usually it works OK.
_HMG_GRIDINPLACEKBDEDIT_2(2082)
- srvet_claudio
I fixed.tonton2 wrote:Bonjour,Hi
- srvet_claudio
Marek when your app crashes, please post all info display in ErrorLog.Htm file.mol wrote:from time to time, my app crases with error:I don't know what's going on.Code: Select all
Bonjour,srvet_claudio wrote:I fixed.tonton2 wrote:Bonjour,Hi
Please ,I dont understand how you fixed it
merci beaucoup
Y.TABET
Y.TABET
I'm posting whole error message:srvet_claudio wrote:Marek when your app crashes, please post all info display in ErrorLog.Htm file.mol wrote:from time to time, my app crases with error:I don't know what's going on.Code: Select all
BASEobszar: TOWARY/1066 Nieprawidłowy argument: wymagany typ: logiczny
(b)MAIN(557)
EVENTS(2101)
DOMESSAGELOOP(0)
_ACTIVATEWINDOW(5534)
POPRAWDODAJTOWAR(730)
(b)OKNOTABTOWAROW_ONINIT(417)
_DOCONTROLEVENTPROCEDURE(5866)
EVENTS(814)
DOMESSAGELOOP(0)
TABELAREMANENT(2169)
(b)ZDEFINIUJMENUGLOWNE(1934)
EVENTS(1653)
DOMESSAGELOOP(0)
MAIN(567)
- srvet_claudio
Hi Marek,mol wrote:I'm posting whole error message:Code: Select all
BASEobszar: TOWARY/1066 Nieprawidłowy argument: wymagany typ: logiczny (b)MAIN(557) _HMG_GRIDINPLACEKBDEDIT_2(2082) EVENTS(2101) DOMESSAGELOOP(0) _ACTIVATEWINDOW(5534) POPRAWDODAJTOWAR(730) (b)OKNOTABTOWAROW_ONINIT(417) _DOCONTROLEVENTPROCEDURE(5866) EVENTS(814) DOMESSAGELOOP(0) _ACTIVATEWINDOW(5534) TABELAREMANENT(2169) (b)ZDEFINIUJMENUGLOWNE(1934) _DOCONTROLEVENTPROCEDURE(5866) EVENTS(1653) DOMESSAGELOOP(0) _ACTIVATEWINDOW(5534) MAIN(567)
the problem is in the Main function (line 557), it require a logical value and you pass another type of data.
PS: TOWARY is a data base or area alias?
Thanks Claudio for your answer!
I'll investigate my code. It's old codeblock for handle errors. There were no problems with this code until now. And now, it happens from time to time:
line 557: StObsBledu := ErrorBlock({|e| ObslBledu(e,StObsBledu)})
static function ObslBledu(ObiektBlad,StObsBledu)
local wybor, NazwaKart := "", cTrescWiadomosci
if ObiektBlad:GenCode == 20 .or. ObiektBlad:GenCode == 21
if !empty(ObiektBlad:OsCode)
if ObiektBlad:OsCode == 3
* brak kartoteki
NazwaKart := ObiektBlad:FileName
NazwaKart := substr(NazwaKart,1,rat(NazwaKart,"\")-1)
ObiektBlad:description := "Brak folderu: " + NazwaKart
if DirMake(NazwaKart) = 0
ObiektBlad:CanRetry := .t.
ObiektBlad:CanDefault := .t.
ObiektBlad:CanSubstitute := .t.
ObiektBlad:description := "Brak folderu"
return(ObiektBlad)
if ObiektBlad:GenCode == 25
* problemy z drukarką
do while .t.
wybor := Alert("Problemy z drukarką - włącz ON-LINE lub zasilanie",;
{"Ponów próbę","Bez wydruku"})
do case
case wybor == 1
if IsPrinter()
* set device to print
return(ObiektBlad)
case wybor == 2
break
otherwise
ObiektBlad:CanRetry := .f.
ObiektBlad:description := "Błąd drukarki"
exit
endcase
enddo
elseif ObiektBlad:GenCode == 32
break
cTrescWiadomosci := ZapiszBlad(.t.,ObiektBlad)
#ifndef Nie_Wysylaj_Maili
SendMail("Błąd w systemie Faktury wersja: "+WersjaProgramu,"NIP: "+F_NIP+eol+ DaneFirmy[6]+eol+ ;
WersjaProgramu + eol + cTrescWiadomosci,.t.)
#endif
* close databases
return eval(StObsBledu,ObiektBlad)
Good morningsrvet_claudio wrote:I fixed.tonton2 wrote:Bonjour,Hi
please Dr Claudio , You wrote that you have fixed that error, but I can't find where is the solution, or I didn't undestand what you wanted to say
Grand merci
Y.TABET
Y.TABET
I confirm existing of this error.tonton2 wrote:Bonjour,Hi
