HMG 3.3.1 (Stable)
tonton2
Re: HMG 3.3.1 (Stable)
Post by tonton2 »
Bonjour,Hi
depuis le patch4 au patch6 il y a apparition de cette erreur lors de la sauvegarde comme indiqué sur l'image.
since the patch4 patch6 there appear this error when saving as showning in the image.
L'Algerie vous salut
Y.TABET
from time to time, my app crases with error:
_HMG_GRIDINPLACEKBDEDIT_2(2082)
I don't know what's going on.
It's strange, because usually it works OK.
tonton2 wrote:Bonjour,Hi
I fixed.
mol wrote:from time to time, my app crases with error:
Marek when your app crashes, please post all info display in ErrorLog.Htm file.
tonton2
Post by tonton2 »
I fixed.
Bonjour,
Please ,I dont understand how you fixed it
merci beaucoup
Y.TABET
I'm posting whole error message:
BASEobszar: TOWARY/1066  Nieprawidłowy argument: wymagany typ: logiczny
(b)MAIN(557)
EVENTS(2101)
DOMESSAGELOOP(0)
_ACTIVATEWINDOW(5534)
POPRAWDODAJTOWAR(730)
(b)OKNOTABTOWAROW_ONINIT(417)
_DOCONTROLEVENTPROCEDURE(5866)
EVENTS(814)
DOMESSAGELOOP(0)
TABELAREMANENT(2169)
(b)ZDEFINIUJMENUGLOWNE(1934)
EVENTS(1653)
DOMESSAGELOOP(0)
MAIN(567)
mol wrote:I'm posting whole error message:
(b)MAIN(557)
EVENTS(2101)
DOMESSAGELOOP(0)
EVENTS(814)
DOMESSAGELOOP(0)
EVENTS(1653)
DOMESSAGELOOP(0)
MAIN(567)
Hi Marek,
the problem is in the Main function (line 557), it require a logical value and you pass another type of data.
PS: TOWARY is a data base or area alias?
Thanks Claudio for your answer!
I'll investigate my code. It's old codeblock for handle errors. There were no problems with this code until now. And now, it happens from time to time:
line 557: 	StObsBledu := ErrorBlock({|e| ObslBledu(e,StObsBledu)})
static function ObslBledu(ObiektBlad,StObsBledu)
        local wybor, NazwaKart := "", cTrescWiadomosci
        if ObiektBlad:GenCode == 20 .or. ObiektBlad:GenCode == 21
                if !empty(ObiektBlad:OsCode)
                        if ObiektBlad:OsCode == 3
                                * brak kartoteki
                                NazwaKart := ObiektBlad:FileName
                                NazwaKart := substr(NazwaKart,1,rat(NazwaKart,"\")-1)
                                ObiektBlad:description := "Brak folderu: " + NazwaKart
								if DirMake(NazwaKart) = 0
                                        ObiektBlad:CanRetry := .t.
                                        ObiektBlad:CanDefault := .t.
                                        ObiektBlad:CanSubstitute := .t.
										ObiektBlad:description := "Brak folderu"
                                        return(ObiektBlad)
        if ObiektBlad:GenCode == 25
                * problemy z drukarką
                do while .t.
                        wybor := Alert("Problemy z drukarką - włącz ON-LINE lub zasilanie",;
                                        {"Ponów próbę","Bez wydruku"})
                        do case
                                case wybor == 1
                                        if IsPrinter()
*                                               set device to print
                                                return(ObiektBlad)
                                case wybor == 2
                                        break
                                otherwise
                                        ObiektBlad:CanRetry := .f.
                                        ObiektBlad:description := "Błąd drukarki"
                                        exit
                        endcase
                enddo
        elseif ObiektBlad:GenCode == 32
                break
        cTrescWiadomosci := ZapiszBlad(.t.,ObiektBlad)
		#ifndef Nie_Wysylaj_Maili
		SendMail("Błąd w systemie Faktury wersja: "+WersjaProgramu,"NIP: "+F_NIP+eol+ DaneFirmy[6]+eol+ ;
			WersjaProgramu + eol + cTrescWiadomosci,.t.)
		#endif
*       close databases
 return eval(StObsBledu,ObiektBlad)
tonton2
Post by tonton2 »
I fixed.
Good morning
please Dr Claudio , You wrote that you have fixed that error, but I can't find where is the solution, or I didn't undestand what you wanted to say
Grand merci
Y.TABET
I confirm existing of this error.
