MySQL and HMG
Re: MySQL and HMG
For me it is working fine Sudip. I don't know where could be the error. :(
Can you send the back up of .sql file with some lines of data?
sudip
Re: MySQL and HMG
Post by sudip »
Hello Rathi,
I am sending some codes which will automatically create a database, Info and a table Accyr.
Now please add an accounting year in "Accounting Year" form by pressing Ctrl+A. Save it. Close the program and try to run the software again.
Please download
InfoSql.zip
(13.76 KiB) Downloaded 337 times
Please note that these codes are unfinished.
TIA.
With best regards.
Re: MySQL and HMG
Hi Sudip,
Please update the query function with the following code:
function sql(dbo1,qstr)
   local i, j
   local table := nil
   local currow := nil
   local tablearr := {}
   local rowarr := {}
   local curdateformat := set(_SET_DATEFORMAT)
   set date ansi
   table := dbo1:query(qstr)
   if table:neterr()
      msgstop(table:error())
      table:destroy()
      set(_SET_DATEFORMAT,curdateformat)
      return tablearr
      if table:lastrec() > 0
         asize(tablearr,0)
         for i := 1 to table:lastrec()
            asize(rowarr,0)
            currow := table:getrow(i)
            for j := 1 to table:fcount()
               aadd(rowarr,currow:fieldget(j))
               //msgbox(currow:fieldget(j))
            next j
	         aadd(tablearr,aclone(rowarr))
         next i
      table:destroy()
      return tablearr
return tablearr
sudip
Re: MySQL and HMG
Post by sudip »
Hi Rathi,
Thanks a lot! Problem is solved.
With best regards.
