HMG 3.3.1 (Stable)
Re: HMG 3.3.1 (Stable)
Pablo César wrote:I made this test:
Function Main()
MsgInfo(GetCurrentFolder())
This display the current folder. This ok.
But when I try with this:
Function Main()
cLogFile:=GetFile( { {'Error','*.log'},{'Build','*.log'} }, "Open building log error" ) /* need to be selected file at another folder */
Then I receive display of another folder (same it was choosen at GetFile), not displaying the current folder... :shock: :o
So I have to use cFilePath( ExeName() ) to ensure the correct result for el CurrentFolder. :(
I do not know if this behaviour is normal or it is a bug in GetFile function.
Is this normal Claudio ?
Hi Pablo,
GetFile ( acFilter ,
cTitle ,
cDefaultPath ,
lMultiSelect ,
lNoChangeDir , // for default is .F.
nFilterIndex ) --> SelectedFileName(s)
HMG 3.3.1 (Stable)
Function Main()
Function Main()
Hi Pablo,
cTitle ,
cDefaultPath ,
lMultiSelect ,
Thank you Claudio !
I've been omitting 4, 5 and 6 parameters and IMHO this 5th parameter should not be false as default, must be true.
More one item for missing info at hmgdoc.
mol wrote:My clients say my application is very slow after last release.
It's caused of GRID control, I think.
A lot of variants causes this control is slow. Maybe leak of memory? I can't find where real problem lays.
Is it the way to build simplified grid control to speed up browsing dbf tables?
Everything worked fine in hmg 3.2 or even 3.3.0.
I can't roll up to old hmg because of pdf generating.
Hi all,
change in SOURCE\c_grid.c (line 126):
ListView_SetExtendedListViewStyle ( hbutton, (hb_parl(9) ? 0 : LVS_EX_GRIDLINES) | LVS_EX_FULLROWSELECT | LVS_EX_DOUBLEBUFFER | LVS_EX_SUBITEMIMAGES );
for this line:
ListView_SetExtendedListViewStyle ( hbutton, (hb_parl(9) ? 0 : LVS_EX_GRIDLINES) | LVS_EX_FULLROWSELECT | LVS_EX_SUBITEMIMAGES );
and rebuild lib.
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
Subscribe to this thread and I tried to make this correction, but no such line
Can someone please put a link to the current version of HMG, which includes all patch?
Thanks
I've applied changes to hpg, rebuilt app and asked client for testing.
When I get response, I'll post about results.
Many thanks, Claudio!
dragancesu wrote:Subscribe to this thread and I tried to make this correction, but no such line
Thanks
You can download whole hmg 3.3.1 library with all patches from my ftp:
http://www.marekolszewski.info/hmg/hmg_20141218.zip
mol wrote:I found strange behaviour of virtual grid - OnQueryData is fired everytime when mouse moves over grid - without changing anything. Is it right?
Try this little sample:
* HMG Virtual Grid Demo
* (c) 2003 Roberto Lopez
	private nCounter := 0
		WIDTH 450 ;
		HEIGHT 400 ;
		TITLE 'Grid test' ;
		DEFINE MAIN MENU
		@ 10,10 GRID Grid_1 ;
		WIDTH 170 ;
		HEIGHT 330 ;
		HEADERS {'Column 1'} ;
		WIDTHS {140};
		VIRTUAL ;
		ITEMCOUNT 3 ;
		ON QUERYDATA QueryTest()
		@ 10,200 Label L1 ;
			Width 200 ;
			Height 20 ;
			value "Count of QueryData"
		@ 30,200 TEXTBOX Counter ;
			Width 100 ;
			Height 20 ;
			NUMERIC
			value 0
	CENTER WINDOW Form_1
Procedure QueryTest()
	This.QueryData := Str ( This.QueryRowIndex )
	//msgdebug("Row is: "+ Str ( This.QueryRowIndex ))
	Form_1.Counter.Value := ++nCounter
Hi Marek
Yes it is normal, it is the Window System that calls OnQuery "when necessary".
It's strange construction in my opinion, but, not for eliminating, I think
Hola a todos,
Quiero poner la propiedad transparente en el control RadioGroup y no lo logro.
Alguna idea?
Hello everyone,
I want to put the transparent property in the RadioGroup control and I fail.
Any ideas?
 * Copyright 2002-2008 Roberto Lopez <mail.box.hmg@gmail.com>
 * http://www.hmgforum.com//
      WIDTH 640 HEIGHT 480 ;
      TITLE 'HMG Demo' ;
      ICON 'DEMO.ICO' ;
      MAIN ;
      BACKCOLOR BLUE;
      FONT 'Arial' SIZE 10
      DEFINE MAIN MENU
         POPUP 'M&isc'
            ITEM 'Set RadioGroup 1 ReadOnly Property To {.T.,.T.,.T.,.T.}'   ACTION Form_1.Radio_1.ReadOnly := { .T. , .T. , .T. , .T. }
            ITEM 'Set RadioGroup 1 ReadOnly Property To {.F.,.F.,.F.,.F.}'   ACTION Form_1.Radio_1.ReadOnly := { .F. , .F. , .F. , .F. }
            ITEM 'Set RadioGroup 1 ReadOnly Property To {.F.,.T.,.F.,.T.}'   ACTION Form_1.Radio_1.ReadOnly := { .F. , .T. , .F. , .T. }
            SEPARATOR
            ITEM 'Set RadioGroup 2 ReadOnly Property To {.T.,.T.,.T.,.T.}'   ACTION Form_1.Radio_2.ReadOnly := { .T. , .T. , .T. , .T. }
            ITEM 'Set RadioGroup 2 ReadOnly Property To {.F.,.F.,.F.,.F.}'   ACTION Form_1.Radio_2.ReadOnly := { .F. , .F. , .F. , .F. }
            ITEM 'Set RadioGroup 2 ReadOnly Property To {.T.,.T.,.T.,.T.}'   ACTION Form_1.Radio_2.ReadOnly := { .F. , .T. , .F. , .T. }
            SEPARATOR
            ITEM 'Get RadioGroup 1 ReadOnly Property'   ACTION MsgInfo ( LogicalArrayToString ( Form_1.Radio_1.ReadOnly ) )
            ITEM 'Get RadioGroup 2 ReadOnly Property'   ACTION MsgInfo ( LogicalArrayToString ( Form_1.Radio_2.ReadOnly ) )
         END POPUP
      END MENU
      DEFINE RADIOGROUP Radio_1
         OPTIONS   { 'One' , 'Two' , 'Three', 'Four' }
         VALUE   1
         WIDTH   100
         TOOLTIP   'RadioGroup'
         READONLY { .F. , .T. , .F. , .T. }
         ROW   10
         COL   10
         TRANSPARENT .T.
      END RADIOGROUP
      DEFINE RADIOGROUP Radio_2
         ROW 10
         COL 150
         VALUE 1
         WIDTH 100
         TRANSPARENT .T.
         HORIZONTAL .T.
      END RADIOGROUP
      @ 150,10 DATEPICKER Date_1 ;
      VALUE CTOD('  / /  ') ;
      TOOLTIP 'DatePicker Control'
   Form_1.date_1.SetFocus
   Form_1.Center
   Form_1.Activate
Function LogicalArrayToString ( lArray )
Local RetVal := '{ ' , I
   For I := 1 To Len ( lArray )
      If lArray [I]
         RetVal := RetVal + ' ".T." '
      Else
         RetVal := RetVal + ' ".F." '
      EndIf
   Next I
Return RetVal + ' }'
Modify: C:\hmg.3.3.1\SAMPLES\Controls\RadioGroup\RADIOGROUP_5
Hola a todos,
Estoy tratando de cambiar el color de fondo y la letra de un TextBox en tiempo de ejecución, el control tiene la propiedad "ReadOnly .T." y no lo logro. :(
		CASE nOpcion = 6
			ColorGets := aColorSelect
			Colores.TextBox_3.ReadOnly := .F.
*			Colores.TextBox_3.DisabledFontColor := aColorSelect
			SetProperty ( 'Colores' , 'TextBox_3' , 'DisabledFontColor' , aColorSelect )
			Colores.TextBox_3.ReadOnly := .T.
			Actualiza()
		CASE nOpcion = 7
			SetProperty ( 'Colores' , 'TextBox_3' , 'DisabledBackColor' , aColorSelect )
			Actualiza()
Tambien observo que si utilizo la sentencia:
Me da el siguiente error:
C:\hmg.3.3.1\Mios\Colores\Main.Prg(1148) Error E0030  Syntax error "syntax error at '.'"
1 error
Tambien observo que el textbox en su información de control tiene:
DEFINE TEXTBOX <Controlname>
READONLY <lValue>
DISABLEDBACKCOLOR <aDisabledBackColor>
DISABLEDFONTCOLOR <aDisabledFontColor>
END TEXTBOX
y que sus propiedades tiene:
     - FontColor
      - DisabledBackColor
      - DisabledFontColor
      - CaretPos
      - ReadOnly
      - Name (R)
      - TabStop (D)
      - Field (D)
      - Parent (D)
      - InputMask (D)
      - Format (D)
      - MaxLength (D)
      - RightAlign (D)
      - HelpId (D)
      - CaseConvert (D)
      - DataType (D)
Las cuales: ReadOnly, DisabledBackColor y DisabledFontColor se pueden cambiar en tiempo de ejecución y no lo hace.
Tambien observo que la documentación para ReadOnly no es clara, solo tiene:
Syntax:
ReadOnly <lValue>
Lo cual intuyo yo que debería ser:
Syntax:
ReadOnly  <lValue> (Control Definition)
<WindowName>.<ControlName>.ReadOnly :=  lValue
<WindowName>.<ControlName>.ReadOnly -->  lValue
This should be specified as a three element numeric array containing red, green and blue components.
Y también la propiedad: DisabledBackColor tiene el mismo problema.
Syntax:
DisabledBackColor <anColor>
Must be specified as a three elements numeric array containing red, green and blue components
Se que es mucho trabajo, es un trabajo gigante, pero creo en mi humilde opinión, se debería avanzar concluyendo con cosas solidas, ya que me desanimo en seguir mi proyecto teniendo tantos tropiezos, yo creo que ya no deberían de existir estas cosas sin resolver o solo a mi me pasa?, acabo de revisar máquina, volvi a cargar HMG y último parche y todo igual.
P.D.: Y no lo digo solo por mi, sino por todos los que empezamos con HMG.
Hello everyone,
I'm trying to change the background color and font of a TextBox at run time, the control has the property "ReadOnly .T." and I fail. :(
CASE nOpcion = 6
ColorGets: = aColorSelect
Colores.TextBox_3.ReadOnly: = .F.
* Colores.TextBox_3.DisabledFontColor: = aColorSelect
SetProperty ('Colors', 'TextBox_3', 'DisabledFontColor' aColorSelect)
Colores.TextBox_3.ReadOnly: = .T.
Refresh ()
CASE nOpcion = 7
SetProperty ('Colors', 'TextBox_3', 'DisabledBackColor' aColorSelect)
Refresh ()
Also I notice that if I use the sentence:
I get the following error:
C:\hmg.3.3.1\Mios\Colors\Main.prg (1148) E0030 Error Syntax error "syntax error at '.'"
1 error
I also note that the textbox in its control information is:
   DEFINE TEXTBOX <controlname>
             READONLY <lValue>
              DisabledBackColor <aDisabledBackColor>
   END TEXTBOX
and that their properties have:
 - FontColor
       - DisabledBackColor
       - DisabledFontColor
       - caretPos
       - ReadOnly
       - Name (R)
       - TabStop (D)
       - Field (D)
       - Parent (D)
       - InputMask (D)
       - Format (D)
       - MaxLength (D)
       - RightAlign (D)
       - HelpID (D)
       - CaseConvert (D)
       - DataType (D)
Which: ReadOnly, DisabledFontColor DisabledBackColor and can be changed at runtime and does not.
I also note that the documentation for ReadOnly is unclear, simply:
 Syntax:
ReadOnly <lValue>
Which I can sense it should be:
 Syntax:
<WindowName> <ControlName> .ReadOnly:. = lValue
<WindowName> <ControlName> .ReadOnly -.> lValue
This should be specified as a numeric array element container containing three red, green and blue components.
And the property: DisabledBackColor has the same problem.
 Syntax:
Must be specified as a numeric array elements container containing three red, green and blue components
I know it's hard work, is a giant work, but I believe in my humble opinion, should move concluding with solid things because I get discouraged to continue my project having so smoothly, I think it does not should be these things unresolved or only happens to me ?, I just checked machine turned refresh HMG and last patch and all the same.
PS: And do not say just for me but for all those who started with HMG.
Hi Friends,
please test the GRID behavior with this new patch (is more fast):
HMG.3.3.1_patch6.rar
(2.5 MiB) Downloaded 627 times
