HMG 3.3.1 (Stable)
tonton2
Re: HMG 3.3.1 (Stable)
Post by tonton2 »
Bonsoir tout le monde,
in the new compilation it appears the following errors
C:\hmg.3.3.1\24_09_2014_GESTION_HMG\gestion_reelle1\gestion.prg:847:0: warning: "_WIN32_WINNT" redefined [enabled by default]
c:\hmg.3.3.1\mingw\bin\../lib/gcc/mingw32/4.6.2/../../../../include/windef.h:20:0: note: this is the location of the previous definition
C:/hmg.3.3.1/lib/libhmg.a(c_windows.o):c_windows.c:(.text+0x1ff0): multiple definition of `HB_FUN_GETDESKTOPREALTOP'
C:/Users/youcef/AppData/Local/Temp/hbmk_74o42l.dir/gestion.o:gestion.c:(.text+0x990): first defined here
C:/hmg.3.3.1/lib/libhmg.a(c_windows.o):c_windows.c:(.text+0x2030): multiple definition of `HB_FUN_GETDESKTOPREALLEFT'
C:/Users/youcef/AppData/Local/Temp/hbmk_74o42l.dir/gestion.o:gestion.c:(.text+0x9d0): first defined here
C:/hmg.3.3.1/lib/libhmg.a(c_windows.o):c_windows.c:(.text+0x2070): multiple definition of `HB_FUN_GETDESKTOPREALWIDTH'
C:/Users/youcef/AppData/Local/Temp/hbmk_74o42l.dir/gestion.o:gestion.c:(.text+0xa10): first defined here
C:/hmg.3.3.1/lib/libhmg.a(c_windows.o):c_windows.c:(.text+0x20b0): multiple definition of `HB_FUN_GETDESKTOPREALHEIGHT'
C:/Users/youcef/AppData/Local/Temp/hbmk_74o42l.dir/gestion.o:gestion.c:(.text+0xa50): first defined here
hbmk2[gestion]: Error: Running linker. 1
gcc.exe C:/Users/youcef/AppData/Local/Temp/hbmk_74o42l.dir/gestion.o
Merci beaucoup pour le travail que vous fournissez
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
tonton2 wrote:Bonsoir tout le monde,
In your file gestion.c eliminates the functions GETDESKTOPREALTOP, GETDESKTOPREALLEFT, GETDESKTOPREALWIDTH and GETDESKTOPREALHEIGHT, these functions are parts of HMG.
HMG 3.3.1 (Stable)
srvet_claudio wrote:..//.. the functions GETDESKTOPREALTOP, GETDESKTOPREALLEFT, GETDESKTOPREALWIDTH and GETDESKTOPREALHEIGHT, these functions are parts of HMG.
That's means you have already implemented synthesized way for windows creation in full screen by default ?
In other words, now we can just to DEFINE WINDOW without row, col, width and height parameters then it will be considered at full screen windowed according Desktop sizes.
Once again, thanks Claudio !
Thank you Dr. Claudio for nice improvement, it is really simplified
tonton2
Post by tonton2 »
merci beaucoup Dr Claudio
Y.TABET
Thanks Claudio !
My clients say my application is very slow after last release.
It's caused of GRID control, I think.
A lot of variants causes this control is slow. Maybe leak of memory? I can't find where real problem lays.
Is it the way to build simplified grid control to speed up browsing dbf tables?
Everything worked fine in hmg 3.2 or even 3.3.0.
I can't roll up to old hmg because of pdf generating.
I found strange behaviour of virtual grid - OnQueryData is fired everytime when mouse moves over grid - without changing anything. Is it right?
Try this little sample:
* HMG Virtual Grid Demo
* (c) 2003 Roberto Lopez
	private nCounter := 0
		WIDTH 450 ;
		HEIGHT 400 ;
		TITLE 'Grid test' ;
		DEFINE MAIN MENU
		@ 10,10 GRID Grid_1 ;
		WIDTH 170 ;
		HEIGHT 330 ;
		HEADERS {'Column 1'} ;
		WIDTHS {140};
		VIRTUAL ;
		ITEMCOUNT 3 ;
		ON QUERYDATA QueryTest()
		@ 10,200 Label L1 ;
			Width 200 ;
			Height 20 ;
			value "Count of QueryData"
		@ 30,200 TEXTBOX Counter ;
			Width 100 ;
			Height 20 ;
			NUMERIC
			value 0
	CENTER WINDOW Form_1
Procedure QueryTest()
	This.QueryData := Str ( This.QueryRowIndex )
	//msgdebug("Row is: "+ Str ( This.QueryRowIndex ))
	Form_1.Counter.Value := ++nCounter
mol wrote:I found strange behaviour of virtual grid - OnQueryData is fired everytime when mouse moves over grid - without changing anything. Is it right?
		WIDTH 450 ;
		HEIGHT 400 ;
		TITLE 'Grid test' ;
		DEFINE MAIN MENU
		WIDTH 170 ;
		HEIGHT 330 ;
		WIDTHS {140};
		VIRTUAL ;
		ITEMCOUNT 3 ;
		@ 10,200 Label L1 ;
			Width 200 ;
			Height 20 ;
			Width 100 ;
			Height 20 ;
			NUMERIC
			value 0
Hi Marek
Yes it is normal, it is the Window System that calls OnQuery "when necessary".
mol wrote:My clients say my application is very slow after last release.
You can send me (srvet@adinet.com.uy) a small example with a large database.
HMG 3.3.1 (Stable)
I made this test:
Function Main()
MsgInfo(GetCurrentFolder())
This display the current folder. This ok.
But when I try with this:
Function Main()
cLogFile:=GetFile( { {'Error','*.log'},{'Build','*.log'} }, "Open building log error" ) /* need to be selected file at another folder */
Then I receive display of another folder (same it was choosen at GetFile), not displaying the current folder... :shock: :o
So I have to use cFilePath( ExeName() ) to ensure the correct result for el CurrentFolder. :(
I do not know if this behaviour is normal or it is a bug in GetFile function.
Is this normal Claudio ?
