SET TOOLTIPBACKCOLOR
the command SET TOOLTIPBACKCOLOR {255,255,0} with win7 64-bit does not work !! While on win xp works .There is also to you?
does not take the desired color
I tried in Win7 32 bits thru this code and worked for me normally.
May you test it in your Win7 at 64 bits ?
Also can you inform with HMG version are you using ? Unicode /ANSI ?
Re: SET TOOLTIPBACKCOLOR
I used version is 'HMG 3.3.1' and compiled 32-bit --
Have you tested with that code I passed ?
W7-32 BITS HMG331 OK!
Win7, 32 bits, HMG3.3.1 No trabaja, Unicode
P.D., Ya recompile libreria y nada.
Win7, 32-bit, HMG3.3.1 not work, Unicode
P. D., Ya library and recompile anything.
SET NAVIGATION EXTENDED
SET EPOCH TO 2000
SET CENTURY ON
SET DATE FRENCH
SET TOOLTIPSTYLE BALLOON
SET TOOLTIPBACKCOLOR {255,0,0}
WIDTH 640 HEIGHT 480 ;
TITLE 'HMG Demo' ;
DEFINE MAIN MENU
DEFINE POPUP 'Test'
MENUITEM 'Set Text_1 Value' ACTION Form_1.Text_1.Value := Date()
MENUITEM 'Set Text_2 Value' ACTION Form_1.Text_2.Value := ctod (' / / ')
MENUITEM 'Set Text_3 Value' ACTION Form_1.Text_3.Value := ctod('01/01/2005')
MENUITEM 'Set Text_1 ReadOnly' ACTION Form_1.Text_1.ReadOnly := .T.
MENUITEM 'Clear Text_1 ReadOnly' ACTION Form_1.Text_1.ReadOnly := .F.
SEPARATOR
MENUITEM 'Get Text_1 Value' ACTION MsgInfo ( dtoc ( Form_1.Text_1.Value ) )
MENUITEM 'Get Text_2 Value' ACTION MsgInfo ( dtoc ( Form_1.Text_2.Value ) )
MENUITEM 'Get Text_3 Value' ACTION MsgInfo ( dtoc ( Form_1.Text_3.Value ) )
END POPUP
END MENU
@ 10,10 TEXTBOX Text_1 ;
VALUE ctod('01/01/2004') ;
TOOLTIP 'Date TextBox 1' ;
DATE
@ 40,10 TEXTBOX Text_2 ;
VALUE Date() ;
TOOLTIP 'Date TextBox 2' ;
DATE
DEFINE TEXTBOX Text_3
ROW 70
COL 10
DATE .T.
END TEXTBOX
Form_1.Center
Form_1.Activate
Pablo César excuse but I do not know how to enter your code and the example of Javier Tovar does not work to me
Please note hereunder quite same Javier's sample code:emzampi wrote:Pablo César excuse but I do not know how to enter your code and the example of Javier Tovar does not work to me
#define WM_USER 0x0400
#define TTM_SETTIPBKCOLOR (WM_USER + 19)
#define TTM_SETTIPTEXTCOLOR (WM_USER + 20)
Function Main()
// SET TOOLTIPSTYLE STANDARD
// SET TOOLTIPBACKCOLOR {255,255,0}
TITLE 'HMG Demo' ;
DEFINE MAIN MENU
DEFINE POPUP 'Test'
SEPARATOR
END POPUP
END MENU
DATE
VALUE Date() ;
DATE
ROW 70
COL 10
TOOLTIP 'Date TextBox 3'
DATE .T.
END TEXTBOX
CENTER WINDOW Form_1
SendMessage( GetFormToolTipHandle("Form_1"), TTM_SETTIPBKCOLOR, RGB(255,255,0), 0 )
SendMessage( GetFormToolTipHandle("Form_1"), TTM_SETTIPTEXTCOLOR, RGB(0,92,233), 0 )
Return NilJavier, puedes probarlo tambien ? Aqui a mi me funciona.Javier Tovar wrote:Win7, 32 bits, HMG3.3.1 No trabaja, Unicode
I guess this Tooltips doesn't take effects when your Windows has Appearance changed, for example AERO style doesn't work.
In my test, my Windows is setted default (not customed style, Classic one).
Estimado Claudio, todo indica que es algo a más que se debe ajustar para no sufrir interferencia del SO. Lo que pude leer es que existe la propiedad OwnerDraw, porque hé visto vários código que se utilizan asi como este y dá cierto:
http://www.codeproject.com/Articles/420 ... th-Image-C
Testeé este ejemplo y mismo personalizando la apariencia del Windows, funciona igual.
- CustomToolTipDemo.zip
- (354.13 KiB) Downloaded 352 times
