The problem was introduced in patch 3, I will investigate.srvet_claudio wrote:Hi Marek,mol wrote:I've installed and compiled Patch 4 - there is still a problem with PDF generation.
I've tested with my app and sample HMG\SAMPLES\HPDF\HMG_HPDF\DEMO and built application throws an error: Can not start new page. | HB_HPDF_INVALID | StartPage and Can not create Page Outline
I must revert to Patch 2
you're right !!!
It's very weird because I did not make any changed in HPDF in any of the patches![]()
HMG 3.3.1 (Stable)
- srvet_claudio
Re: HMG 3.3.1 (Stable)
- srvet_claudio
I fixed, the problem was the load of TTF fonts.mol wrote:I've installed and compiled Patch 4 - there is still a problem with PDF generation.
Please unzip this file in \Source and rebuild.
srvet_claudio wrote:It's very weird because I did not make any changed in HPDF in any of the patches
I'm becoming an old man and forgotten,srvet_claudio wrote:The problem was introduced in patch 3
apparently I mixed versions of source code.
PS: I love the patches for detect bugs !!!
- h_HMG_HPDF.rar
- (10.01 KiB) Downloaded 515 times
Thanks!
I'll try to install patch and test it!
Merci a tous
It's working very good
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
Gracias Dr. Claudio
Excelente trabajo
Excelente trabajo
- srvet_claudio
Hi Friends.
Please test this patch the last minute.
See this demo:SET TOOLTIPCUSTOMDRAW ON|OFF --> For default ToolTip Custom Draw is OFF
SET TOOLTIPCUSTOMDRAW TO <lOn>
ToolTipCustomDrawIsActive() --> lBoolean
SET TOOLTIPCUSTOMDRAW CONTROL <ControlName> OF <ParentName> [ BACKCOLOR <aBackColor> ] [ FORECOLOR <aForeColor> ] [ ARRAYFONT <aFont> ] [ BALLOON <lBalloon> ]
SET TOOLTIPCUSTOMDRAW CONTROL <ControlName> OF <ParentName> --> Remove tooltip custom draw of the control
Note:
aFont := ARRAY FONT <cFontName> SIZE <nFontSize> [ BOLD ] [ ITALIC ] [ UNDERLINE ] [ STRIKEOUT ] --> { cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout }
aFont := CREATE ARRAY FONT <cFontName> SIZE <nFontSize> [ BOLD <lBold> ] [ ITALIC <lItalic> ] [ UNDERLINE <lUnderline> ] [ STRIKEOUT <lStrikeout> ] --> { cFontName, nFontSize, lBold, lIitalic, lUnderline, lStrikeout }
PRIVATE lOnToolTipCustomDraw := .T.
SET TOOLTIPSTYLE BALLOON
SET TOOLTIPFORECOLOR BLUE
SET TOOLTIPCUSTOMDRAW TO lOnToolTipCustomDraw // For default ToolTip Custom Draw is OFF
DEFINE WINDOW Form_1 MAIN
@ 200,250 LABEL Label_1 ;
AUTOSIZE ;
VALUE 'Click me On/Off TOOLTIP Custom Draw!' ;
ACTION SetOnOff();
FONT 'Arial' SIZE 24;
TOOLTIP "ToolTip Label 1"
@ 50,50 LABEL Label_2 ;
AUTOSIZE ;
VALUE 'Hello HMG World' ;
TOOLTIP "ToolTip Label 2 of Form_1"
@ 150,50 LABEL Label_3 ;
AUTOSIZE ;
VALUE 'Label with Default ToolTip' ;
TOOLTIP "ToolTip Default"
aFont := ARRAY FONT "Arial" SIZE 12 BOLD UNDERLINE
SET TOOLTIPCUSTOMDRAW CONTROL Label_1 OF Form_1 FORECOLOR RED ARRAYFONT aFont
aFont := ARRAY FONT "Times New Roman" SIZE 10 BOLD ITALIC
SET TOOLTIPCUSTOMDRAW CONTROL Label_2 OF Form_1 ARRAYFONT aFont BALLOON .F.
// SET TOOLTIPCUSTOMDRAW CONTROL Label_1 OF Form_1 // Remove tooltip custom draw of the control
PROCEDURE SetOnOff
lOnToolTipCustomDraw := .NOT. lOnToolTipCustomDraw
MsgInfo ({"ToolTip Custom Draw is: ", ToolTipCustomDrawIsActive ()})
- HMG.3.3.1_Patch5.rar
- (2.47 MiB) Downloaded 547 times
Wow doctor ! You are great !!!
All is working perfect ! Very nice all improvements, with different ToolTips ! Genial !
Thank you very much, genius !!
Thank you Claudio !
Thank you Claudio !
- srvet_claudio
Hi Friends,
I fixed a bug reporter in patch 5 (viewtopic.php?f=36&t=4078&start=20#p38506)
Please substitute patch 5 for this patch (patch 5b).
- HMG.3.3.1_Patch5b.rar
- (2.47 MiB) Downloaded 594 times
Gracias Dr. Claudio Soto por su ayuda siempre!
