ActiveX experiments
Re: ActiveX experiments
Agil Abdullah wrote: I Don't speak Spanish/Portugese, could you explain what you were discussing?... Thanks
an error happens in line 35 of the example posted ..
My machine has Windows 7 Home Premium 64 HMG.3.3.1 patch 3.
Hay un error en la linea 35, no logra compilar bien!
Win 7, 32Bits, HMG.3.3.1, patch 3.
Postby andyglezl » Tue Nov 11, 2014 7:11 pm
guiado por la lógica, creo que se deberá tener instalado el FLASH PLAYER, IEXPLORER y OFFICE
para poder probarlo.
guided by logic, I think you should have installed FLASH PLAYER, IEXPLORER and OFFICE to try.
Hola Javier, si tienes instalado el Office (de Microsoft) ? creo que va a ser un requerimiento para utilizar en este caso
el control ActiveX.
Hi Javier, if you have installed the Office (from Microsoft)? I think it will be a requirement to use in this case
ActiveX control.
Postby andyglezl » Tue Nov 11, 2014 7:30 pm
Demo.ACTIVEX.rar
(471.46 KiB) DOWNLOADED 36 times :?
Y es que sin retroalimentacion, uno puede imaginarse muchas cosas pero cada configuración en cada
computadora es diferente. No se, si no es de interés para muchos o no es lo que esperan.
En fin ...
And is that without feedback, one can imagine many things but each configuration in each
computer is different. There is, if not of interest to many or not what they expect.
Anyway ...
Gracias Agil !
Thanks Agil !
Agil Abdullah
Post by Agil Abdullah »
DANIEL thanks...
ANDY thanks...
Interesting discussion. We indonesians only know the words "bravo" , "amigo", "gracia", "gooool", "Saludos".
When using android , very hard to call Google-translate.
SALUDOS
Programmer Never Surrender
el control ActiveX.
ActiveX control.
Si tengo instalado Office 2010 de microsoft!
If I have installed Microsoft Office 2010!
Por lo que leí, debe de existir el archivo "richtx32.ocx" en c:\windows\system32
de lo contrario habrá que conseguirlo y registrarlo: Regsvr32 c:\windows\system32\richtx32.ocx
Yo no recuerdo haber hecho esto, por eso asumo que al instalar el Oficce se instaló.
From what I read, you should have the "richtx32.ocx" file in c: \ windows \ system32
otherwise we will have to get it and register: Regsvr32 c: \ windows \ system32 \ richtx32.ocx
I do not remember doing this, so I assume that installing Oficce installed.
andyglezl wrote:...
Ask to Google :
http://www.ocxme.com/ocx/files/richtx32_ocx.html
There are many more.
Caution : .ocx's are dangerous :mrgreen:
Addendum :
or better :
http://support.microsoft.com/kb/165437
TIA
OK Andy,
Resuelto, primero baje el archivo de esta dirección:
http://www.opendll.com/index.php?file-d ... =6.1.97.82
Después en el simbolo del sistema escribí esto para registrarlo en Windows:
regsvr32 c:/windows/system32/RICHTX32.OCX
Y ya se compilo sin problemas!
OK Andy,
Resolved, first download the file from this address:
After the symbol I wrote this system to register it in Windows:
regsvr32 c: /windows/system32/RICHTX32.OCX
And I will compile without problems!
