Facing Android Development
Re: Facing Android Development
Roberto Lopez wrote: ...
In the case that I find enough time to create the translator to 'sugarize' the client syntax, you should give it a try.
Thanks; very good news :!:
Everybody likes sugar :)
With my best regards :)
Thanks Roberto,
As I'm not at home I only read new messages. When I'm back home I'll give it a look!
Roberto,
I could not resist a quick try... Compiling (build test.prg) gives an error.. can't find....
Compiling build test (without .prg) is OK.
Hi all
Does anyone think to sell their old Android machine to me ? :lol:
serge_girard wrote:Roberto,
Is working here... what is exactly the error message?
Roberto,
This is the error when trying to compile with (build test.prg):
Harbour 3.2.0dev (r1312192324)
Copyright (c) 1999-2013, http://harbour-project.org/
Compiling 'TEST.PRG'...
Lines 9, Functions/Procedures 1
Generating C source output to 'C:\Users\GEBRUI~1\AppData\Local\Temp\hbmk_n7spfs.
dir\TEST.c'... Done.
Het systeem kan het opgegeven bestand niet vinden.	(The system can't find the file.. or something)
Druk op een toets om door te gaan. . .(Press any key to continue)
Build test (without .prg) is giving "1 file is replaced (or something like that) " os this is OK and it will probably be a path-error or something?
Regards Serge
One file for client side and one file for server side.
The client is HTML and the server is Harbour.
I'm sure that using your own app in a phone is an enough reward :)
Hola
Parece prometedor, espero ansioso algunos ejemplos para probar ! Gracias.
hi
Looks promising, I look forward examples to test examples! Thanks.
Roberto,
I did some tests with HMG/WEB Alpha 012 + NETIO.
HMG + NETIO works fine but combining with HMG/WEB Alpha 012 gives an runtime-error:
TEST.cgi - Entrypoint not found
Unable to find entrypoint of procedure hb_fileRegister in DLL-file harbour-32.dll
What I did:
1) HMG app with NETIO (See Connect_NetServer() and USERSDBF()... : works OK
2) Server application with several queries (see Q_USERS()) which are called from HMG app: works OK
3) Index.html with TEST.CGI which calls also Server-app-query Q_USERS: gives runtime-error.
4) Index.html with TEST.CGI which has a copy of Q_USERS: works OK.
So I can't get NETIO working with CGI. Harbour-32.dll is located in the same folder as the CGI modules.
Any idea how to fix this?
See source-snippets:
PRG-CGI module
/* build.bat :
@ECHO OFF
CLS
SET HBPATH=C:\harbour\bin
SET HMGINCPATH=c:\hmgweb\include
SET APACHECGIPATH=c:\hmgweb\apache\cgi-bin
%HBPATH%\hbmk2 %1 -i%HMGINCPATH% hbmysql.hbc hbmisc.hbc hbnetio.hbc hbct.hbc -shared
IF ERRORLEVEL 0 MOVE %1.exe %APACHECGIPATH%\%1.cgi
// TEST.PRG --> TEST.CGI   ------------------------------------------------------
#include "error.ch"
#include "common.ch"
#require "hbnetio"
REQUEST HB_GT_CGI_DEFAULT
REQUEST HB_GT_WIN_DEFAULT
FUNCTION MAIN()
LOCAL	 aQuery				:= {}
PUBLIC cNetServer       := '127.0.0.1'          // local server or any addres (even Internet)
PUBLIC nNetPort         := 2941                 // you can choose any you want
PUBLIC cNetPass         := 'something_secret'   // Idem
PUBLIC _HMG_SYSDATA_		[ 32 ]
cQUERY	:= getvalue("url")
cWHERE	:= getvalue("where")
// requested query existing eg: Q_USERS
IF !Connect_NetServer()
	xSUR_NAME		:= ''
	xFAM_NAME		:= ''
	aQuery			:= netio_funcexec( cQUERY, cWHERE )
   xSUR_NAME		:= ALLTRIM(aQuery[1] [1] )
   xFAM_NAME		:= ALLTRIM(aQuery[1] [2] )
	netio_disconnect( cNetServer , nNetPort )
OutStd( "Content-type: text/html" + hb_OSNewLine() + hb_OSNewLine() )
OutStd( '<br> ' )
OutStd( xSUR_NAME + ' ' + xFAM_NAME + '<br> ' )
/* ok
aAr := Q_USERS()
xSUR_NAME		:= ALLTRIM(aAr [1] [1] )
xFAM_NAME		:= ALLTRIM(aAr [1] [2] )
OutStd( '<br> ' )
OutStd( xSUR_NAME + ' ' + xFAM_NAME + '<br> ' ) */
FUNCTION Connect_NetServer()
LOCAL c_STR_Con := "net:"
lConnect    := netio_connect( cNetServer , nNetPort ,, cNetPass, 9 )
IF .Not. lConnect
   RETURN .F.
RETURN .T.
HMG App
IF .Not. lConnect
   RETURN .F.
RETURN .T.
FUNCTION USERSDBF()
cWHERE := ''
	xSUR_NAME		:= ''
	xFAM_NAME		:= ''
	aQuery			:= netio_funcexec( 'Q_USERS', cWHERE )
MSGINFO(xSUR_NAME, 'xSUR_NAME')
SERVER Function
/* Q_USERS is located within HMGSERVERIO.PRG                             */
/* When calling netio_funcexec( 'Q_USERS', '' ) from a HMG Application   */
/* (function USERSDBF) this works fine.                                  */
/* When calling from TEST.CGI it gives a runtime-error:                  */
/* TEST.cgi - Entrypoint not found                                       */
/* Unable to find entrypoint of procedure hb_fileRegister in DLL-file    */
/* harbour-32.dll.                                                       */
/* (see att.  )                                                          */
FUNCTION Q_USERS()
LOCAL       a, aRecordset := {}, aFIELD := {}
PARAMETERS  cWHERE
USE  USERFILE
IF!EMPTY(cWHERE)
	SET FILTER TO FAM_NAME == cWHERE
GO TOP
DO WHILE .NOT. EOF()
   aFIELD   := {}
   FOR a = 1 to fcount()
      AADD(aFIELD , fieldGet(a) )
   NEXT a
   AADD( aRecordset , aFIELD )
   SKIP
ENDDO
USE
RETURN aRecordset
Greetings and thanks, Serge
Sorry... my mistake... its build test (without '.prg')
I can't help, since I've not tested NETIO on a CGI app.
Anyway... maybe in real world conditions, you should not need that.
At least in my case, the dbf files are located in the same machine as the web server, son your cgi apps, does not need to communicate with dbf files via NETIO. You should follow that path, since is the most simple and efficient.
