Very Small Expense Management Project
sudip
Re: Very Small Expense Management Project
Post by sudip »
Latest version has some improvements:-
1. You can add, change expense heads during daily expense entry (I just found one problem, after coming back you daily expense entry window, you have to reselect expense head combo box. This is a serious problem. And I shall solve it shortly).
2. Report has Pmt by and Other fields (chq no, chq dt, bank etc.). But, you have to select which fields will come to report, if fieldwidths become greater than page width ;(
Please download:
Setup:
setup.zip
(828.08 KiB) Downloaded 832 times
Source code:
MyExpense.zip
(11.7 KiB) Downloaded 780 times
swapan wrote: Then what's the Client's (the doctor) feedback?! Please share the first hand reaction he gave. And any changes/ideas from his side? I'm curious to know, after all he has seen a few readymade software on this subject before yours rather say "ours" software.
First of all, thank you Swapan, to call it "our" software. Is it is :)
Doctor's reaction was like, "Ok, you have done it! Thank you very much. It's working. And I shall inform you about my problems and suggestions after using it". He is using computer for many years. He even knows the terms like "Open Source Software". But, he never participated in software testing. So, I found his reaction is quite positive :)
Thank you all very much.
With best regards.
sudip
Post by sudip »
I solved previous problem. Please download :
Setup:
setup.zip
(827.95 KiB) Downloaded 858 times
Source Code:
MyExpense.zip
(11.71 KiB) Downloaded 828 times
Please send your comments regarding this software. This will be very helpful for learning of HMG for any novice HMG learner like myself.
TIA.
With best regards.
Thanks for sharing Sudip. :)
Suggestion for improvement:
Daily Expense Entry Grid justification shall be {left, left, right}
sudip
Post by sudip »
rathinagiri wrote:Suggestion for improvement:
Yes, I did it. Moreover I also used my first .hlp file with it :)
Thank you Rathi. I used Shalom help referred by you. And I also learned how to use help from your Dbu and InterestCalculator source code. :)
Please download:
Setup:
setup.zip
(831.01 KiB) Downloaded 946 times
Source Code:
MyExpense.zip
(15.18 KiB) Downloaded 1019 times
Please send your remarks. :)
TIA.
With best regards to all.
Thanks Sudip. Now it is fine. :)
sudip
Post by sudip »
Hello Friends,
I converted this small project to SQLite and added some features.
Please go to viewtopic.php?f=15&t=853&p=5238#p5238
And send your comments about this to help me learning HMG and SQLite :)
Regards.
Tristan
Post by Tristan »
Hello !
I download expense project and try to compile but error, please help me...
As the error log points out, you have to install hfcl, a user defined library which can be downloaded from here.
Tristan
Post by Tristan »
Hi Thanks !
I already donwload and compile again but error still happen.
What is hfcl ?
Thanks for help.
Tristan
