Autoscroll to bottom in EDITBOX
- Clip2Mania
I'm "filling up" an editbox (with vertical scrollbar) with data, which is over a hundred lines long, refreshing the display after every line that I add. The default behaviour is that you only see the x number of first lines (depending on height you defined).
Is there a way to have the editbox automatically scroll down when you add lines beyond the height of the editbox?
Re: Autoscroll to bottom in EDITBOX
Did you try this?
form.editbox.caretpos := len( form.editbox.value )
- Clip2Mania
Mr Rathinagiri,
Adding piece of code attached.
The caret-position is indeed at the end, but the editbox doesn't scroll to the bottom...Did you try this?
- Scroll.zip
- (1.32 KiB) Downloaded 714 times
Hi,Clip2Mania wrote: Adding piece of code attached.
Thanks for your sample code.
Please take a look for the working updated sample below.
#define CRLF chr(13)+chr(10)
function main()
local cSMsg:="Do Something"
DEFINE WINDOW MainForm;
AT 90,90;
WIDTH 780;
HEIGHT 550;
TITLE 'Inventory Renamer';
MAIN;
NOSIZE
DEFINE MAIN Menu of MainForm
DEFINE POPUP "File"
MENUITEM "Select From List" ACTION DoList()
SEPARATOR
MENUITEM "Exit" ACTION ThisWindow.Release
END POPUP
END MENU
DEFINE STATUSBAR
STATUSITEM cSMsg
CLOCK
DATE
END STATUSBAR
@ 005,005 EDITBOX Edit_1 ;
WIDTH 760 HEIGHT 425 ;// READONLY ;
VALUE " ";
FONTCOLOR {000,000,255} ;
FONT "Courier New" SIZE 10
@ 440, 665 BUTTON bn_Go;
OF MainForm;
CAPTION "Rename";
ACTION MsgInfo("Go!")
@ 443, 10 LABEL lb_Stat ;
VALUE " ";
WIDTH 650;
TRANSPARENT
MainForm.Center
MainForm.Activate
return NIL
function Dolist()
local cList, n, nTokens
local cStr:=""
if !file("list.txt")
MsgInfo("Didn't find a list.txt")
return NIL
cList:=memoread("list.txt")
nTokens:=numtoken(cList,CRLF)
MsgInfo("List is "+str(len(cList))+" bytes long"+ CRLF + str(nTokens)+" lines in the list")
For n := 1 to nTokens
cDir:=token(cList,CRLF,n)
cStr:=cStr+"File "+strzero(n,3)+" "+cDir+CRLF
MainForm.Edit_1.Value:=cStr
MainForm.Edit_1.Caretpos := len(MainForm.Edit_1.Value)-1
do events
Next
INSERT_CTRL_END()
return NIL
function strzero(nNum,nLen)
return right(replicate("0",nLen)+ltrim(token(str(nNum),".",1)),nLen)
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
HB_FUNC( INSERT_CTRL_END )
keybd_event(
VK_CONTROL, // virtual-key code
0, // hardware scan code
0, // flags specifying various function options
0 // additional data associated with keystroke
keybd_event(
VK_END , // virtual-key code
keybd_event(
KEYEVENTF_KEYUP,// flags specifying various function options
#pragma ENDDUMPKind Regards,
- Clip2Mania
Unfortunately, don't know any C myself ...
Thanks for this solution Grigory!
- Agil Abdullah
For me, it's very useful, coz not only reading text/memo but also showing line numbers at every line.
Thanks Gregory.
Thanks Gregory.
Programmer Never Surrender
Thanks Gregory !
Gracias Gregory Filatov,
Excelente ejemplo!
Excelente ejemplo!
- esgici
Hi ErikClip2Mania wrote:Unfortunately, don't know any C myself ...![]()
I agree with you
We need something like HMG_KeyPut() same as HB_KeyPut()
Happy HMG'ing
Viva INTERNATIONAL HMG
