Using & in a label
CalScot
Using & in a label
Post by CalScot »
Hi, everyone.
I think I've discovered a bug!
I'm using 3.3.1 and XP3.
When I use Property Edit to enter the value of a label, and I type in "&" (the ampersand) instead of "and", it shows properly in the edit box (and shows properly again if I go back to edit it) but it doesn't show correctly on the label. Instead, it shows a double space where the " & " should be.
For example, If I enter
"Checking for this & that..." in the property edit box, it shows up as
"Checking for this that..." on the label itself - before and after compiling.
It's not a big problem, but it would sometimes be nice to be able to save the 2 extra character spaces that using "&" instead of "and" allows.
Thanks and regards to you all.
Re: Using & in a label
& in conjuction with next character works like a hot key for control next to label.
If you want to use pure & char, you should change value of label after defining it, I think.
CalScot
Post by CalScot »
Thanks. MOL. I understand what you're saying, but this is done through the Property Edit feature of the Objects Inspector.
I haven't tried (yet) to see what happens if I define or edit it using an external text editor (i.e., outside of the Objects Inspector), but I will, to see if that leaves my label intact -- but I still think it's a system bug that needs to be fixed, in that it's interpreting (misinterpreting!) the text of the label as having a control character in it.
Thanks again.
It's very useful in my opinion, nt a bug.
But, it should exist a way to allow use "&" as common char, eg. \&;
something like html
Wherever you want & inside label/menu control please use &&.
Consider this:
   define window x at 0, 0 width 400 height 300 main
      define label l1
         row 10
         col 10
         width 200
         value 'A Sample & Label'
      end label
      define label l2
         row 40
         col 10
         width 200
         value 'A Sample && Label'
      end label
   end window
   x.Center
   x.Activate
CalScot
Post by CalScot »
Ah! I suspected that I couldn't have been the first to encounter this!
You've solved the spacing problem that led me to discover this.
Perfect solution!
Thank you Rathinagiri
gfilatov
Post by gfilatov »
Rathinagiri wrote:Hi,
Consider this:
Please be so kind to try also the updated sample below:
      define label l1
         row 10
         col 10
         width 200
         NOPREFIX .T.
      end label
      define label l2
         row 40
         col 10
         width 200
      end label
   end window
   x.Center
   x.Activate
Awesome Grigory! Thanks!
Thanks for info!
I'm still learning and still foolish :-D
CalScot
Post by CalScot »
Not at all foolish, MOL! ;-) We all live and learn. (And sometimes forget!)
And I absolutely agree about having & as an operator/evaluator - I use it a lot! I'm just surprised that I haven't had (or don't remember?) the issue of it being inside a string before now!
I even tried (before posting) to search this site for "& in a label", but as the search stripped out the "& in a", that didn't help me much. And I can't see a way around that, either! Who can find this thread if they search for it using "&" as a key word?
But my concern (it wasn't really a "problem") is resolved, so thanks to all for that.
Now I need to go and check out Grigory's "NOPREFIX .T." addition :-)
Thanks again.
CalScot
