Wish to be able to enter Pdf filename
hmgchang
Post by hmgchang »
Dear Masters,
From the print preview...
i wish to be able to enter the pdf filename
Just Hmg It !
Clip2Mania
Re: Wish to be able to enter Pdf filename
Post by Clip2Mania »
That is what mol is proposingin this post
AFAIK there are still some small issues with it (return to the original name if you call the print repeatedly), and it is not yet implemented. Hopefully in 3.3.2 ;)
It is implemented in the next version, with all the features of the PUTFILE function.
srvet_claudio wrote:It is implemented in the next version, with all the features of the PUTFILE function.
Thank you, Sir
Thank you, Sir
I've took a brief look at the last version and a little proposal for the next releases arised:
It could be nice if you could specify a destination PDF file at SELECT PRINTER command, so, you could generate PDF reports without user interaction (without preview).
This has another advantage: You could use the same print code (@...PRINT commands) without the need of two separate codes @...PRINT and @...HPDFPRINT.
In other words an unique report code with multiple possible destinations (including PDF file).
Since (as I've said) I've only took a brief look at the last version, if this is already possible, I'm sorry in advance...
Roberto Lopez wrote:It could be nice if you could specify that the destination PDF file at SELECT PRINTER command, so, you could generate PDF reports without user interaction (without preview).
Very nice!
Very nice!
Roberto Lopez wrote:I've took a brief look at the last version and a little proposal for the next releases arised:
In other words and unique report code with multiple possible destinations (including PDF file).
Very fine option, but we must remember that print preview generates image pdf and .pdf file can be very big for few pages.
Very good idea Roberto. :)
