Merci mon ami pour vos conseils(chokrane ilayka)esgici wrote: IMO modifying system file is not a good way![]()
HMG 3.3.1 (Stable)
Re: HMG 3.3.1 (Stable)
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
Error CueBanner in HMG.3.3.1
Harbour 3.2.0dev (r1404111536)
Copyright (c) 1999-2014, http://harbour-project.org/" onclick="window.open(this.href);return false;
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:88:0: warning: "EM_SETCUEBANNER" redefined [enabled by default]
#define EM_SETCUEBANNER 5377 // Set the cue banner with the lParm = LPCWSTR
In file included from C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:86:0:
c:\hmg.3.3.1\mingw-64\x86_64-w64-mingw32\include\commctrl.h:4430:0: note: this is the location of the previous definition
#define EM_SETCUEBANNER (ECM_FIRST+1)
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg: In function 'HB_FUN_SETCUEBANNER':
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:93:7: warning: implicit declaration of function 'hb_parc' [-Wimplicit-function-declaration]
LPWSTR lpWCStr = HMG_parc(2) ;
In file included from C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:83:0:
C:/hmg.3.3.1/include/HMG_UNICODE.h:73:41: warning: comparison between pointer and integer [enabled by default]
#define HMG_CHAR_TO_WCHAR(c) ((c != NULL) ? hb_osStrU16Encode(c) : NULL) // return WCHAR
C:/hmg.3.3.1/include/HMG_UNICODE.h:74:38: note: in expansion of macro 'HMG_CHAR_TO_WCHAR'
#define HMG_parc(n) HMG_CHAR_TO_WCHAR (hb_parc(n))
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:93:24: note: in expansion of macro 'HMG_parc'
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:93:7: warning: implicit declaration of function 'hb_osStrU16Encode' [-Wimplicit-function-declaration]
C:/hmg.3.3.1/include/HMG_UNICODE.h:73:73: warning: pointer/integer type mismatch in conditional expression [enabled by default]
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:97:4: warning: implicit declaration of function 'hb_parnl' [-Wimplicit-function-declaration]
SendMessage( (HWND) hb_parnl(1), EM_SETCUEBANNER, (WPARAM) hb_parl(3), (LPARAM) (LPCWSTR) lpWCStr ) ;
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:97:17: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
C:\hmg.3.3.1\SAMPLES\Controls\TextBox\CUEBANNER\demo.prg:97:4: warning: implicit declaration of function 'hb_parl' [-Wimplicit-function-declaration]
CueBanner in 32 bits Work..
CueBanner in 64
CueBanner in 64
Hola
Siempre que actualizo HMG se me olvida que tengo que respaldar mi "i_Color.ch".
Aquí les dejo este "i_color_Nvo.ch" por si lo quieren utilizar e incluso si se puede
distribuir con las nuevas versiones de HMG.
hi
Whenever I update HMG I forget that I have to support my "i_Color.ch".
Here is this "i_color_Nvo.ch" in case you want to use and even if you can
distribute new versions of HMG.
viewtopic.php?f=8&t=3953&p=36926&sid=cc ... 303#p36926
hi
- srvet_claudio
See if you file C:\hmg.3.3.1\INCLUDE\i_tree.chtonton2 wrote:bonsoirJavier Tovar wrote:Hola Tonton2,
-Solo ve a donde esta ese linea en el archivo C: \ HMG \ include \ i_tree.ch en la linea 233, y pones doble diagonal al inicio:-Ejecutas el BuildAllLib.BatCode: Select all
//_HMG_THIS_TREEITEM_VALUE
-Listo
When we use thiswe get that errorCode: Select all
include this line:
MEMVAR _HMG_This_TreeItem_Value
- srvet_claudio
This is the correct way to implement SETCUEBANNER (32 and 64 bits):danielmaximiliano wrote:Error CueBanner in HMG.3.3.1
Copyright (c) 1999-2014, http://harbour-project.org/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
#pragma BEGINDUMP
#define COMPILE_HMG_UNICODE // Remove this for ANSI building
#include "HMG_UNICODE.h"
#include <windows.h>
#include <commctrl.h>
#include "hbapi.h"
#ifndef EM_SETCUEBANNER
#define ECM_FIRST 0x1500
#define EM_GETCUEBANNER (ECM_FIRST+2)
#endif
HB_FUNC( SETCUEBANNER ) // (nEditHandle, cMsg, lGetFocus) -> nil
#ifdef UNICODE
LPWSTR lpWCStr = HMG_parc(2);
#else
LPWSTR lpWCStr = HMG_MBtoWC (hb_parc(2));
#endif
SendMessage ((HWND) HMG_parnl(1), EM_SETCUEBANNER, (WPARAM) hb_parl(3), (LPARAM) lpWCStr ) ;
#pragma ENDDUMPRe: HMG 3.3.1 (Stable)
Bonjour,srvet_claudio wrote:See if you file C:\hmg.3.3.1\INCLUDE\i_tree.chtonton2 wrote:bonsoirJavier Tovar wrote:Hola Tonton2,
-Listo
include this line:
cette ligne existe a la ligne 233 de i_tree.ch
This line is in file tree.ch (233)
#xtranslate This.TreeItemValue => _HMG_This_TreeItem_Value
Y.TABET
Y.TABET
Hola, varios puntos... / Hi, several points ....
Es posible que cualquier "CONTROL" tenga el evento ON MOUSEOVER ??, lo comento
porque este evento lo hace cuando ponemos la propiedad TOOLTIP.
It is possible that any "CONTROL" has the event ON MOUSEOVER ??, I mention
because this event does when we put the TOOLTIP property.
Tengo una serie de controles COMBOBOX y quiero que al ON CHANGE se pase al siguiente y se abra automáticamente
(para evitar varios "clicks") alguna idea de como la haria ??
I have a number of controls COMBOBOX, and I want to ON CHANGE will go to the next and automatically open
(to avoid several "clicks") any idea as would make ??
Estoy queriendo utilizar un arreglo con el COMBOBOX con la propiedad SORT pero despliega el siguiente error...???
I'm wanting to use an arrangement with the SORT property COMBOBOX but displays the following error ... ???
- ComboBox-Error.png (153.39 KiB) Viewed 5242 times
Hi Andy,andyglezl wrote: I have a number of controls COMBOBOX, and I want to ON CHANGE will go to the next and automatically open
Please be so kind to try the following working sample:
* MiniGUI ComboBox Demo
* (c) 2002 Roberto Lopez
#include "minigui.ch"
WIDTH 400 ;
HEIGHT 200 ;
TITLE 'ComboBox Demo' ;
DEFINE COMBOBOX Combo_1
ROW 10
COL 10
WIDTH 100
ITEMS { '1 | Uno' , '2 | Dos' , '3 | tres' , '0 | zero' }
VALUE 1
ON CHANGE MsgInfo ( 'On Change event' )
ON ENTER MsgInfo ( Str(Form_1.Combo_1.value) )
UPPERCASE .T.
sort .T.
on gotfocus ComboboxShowList( this.Handle )
END COMBOBOX
CENTER WINDOW Form_1
* C-level
#pragma BEGINDUMP
#include "hbapi.h"
HB_FUNC ( COMBOBOXSHOWLIST )
SendMessage( (HWND) hb_parnl( 1 ), CB_SHOWDROPDOWN, 1, 0 );
#pragma ENDDUMP
