Class DATA getSet
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Class DATA getSet
Post by karweru »
Hi Friends,
I want to illustrate my question with the code below;
CREATE CLASS student
DATA name
DATA age
EXPORT:
METHOD name(cName) INLINE ::getSet("name",cName)
METHOD age(nAge) INLINE ::getSet("age",nAge)
METHOD getSet(xVar,xVal)
ENDCLASS
METHOD init()
::name:=""
::age=:=0
RETURN self
METHOD getSet(xVar,xName)
nPars:=pCount()
do case
case (xVar:=upper(xVar))=="NAME"
 if nPars==2
::name:=xVal
return ::name
case xvar=="AGE"
if nPars==2
::age:=xVal
return ::age
endcase
return Nil
My question is about the getset() method manner of coding. Is there a function that can be used to get/set DATA in a class. I stumbled on classSel() which can list all the DATA in the class but is there a function(s) that can be used so that the getSet() method above can be coded as below;
getDataFunction(<xVar>)
setDataFunction(<xVar>,<xVal>)
Thank you in advance.
Kind regards,
Gilbert.
Re: Class DATA getSet
karweru wrote:...
Hi Gilbert
Frankly, I'm not an OOP expert.
Recently past a thread in Harbour users forum, including a document on Harbour OOP.
I hope it may be useful.
karweru
Post by karweru »
Hi Esgici,
Thank you very much for your interest in this subject...I was able to resolve the question and consequently used this style to re-write HMGobjects, very compressed/shortened verson, for use in my projects.
The solution was using macros as below, (using the same code above for illustration);
DATA name
DATA age
EXPORT:
ENDCLASS
METHOD init()
::name:=""
::age=:=0
RETURN self
local get_Var,set_Var
get_var:="qself():_"+xVar
set_var:="qself():"+xVar
if valType(xVal)!="U"
&set_Var:=xVal
return &get_Var
Thank you again Esgici.
Kind regards,
Gilbert.
Hi Gilbert
I was should interested; because your question left 20 days unanswered;
and I know well what is being left unanswered, waiting unresponsive :(
I'm glad that you have found yourself an answer to your question.
And thanks to share your code with us :)
dhaine_adp
Post by dhaine_adp »
Hi Gilbert,
Here's a shortened version of your solution without the local variables on method getSet():
   DATA name INIT NIL HIDDEN
   DATA age  INIT  0 HIDDEN
   EXPORT:
   METHOD New() CONSTRUCTOR
ENDCLASS
METHOD New()
   RETURN self
METHOD getSet( cPropName, xVal )
   IF PCOUNT() == 1
      return ::&( cPropName )
      ::&( cPropName ) := xVal
   RETURN Self
Danny
Manila, Philippines
Interesting!
