HMG 2.9.2 (Forum test VI)
This will be the last forum test prior publication of 2.9.2.
Please, report any problem you found.
TIA.
- Fixed: Print Preview. 'go to page' window not refresh preview window.
- Modified: Documentation completed, fixed, indexed, linked and formatted.
- New: Property style synonyms for the following GUI
objects (look at documentation for details):
- WINDOW
- TOOLBAR
- TREE
- TAB
- SPLITBOX
- CONTEXT MENU
- DROPDOWN MENU
- MAIN MENU
- STATUSBAR
The following synonyms for alternate syntax were added:
- LINES (NOLINES)
- ALIGNMENT (CENTERALIGN,RIGHTALIGN)
- TODAY (NOTODAY)
- TODAYCIRCLE (NOTODAYCIRCLE)
- DATATYPE (NUMERIC,CHARACTER,DATE)
- CASECONVERT (UPPERCASE,LOWERCASE)
- TICKMARKS (NOTICKS)
- AUTOSIZEWINDOW (NOAUTOSIZEWINDOW)
- AUTOSIZEMOVIE (NOAUTOSIZEMOVIE)
- ERRORDLG (NOERRORDLG)
- MENU (NOMENU)
- OPEN (NOOPEN)
- PLAYBAR (NOPLAYBAR)
Roberto.
hmg292-6.rar
(369.24 KiB) Downloaded 383 times
Re: HMG 2.9.2 (Forum test VI)
Thanks a lot Maestro :)
Best Regards
Vanguarda
Post by Vanguarda »
Thanks master for this update
regards,
Hi Maestro
Tested, no problem encountered.
Best Regards
gfilatov
Post by gfilatov »
Roberto Lopez wrote:Hi All,
Hi Roberto,
There is a small issue in the header i_altsyntax.ch.
Take a look for the following definitions:
#xcommand ALIGNMENT RIGHT ;
_HMG_SYSDATA \[ 440 \] := .T. ; _HMG_SYSDATA \[ 393 \] := .F.
#xcommand ALIGNMENT CENTER ;
_HMG_SYSDATA \[ 440 \] := .F. ; _HMG_SYSDATA \[ 393 \] := .T.
_HMG_SYSDATA \[ 440 \] := .F. ; _HMG_SYSDATA \[ 393 \] := .F.
I guess that it should be the ALIGNMENT LEFT :?:
Hi Roberto,
You are right.
I'll fix it prior to publication.
Thanks for reporting.
Roberto.
