Temporary table
Re: Temporary table
franco wrote:esgici,
I am not sure if this is dll but I must start with #include "hfcl.ch" or the hb_dbcreatetemp()
does not work
I am still having trouble with print grid from a table.
It does not make sense to create a temp table with some fields of a real table, then crate an array
to use print grid. maybe you can help with this.
or how do I just create an array with certain fields of a real table then sort on one of the
fields. I know this is easy but can not find example.
Thanks ............. Franco
Hi Franco
Expression like does not work, I am still having trouble and does not make sense not have enough meaning to understand your problem(s). And without understand we can't help you :(
Please be clear about problem(s) and more importantly give us some SSCCE(s).
Re: Temporary table
esgici wrote:Hi Franco
Re: Temporary table
Franco: I look at the examples
C:\hmg.3.3.1\SAMPLES\Miscellaneous\TEMPORARY_TABLE
C:\hmg.3.3.1\SAMPLES\Advanced\MEMORY_TABLES
