Pablo, this we will do in the next release. Thanks a lot.Pablo César wrote:Yes Marek, you are right !mol wrote:I found a difference in h_HMG_HPDF.PRG source file.
In _HMG_HPDF_PRINT function definition, some piece of code from line 283 looks like that:In _HMG_HPDF_MULTILINE_PRINT function definition, adequate line (no. 372) differents from above:Code: Select all
If HMG_UPPER( HB_USUBSTR( cFontName, HMG_LEN( cFontName ) - 3 ) ) == '.TTF' // load ttf fontDifference is in recognizing .TTF extension. First line is good, second is bad.Code: Select all
If HMG_UPPER( HB_USUBSTR( cFontName, HMG_LEN( cFontName ) - 4 ) ) == '.TTF' // load ttf font
I've changed 4 to 3 in line 372, recompiled library, and it's work OK to me.
I'm testing forward.
It's a bug to correct in the next version of HMG, I think.
Regards, Marek
I have published this solution at viewtopic.php?p=35144#p35144 because EduardoLuis has appointed this same fail. Even with solution in our hands, nothing happen at new releases.
Only strong discusions about this...
HMG 3.3.1 (Stable)
Re: HMG 3.3.1 (Stable)
I've modified h_controlmisc.prg to allow user to enter base filename for saving his prinouts:
Function _HMG_PRINTER_SavePages()
Local c , i , f , t , d , e, x, h, a := {}
Local g := {"PDF", "BMP","JPG","GIF","TIF","PNG","EMF"}
Local nTypePicture := { Nil , BT_FILEFORMAT_BMP, BT_FILEFORMAT_JPG, BT_FILEFORMAT_GIF, BT_FILEFORMAT_TIF, BT_FILEFORMAT_PNG, Nil }
Local hBitmap, nType
Local flag_PDF := .F.
local nWidth, nHeight, nDPI, cDocName
x := _HMG_PRINTER_GetOutFileType ( g ) /* Returns following Array:
( x[1]=>Folder_Name | x[2]=>File_Type | x[3]=>Base file name) */
if HMG_LEN(x)=0
IF x[ 2 ] == 1
flag_PDF := .T.
cDocName := alltrim(x[ 3 ])
if empty(cDocName)
cDocName := "HMG_PrintFile_"
// avoid to use special chars in filename
cDocName := charrepl(":/.,|\@#$%&^*+ ",_HMG_SYSDATA [ 358 ],"_") + "_"
If HB_URIGHT(x[1],1) != '\'
e := x[1] + '\'
Else
e := x[1]
h := g[x[2]] // File_Type extension
nType := nTypePicture[ x[2] ]
t := gettempfolder()
//MsgStop(_HMG_SYSDATA [ 358 ])
c := adir ( t + _HMG_SYSDATA [ 379 ] + "_hmg_print_preview_*.Emf")
asize ( a , c )
adir ( t + _HMG_SYSDATA [ 379 ] + "_hmg_print_preview_*.Emf" , a )
For i := 1 To c
f := t + a [i]
d := e + cDocName + StrZero ( i , 4 )
//MsgStop("f->"+f+chr(10)+"t->"+t+chr(10)+"d->"+d+chr(10)+"cDocName->"+ cDocName+ "len(a)->"+str(len(a)))
IF HMG_UPPER (h) == "EMF"
COPY FILE (F) TO (D+"."+h)
// by Dr. Claudio Soto, April 2014
hBitmap = BT_BitmapLoadEMF ( f, WHITE )
IF hBitmap <> 0 .AND. flag_PDF == .F.
BT_BitmapSaveFile (hBitmap, d+"."+h, nType)
BT_BitmapRelease (hBitmap)
IF hBitmap <> 0 .AND. flag_PDF == .T. // by Rathinagiri (May 2014)
if i == 1
nDPI := 300
nWidth := ( BT_BitmapWidth ( hBitmap ) / nDPI * 25.4 )
nHeight := ( BT_BitmapHeight( hBitmap ) / nDPI * 25.4 )
_HMG_HPDF_INIT ( d+".pdf", 1, 256, nHeight, nWidth, .f. )
_hmg_hpdf_startdoc()
_HMG_HPDF_SetCompression( 'ALL' )
h := "JPG"
_hmg_hpdf_startpage()
BT_BitmapSaveFile (hBitmap, d+"."+h, BT_FILEFORMAT_JPG)
_HMG_HPDF_IMAGE ( d+"."+h, 0, 0, nHeight, nWidth, .t. , h )
_hmg_hpdf_endpage()
FERASE( d+"."+h )
if i == c
_hmg_hpdf_enddoc()
Next i
Function _HMG_PRINTER_GetOutFileType (aFiletype) // by Pablo César, April 2014
Local cFolder_aux,cFolder:=GetCurrentFolder(), aRet:={}
DEFINE WINDOW Out_File AT 171 , 285 WIDTH 468 HEIGHT 179 ;
TITLE "Output type file" MODAL NOSIZE NOSYSMENU
ON KEY ESCAPE ACTION ThisWindow.Release()
DEFINE LABEL Label_1
ROW 22
COL 20
WIDTH 60
HEIGHT 20
VALUE "Folder:"
FONTNAME "Arial"
FONTSIZE 9
END LABEL
DEFINE TEXTBOX Text_1
ROW 18
COL 90
WIDTH 320
HEIGHT 22
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
READONLY .T.
VALUE cFolder
END TEXTBOX
DEFINE BUTTON Button_1
ROW 17
COL 412
WIDTH 30
HEIGHT 24
ACTION (cFolder_aux:=GetFolder(),cFolder := IIF (EMPTY(cFolder_aux),cFolder,cFolder_aux), SetProperty("Out_File","Text_1","Value",cFolder))
FONTNAME "Arial"
FONTSIZE 9
PICTURE "HP_FOLDER"
PICTALIGNMENT TOP
END BUTTON
DEFINE LABEL Label_OutFileName
ROW 50
COL 10
WIDTH 79
HEIGHT 40
VALUE "Base filename:"
FONTNAME "Arial"
FONTSIZE 9
END LABEL
DEFINE TEXTBOX Text_OutFileName
ROW 50
COL 90
WIDTH 320
HEIGHT 22
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
READONLY .F.
VALUE charrepl(":/.,|\@#$%&^*+ ",_HMG_SYSDATA [ 358 ],"_")
END TEXTBOX
DEFINE LABEL Label_2
ROW 90
COL 20
WIDTH 60
HEIGHT 20
VALUE "File type:"
FONTNAME "Arial"
FONTSIZE 9
END LABEL
DEFINE COMBOBOX Combo_1
ROW 86
COL 90
WIDTH 100
HEIGHT 126
ITEMS aFiletype
VALUE 1
FONTNAME "Arial"
FONTSIZE 9
END COMBOBOX
DEFINE BUTTON Button_2
ROW 110
COL 270
WIDTH 80
HEIGHT 24
ACTION (aRet:={GetProperty("Out_File","Text_1","Value"),GetProperty("Out_File","Combo_1","Value"),GetProperty("Out_File","Text_OutFileName","Value")},ThisWindow.Release())
CAPTION _HMG_SYSDATA [ 371 ] [11]
FONTNAME "Arial"
FONTSIZE 9
END BUTTON
DEFINE BUTTON Button_3
ROW 110
COL 360
WIDTH 80
HEIGHT 24
CAPTION _HMG_SYSDATA [ 371 ] [12]
FONTNAME "Arial"
FONTSIZE 9
END BUTTON
CENTER WINDOW Out_File
ACTIVATE WINDOW Out_File
Return aRet
- esgici
Good enhancement, thanks Marekmol wrote:I've modified h_controlmisc.prg to allow user to enter base filename for saving his prinouts:
I hope will be implemented in next release of HMG
Viva INTERNATIONAL HMG
Thank you Marek. Will use it.
Save window is in English only. We should add national labels too.
- Agil Abdullah
Many thanks to Mr. Rathi and his team and supporters.
Awaiting accomplished this new version.
-Agil-
-Agil-
Programmer Never Surrender
- srvet_claudio
Hi Friends,
please test this patch, main changes are:
1) internal change in Dynamic Back and Fore Color in Grid (now is more efficient, was removed the use of an array with an element for each cell, avoid create a huge array).
2) New Dynamic Font in Grid and Tree controls
New features:
New features:
* GRID
- <ParentWindowName>.<GridControlName>.Image ( lTransparent ) := { "image1.png", "image2.bmp", ... }
- <ParentWindowName>.<GridControlName>.ImageIndex ( nRow , nCol )
- <ParentWindowName>.<GridControlName>.ImageList
- <ParentWindowName>.<GridControlName>.ColumnDYNAMICFONT( nCol ) := {|| {cFontName, nFontSize, [ lBold, lItalic, lUnderline, lStrikeOut ]} }
- <ParentWindowName>.<GridControlName>.HeaderImageIndex ( nCol ) [ := | -->] nIndex
- <ParentWindowName>.<GridControlName>.ChangeFontSize := nSize | NIL // Useful for use Dynamic Font with more (less) Height than the size of font the Grid/Tree control
// Dynamic Font (Grid/Tree)
ARRAY FONT <cFontName> SIZE <nFontSize> [ BOLD ] [ ITALIC ] [ UNDERLINE ] [ STRIKEOUT ] --> { cFontName, nFontSize, lBold, lIitalic, lUnderline, lStrikeout }
CREATE ARRAY FONT <cFontName> SIZE <nFontSize> [ BOLD <lBold> ] [ ITALIC <lIitalic> ] [ UNDERLINE <lUnderline> ] [ STRIKEOUT <lStrikeout> ] --> { cFontName, nFontSize, lBold, lIitalic, lUnderline, lStrikeout }
* Tree Control
- ON EXPAND
- ON COLLAPSE
- This.TreeItemValue
- <ParentWindowName>.<TreeControlName>.DynamicForeColor := cBlock
- <ParentWindowName>.<TreeControlName>.DynamicBackColor := cBlock
- <ParentWindowName>.<TreeControlName>.DynamicFont := cBlock
- <ParentWindowName>.<TreeControlName>.ChangeFontSize := nSize | NIL // Useful for use Dynamic Font with more (less) Height than the size of font the Grid/Tree control
- <ParentWindowName>.<TreeControlName>.IsExpand ( nValue ) --> lBoolean
- <ParentWindowName>.<TreeControlName>.ImageList [ := | --> ] hImageList
- <ParentWindowName>.<TreeControlName>.HasLines [ := | --> ] lBoolean
- <ParentWindowName>.<TreeControlName>.FullRowSelect [ := | --> ] lBoolean
- <ParentWindowName>.<TreeControlName>.HasButton ( nValue ) [ := | --> ] lBoolean
- <ParentWindowName>.<TreeControlName>.Cargo ( nValue ) [ := | --> ] xData
- <ParentWindowName>.<TreeControlName>.CargoScan ( xData ) --> nValue | NIL
- <ParentWindowName>.<TreeControlName>.GetPathValue ( nValue ) --> anPathValue | NIL
- <ParentWindowName>.<TreeControlName>.GetPathName ( nValue ) --> acPathName | NIL
- <ParentWindowName>.<TreeControlName>.GetDisplayLevel ( nValue ) --> nDisplayColumn | NIL
- Demo_patch1.rar
- (9.51 KiB) Downloaded 626 times
- HMG.3.3.1_patch1.rar
- (793.53 KiB) Downloaded 690 times
Gracias Claudio por el trabajo y tu tiempo para con HMG...
como siempre una admiración hacia tú persona...
HMG 3.3.1 (Stable)
+1danielmaximiliano wrote:Gracias Claudio por el trabajo y tu tiempo para con HMG...
Very clever solution:
* Dynamic Font
#xtranslate ARRAY ;
FONT <fontname>;
SIZE <fontsize>;
[ <bold : BOLD> ] ;
[ <italic : ITALIC> ] ;
[ <underline : UNDERLINE> ] ;
[ <strikeout : STRIKEOUT> ] ;
=> { <fontname>, <fontsize>, <.bold.>, <.italic.>, <.underline.>, <.strikeout.> }HMGing a better world
