MsgInfo stop next control event to run ?
hmgchang
Post by hmgchang »
Dear Masters,
I tried to use OnLostFocus on controls, but it stop the next Action to run ...
here is the ssw,;
Function Main()
      WIDTH 550 ;
      HEIGHT 350 ;
      MAIN ;
      TITLE "MsgInfo function .... stop next event..."
      DEFINE EDITBOX Edit_1
          ROW    30
          COL    30
          WIDTH  210
          HEIGHT 170
          VALUE "This Editbox control has no MsgInfo for OnLostFocus."
      END EDITBOX
      DEFINE EDITBOX Edit_2
        ROW    30
        COL    280
        WIDTH  210
        HEIGHT 160
        VALUE "This control has MsgInfo for the OnLostFocus."
        ONLOSTFOCUS MsgInfo( "Leaving Editbox !")
      END EDITBOX
      DEFINE BUTTON Button_1
        ROW    210
        COL    40
        WIDTH  100
        HEIGHT 28
        ACTION MsgInfo( "Button_1 Action")
        CAPTION "Button_1"
      END BUTTON
      DEFINE BUTTON Button_2
        ROW    210
        COL    290
        WIDTH  100
        HEIGHT 28
        ACTION Nil
        CAPTION "Button_2"
        ONLOSTFOCUS MsgInfo( "Button_2 LostFocus")
      END BUTTON
      DEFINE LABEL Label_1
        ROW    260
        COL    20
        WIDTH  480
        HEIGHT 20
        VALUE "The Edit_2 OnLostFocus event prevent the next control event to occure..."
      END LABEL
    CENTER WINDOW Form_1
Return NIL
Just Hmg It !
hmgchang
Re: MsgInfo stop next control event to run ?
Post by hmgchang »
Where do I do wrong ? pls advise...
TIA
rgds,
Chang
Just Hmg It !
Agil Abdullah
Post by Agil Abdullah »
Hi Chang,
Apa kabar? Salam kenal.
I am a new comer... following while learning.
-Agil
Kemang, Jakarta Selatan, Indonesia
Programmer Never Surrender
Hola HMGChang,
A mi si me muestra bien los MsgInfo de EditBox2 y del Boton2 de tu muestra!
Te envio imagen de que si fuciona bien!, yo tuve ese error y no me quedo más que reinstalar HMG!, Sin antes de buscar virus!
Hello HMGChang,
My well if you show me MsgInfo EditBox2 and Key2 of your shows!
I send you picture if I had fuciona well !, that mistake and do not stay more than reinstall HMG before seeking !, No virus!
greetings
no error.jpg (45.2 KiB) Viewed 4585 times
hmgchang wrote:Dear Masters,
here is the ssw,;
Function Main()
      WIDTH 550 ;
      HEIGHT 350 ;
      MAIN ;
          ROW    30
          COL    30
          WIDTH  210
          HEIGHT 170
      END EDITBOX
        ROW    30
        COL    280
        WIDTH  210
        HEIGHT 160
      END EDITBOX
        ROW    210
        COL    40
        WIDTH  100
        HEIGHT 28
        CAPTION "Button_1"
      END BUTTON
        ROW    210
        COL    290
        WIDTH  100
        HEIGHT 28
        ACTION Nil
        CAPTION "Button_2"
      END BUTTON
        ROW    260
        COL    20
        WIDTH  480
        HEIGHT 20
      END LABEL
Return NIL
The problem is not your code, the problem is in the behavior of the dialog box that in HMG returns the focus to the control that triggered.
