How to compile this (sqlite sample)
- Clip2Mania
Hi all,
I'm trying to compile the example attached (it's about sqlite) in HMG, but I can't get it working.
I keep on getting 'undefined reference to `sqlite3_xxxxx' errors
What should I do to make these errors go away?
Thanks,
Erik
Thanks,
Erik
- sqlite.rar
- (41.95 KiB) Downloaded 534 times
Re: How to compile this (sqlite sample)
I could able to compile successfully. However there is an argument error which you may need to correct.
C:\hmg.3.3.0\SAMPLES\Projs\sqlite>type build.bat
@echo ON
cls
SETLOCAL
SET temp=%~dp0
SET stemp=%temp%&SET pos=0
:loop
SET /a pos+=1
echo %stemp%|FINDSTR /b /c:"SAMPLES" >NUL
IF ERRORLEVEL 1 (
SET stemp=%stemp:~1%
IF DEFINED stemp GOTO loop
SET pos=0
setlocal enableDelayedExpansion
set "temp1=%temp%"
set /a pos=pos-2
set temp=!temp1:~0,%pos%!
if "%1"=="" Goto WithOutPar
Set MainFile=%1
Goto Continue
:WithOutPar
for /R %~dp0%~1 %%f in (*.hbp) do (Set MainFile="%%~nf")
Goto Continue
:Continue
call %temp%\build.bat %MainFile%
@echo ON
cls
SETLOCAL
SET temp=%~dp0
:loop
SET /a pos+=1
IF ERRORLEVEL 1 (
SET pos=0
set "temp1=%temp%"
set /a pos=pos-2
Set MainFile=%1
Goto Continue
:WithOutPar
Goto Continue
:Continue
- screen.png (8.82 KiB) Viewed 13851 times
In your .hbc file, you have to include
libs=sqlite3
libs=sqlite3
- Clip2Mania
That's what I was missing. Thought it was some lib-thing, but didn't know where to put it!In your .hbc file, you have to include
libs=sqlite3
Thanks, Mr. Rathinagiri!
Erik
Add in hmg.hbc file located at c:\hmg\hmg.hbcClip2Mania wrote:That's what I was missing. Thought it was some lib-thing, but didn't know where to put it!In your .hbc file, you have to include
libs=sqlite3
Erik
- Clip2Mania
It happened to be the only lib which was "remmed out" (#) in hmg 3.3.1 (don't know why)Add in hmg.hbc file located at c:\hmg\hmg.hbc
However, I still get following error (apparently cannot create the database)
I am using HMG 3.3.1 - 32 bits.
Should I recompile harbour or so?
- sqlite_err.jpg (58.2 KiB) Viewed 13728 times
Hi,Clip2Mania wrote: However, I still get following error (apparently cannot create the database)
No, it is not
There is a mistake in your calling the function MiscSql() - wrong a first parameter.
Please take a look for your updated module main_button_1_action.prg below:
declare window Main
Function main_button_1_action
public dbo := nil
if .not. file("nombre.db3")
crearbase("nombre.db3")
msginfo("BASE Creada")
return nil
dbo := connect2db("nombre.db3",.f.)
If dbo == nil
msginfo("no se puede conectar con la Base")
return nil
Endif
if ! iswindowactive(vnombre)
Load Window vnombre
datossqlite()
vnombre.Center
vnombre.Activate
function crearbase(mDb)
local sQry
dbo := connect2db(mDb,.t.)
if dbo == nil
msgstop("File could not be created!")
return nil
// create table
sQry := 'CREATE TABLE IF NOT EXISTS "personales" ("id" INTEGER PRIMARY KEY, "nombre" VARCHAR(55), "telefono" VARCHAR(15), "fecha" DATE);'
MiscSql(dbo, sQry)
return nil
- mustafa
Hello Clip2Mania
Look at the Post:
viewtopic.php?f=6&t=1558&start=10" onclick="window.open(this.href);return false;
Sample_Sqlite.zip
Look at the Post:
Sample_Sqlite.zip
- Clip2Mania
Thanks Mustafa!
Problem is, I once downloaded this (nice) example, but wasn't aware of the updates
Thanks for helping me out! All works now.
Erik
Erik
