PrintLen on Test
hmgchang
PrintLen on Test
Post by hmgchang »
Dear Sirs,
I do some test on PrintLen...
PrintLen on Test.JPG (166.22 KiB) Viewed 6802 times
Both side are for monospace and non-fixed fonts...
BTW, how to tell font is monospace or not ?
the ssw :
  MEMVAR _HMG_SYSDATA
  Load Window Main
  Main.Center
  Main.Activate
Return NIL
FUNCTION TestFontWidth()
  LOCAL aFont, aFontSize, aText
  LOCAL cFontName, cText, cText1, cNum
  LOCAL nFontSize, nOneInch, nPAWidth, nPAHeight, nPAHorOffset, nPAVerOffset, nI
  LOCAL nRow1, nRow2, nCol1, nCol2, nRow, nCol, nOneCm, nPrintLen, nJ
  LOCAL nVSpace, nMyPrintLen
  LOCAL lSuccess
  MEMVAR _HMG_SYSDATA
  aText := {  "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789", ;
              "abcdefghijklmnopqrstuvwxyz0123456789", ;
              "人的一生,平安就好。", ;
              hb_UChar( 0x250C) + Replicate( hb_UChar ( 0x2500),20) + hb_UChar( 0x2510), ;
              hb_UChar( 0x2502) + "12345678901234567890" + hb_UChar( 0x2502)}
  aFontSize := { 10, 12, 14}
  aFont := { "CONSOLAS", "COURIER"}
  *- cText := "123456789012345678901234567890123456789012345678901234567890"
  *- aFont := GetFont()
  *- cFontname := aFont[ 1] && "CONSOLAS"
  *- nFontSize := 12
  SELECT PRINTER DIALOG TO lSuccess PREVIEW
  IF lSuccess
    nOneInch := 25.4
    nOneCm   := 10
    nPAWidth     := GetPrintableAreaWidth()
		nPAHeight    := GetPrintableAreaHeight()
		nPAHorOffset := GetPrintableAreaHorizontalOffset()
		nPAVerOffset := GetPrintableAreaVerticalOffset()
    START PRINTDOC
      START PRINTPAGE
        CmBlock( nPAWidth, nPAHeight)
        nRow := 5
        nCol := 0
        nVSpace := 5
        FOR nI := 1 TO LEN( aFontSize)
          nFontSize := aFontSize[ nI]
          nVSpace := nFontSize / 2 + 1
          nRow += nVSpace
          FOR nJ := 1 TO LEN( aText)
            cText := aText[ nJ]
            *- nRow += nFontSize
            *- nRow1 := nRow2 := nRow
            *- @ nRow1, 0 PRINT LINE TO nRow2, nPAWidth PENWIDTH 0.1 COLOR SILVER
            nRow += nVSpace + 3
            FOR nC := 1 TO LEN( aFont)
              cFontName := aFont[ nC]
              nCol := ( nC-1) * 110
              cText1 := cText + PADL( nFontSize, 3)
              @ nRow, nCol PRINT cText1 FONT cFontName SIZE nFontSize
              *- nRow += nI
              nPrintLen := PrintLen( cText, nFontSize, cFontName)
              nMyPrintLen := MyPrintLen( cText, nFontSize)
              cText1 := "PrintLen : " + PADL( nPrintLen, 5) + ", me : " + PADL( nMyPrintLen, 5) + " mm."
              *- nRow += nVSpace
              @ nRow + nVSpace, nCol PRINT cText1 FONT cFontName SIZE nFontSize COLOR BLUE
            nRow += nVSpace
            *- @ nRow, nCol PRINT cText1 FONT cFontName SIZE nI BOLD
            *- nRow += nI
            *- @ nRow, nCol PRINT cText1 FONT cFontName SIZE nI ITALIC
      END PRINTPAGE
    END PRINTDOC
function printLen( cString, nFontsize, cFontname)
  return round(gettextwidth(Nil,cString,cFontname)*0.0254*nFontsize,2)
FUNCTION MyPrintLen( cString, nFontSize)
  LOCAL nFontWidth
  nFontWidth := nFontSize * .555
  RETURN( LEN( cString) * nFontWidth * 25.4 / 72.272)
FUNCTION CmBlock( nPAWidth, nPAHeight)
  LOCAL cNum
  LOCAL nOneCm, nOneInch
  LOCAL nI, nRow, nRow1, nRow2, nCol, nCol1, nCol2
  MEMVAR _HMG_SYSDATA
  nOneCm := 10
  nOneInch := 25.4
  *- Vertical Line
  nI := 0
  DO WHILE nI < nPAWidth
    * cm V-Line
    IF MOD( nI, nOneCm) == 0
      nRow1 := 0
      nRow2 := nPaHeight
      nCol1 := nCol2 := nI
      @ nRow1, nCol1 PRINT LINE TO nRow2, nCol2 PENWIDTH 0.05 COLOR AQUA
      cNum := ALLTRIM( STR( INT( MOD( nI, 110))))
      @ 0, nCol1 PRINT cNum FONT "CONSOLAS" SIZE 10
      @ nPAHeight - 5, nCol2 PRINT cNum FONT "CONSOLAS" SIZE 10
    * Inch V-Line
    IF MOD( nI, nOneInch) == 0
      nRow1 := 0
      nRow2 := nPaHeight
      @ nRow1, nCol1 PRINT LINE TO nRow2, nCol2 PENWIDTH 0.05 COLOR SILVER
    nI++
  ENDDO
  *- Horizonal Line
  nI := 0
  DO WHILE nI < nPAHeight
      nRow1 := nRow2 := nI
      nCol1 := 0
      nCol2 := nPAWidth
    nI++
  ENDDO
TIA
rgds,
Chang
Just Hmg It !
Re: PrintLen on Test
I think there is no function to find out.
We can compare with the following box drawing chars. If the box is misaligned it is proportional font. If the box is rightly aligned, then it is monospace.
The following is in monospace font.
┌─┐ ┌┬┐ [example of line drawing characters]
│ │ ├┼┤ [requires fixed-width, especially with spaces]
└─┘ └┴┘ [otherwise they are mis-aligned, as in the bottom.]
Same text, in proportional font.
We can write a small function to find out whether the given font is a monospace or not.
Use this small sample to find out the list of monospaced fonts in your system.
   public aFontList := {}
   public aMonoSpaced := {}
   GetFontList ( NIL, NIL, DEFAULT_CHARSET, NIL, NIL, NIL, @aFontList )
   define window main at 0, 0 width 800 height 600 main
      define label selectfont
         row 10
         col 10
         width 200
         value 'Select a font'
      end label
      define combobox fonts
         row 10
         col 210
         width 200
         items aFontList
         onchange if( checkfont_ismono( this.item( this.value ) ), main.ismono.value := 'This is a monospaced font', main.ismono.value := 'This is a proportional font' )
      end combobox
      define label ismono
         row 40
         col 10
         width 400
         fontbold .t.
      end label
   end window
   main.fonts.value := 1
   for i := 1 to hmg_len( aFontList )
      if checkfont_ismono( aFontList[ i ] )
         aadd( aMonoSpaced, aFontList[ i ] )
   next i
   if hmg_len( aMonoSpaced )  > 0
      debugmsg( aMonoSpaced )
   Main.Center
   Main.Activate
function checkfont_ismono( cFontName )
   local aChars := { ' ', 'i', 'W' }
   local aLens := { 0, 0, 0 }
   local i
   local nFontSize := 14
   for i := 1 to len( aChars )
      aLens[ i ] := printlen( aChars[ i ], nFontSize, cFontName )
   next i
   lMono := .t.
   for i := 2 to len( aLens )
      if aLens[ 1 ] <> aLens[ i ]
         lMono := .f.
         exit
   next i
return lMono
  return round( gettextwidth( OpenPrinterGetDC(), cString, _HMG_CREATEFONT( OpenPrinterGetDC(), cFontname, nFontSize ) ) * 0.0254 * nFontsize, 2 )
function DebugMSG
   local i, aTemp := {}
   for i := 1 to pcount()
      aadd( aTemp, hb_PValue(i))
   next i
   msgbox(hb_valtoexp(aTemp), "Debug Informations")
 return
#pragma BEGINDUMP
#ifndef COMPILE_HMG_UNICODE
   #define COMPILE_HMG_UNICODE   // Force to compile in UNICODE
#endif
#include "HMG_UNICODE.h"
#include <windows.h>
#include "hbapi.h"
HB_FUNC ( _HMG_CREATEFONT )
   HFONT hFont ;
   int bold = FW_NORMAL;
   int italic = 0;
   int underline = 0;
   int strikeout = 0;
   if ( hb_parl (4) )
      bold = FW_BOLD;
   if ( hb_parl (5) )
      italic = 1;
   if ( hb_parl (6) )
      underline = 1;
   if ( hb_parl (7) )
      strikeout = 1;
   HDC hDC = (HDC) HMG_parnl (1);
   TCHAR *FontName = (TCHAR *) HMG_parc (2);
   INT FontSize = hb_parni (3);
   SetGraphicsMode (hDC, GM_ADVANCED);
   FontSize = FontSize * GetDeviceCaps (hDC, LOGPIXELSY) / 72;   // Size of font in logic points
   hFont = CreateFont (0-FontSize, 0, 0, 0, bold, italic, underline, strikeout,
           DEFAULT_CHARSET, OUT_TT_PRECIS, CLIP_DEFAULT_PRECIS, DEFAULT_QUALITY, DEFAULT_PITCH | FF_DONTCARE, FontName);
   HMG_retnl ((LONG_PTR) hFont );
#pragma enddump
Thank you Chang for opening this thread.
You are an eye opener!
I have to correct some other programs according to the new calculations.
I have a doubt too.
Why in the picture above, printing in "Courier 10" doesn't have the same width for 'ABCDE...' and 'abcde...'? The font is a fixed width font...
PrintLen on Test
Nice work Rathi !
Rathinagiri wrote:You are an eye opener!
Yes ! And this is very good ! :D
Pablo César wrote:You always with new ideas... :)
Congrats both of you !
Excelente Sr. Rathinagiri muy bien :D :D :D
Excellent Mr. Rathinagiri very well :D :D :D
hmgchang
Post by hmgchang »
Dear Sirs,
Thks Mr. Rathinagiri...
i tried by get this error
compile error...
compile error...
Just Hmg It !
hmgchang
Post by hmgchang »
Dear Master,
i still cannot find any accurate calculation...
Could you pls share ... ?
TIA
ths n rgds
Chang
New calculation...
New calculation...
Just Hmg It !
Which version of HMG are you using? It compiles right in HMG 3.3.1
hmgchang
Post by hmgchang »
Thks Sir,
I am still using hmg 3.2
And will upgrade ! :)
Thks n rgds
Chang
Just Hmg It !
