GETFILE()
Jeff Stone
GETFILE()
Post by Jeff Stone »
I don't know whether this behavior was intended or not but if GETFILE() is called and the user elects to chose a file in a different directory than the current directory, the user selected directory will then become the default directory. The GETFILE() function in VFP will not change the default directory when a user selects a file from a different directory.
Jeff
Re: GETFILE()
Look at here.
Re: GETFILE()
Jeff Stone wrote:I don't know whether this behavior was intended or not but if GETFILE() is called and the user elects to chose a file in a different directory than the current directory, the user selected directory will then become the default directory. The GETFILE() function in VFP will not change the default directory when a user selects a file from a different directory.
Jeff
HI Jeff,
  GetFile ( acFilter ,
                  cTitle ,
                  cDefaultPath ,
                  lMultiSelect ,
                  lNoChangeDir )
if lNoChangeDir is .T. --> Restores the current directory to its original value if the user changed the directory while searching for files.
Jeff Stone
Re: GETFILE()
Thank you both very much!
