Problem reading Unicode file
Clip2Mania
Post by Clip2Mania »
Anyone can suggest how to read unicode file attached?
I can open it in Windows Notepad without any problems.
I'm using HMG 3.3.1, 32 bits, Unicode.
Tried using memoread(), HB_Memoread() and FOpen(), FReadStr() combination,
both in ANSI & UNICODE versions of HMG, and apparently cannot open it. :cry:
Suggestions?
Thx,
Erik
test_unicode.zip
(999 Bytes) Downloaded 859 times
Re: Problem reading Unicode file
Refer attached demo
You have to save file using Encoding UTF-8
Also refer
viewtopic.php?f=7&t=3689&p=34140&hilit= ... F+8#p34140
DemoUni.rar
(603 Bytes) Downloaded 906 times
Clip2Mania
Yes, I saw the demo & read post previously. That is exactly the issue. I cannot save the file in UTF-8, because it comes from an external program (EAC). I have a lot of these files and need to read them, so manually opening & saving each file is way too much work for my customer. Furthermore, I want to save him the complexity :!:
In the mean time, found a command-line conversion tool on the web (http://www.autohotkey.com/board/topic/9 ... icode-cmd/. which allows to do this. I use "execute file" command to convert each file first. It's not really beautiful, but it kinda works... :geek:
Clip2Mania wrote:Anyone can suggest how to read unicode file attached?
Suggestions?
Thx,
Erik
Hi Erik,
the problem is that you file is in Unicode UTF16LE (Unicode of Windows) and HMG work with UTF8,
see this code:
FUNCTION Main()
cText := HMG_UTF16LE_TO_UTF8 ("test_unicodeUTF16LE.txt")
MsgInfo (cText)
#pragma BEGINDUMP
#define UNICODE
#include "HMG_UNICODE.h"
#include <windows.h>
#include "hbapi.h"
HB_FUNC ( HMG_UTF16LE_TO_UTF8 )
   TCHAR *FileName = (TCHAR *) HMG_parc (1);
   HANDLE    hFile;
   DWORD     nFileSize;
   DWORD     nReadByte;
   hFile = CreateFile (FileName, GENERIC_READ, 0, NULL, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL);
   if (hFile == INVALID_HANDLE_VALUE)
       return;
   nFileSize = GetFileSize (hFile, NULL);
   if (nFileSize == INVALID_FILE_SIZE)
   {   CloseHandle (hFile);
       return;
   TCHAR cBuffer [ nFileSize ];
   ReadFile (hFile, cBuffer, nFileSize, &nReadByte, NULL);
   HMG_retc (cBuffer);
#pragma ENDDUMP
Simply another approach :
  Convert big-endian Unicode string to ANSI
  CAUTION : Use only for big-endian Unicode string  !
PROCEDURE Main
   MsgBox( UniBE2UT8( HB_MEMOREAD( "test_unicode.txt" ) ) )
FUNCTION UniBE2UT8( cBigEndianStr )          // Convert big-endian Unicode string to ANSI
RETURN ( SUBSTR( STRTRAN( cBigEndianStr, CHR(0), '' ), 3 ) )
Clip2Mania
Fantastic, thanks gentlemen for the effort! :)
There is a problem with both codes, however
Mr. esgici's code does not read to the end of the file but stops somewhere :(
Dr. Claudio's code reads too much :) (see the "garbage" characters at the end of the file)
Not beautiful in Msgbox, but I can filter out in my code. ;)
dr. claudio's result
mr esgici's result
mr esgici's result
Clip2Mania wrote:...
There isn't such truncate problem in my method and upper extra characters in Claudio's method at my side :(
UpperExtraCharactersInClaudio'sMethod
And physically there isn't such extra (letter or not) characters into your file :?
If you made this test on another file, please send me it.
Clip2Mania
Mr esgici,
the trouble is in the accents/special characters (it always is :( )
I tried adding 'SET CODEPAGE TO UNICODE' at the beginning of the program, but that does not change anything.
Chanson_EAC.zip
(1.12 KiB) Downloaded 791 times
Clip2Mania
It is true, I added the éèçàôù characters in the file, because they are very common. In the example above,
if you leave them out, you will see that they are not correctly translated further in the file.
You are right, my conversion method not convenient to your needs :(
