Posts: 4543 Joined: Wed Jul 30, 2008 9:17 pm
Post
by esgici » Fri Jul 18, 2014 1:13 am
Hi All
A simple HMG utility attempt to build a HMG documentation set combined with sample programs.
Please read ReadMe file before build and run project.
ComboDoc.zip
Source and Run time files for ComboDoc project (6.96 KiB) Downloaded 338 times
Sample screen shoot for ThisObject page of doc ThisOb ject.PNG (11.18 KiB) Viewed 5949 times
Viva HMG
Viva
INTERNATIONAL HMG
Posts: 2763 Joined: Fri Apr 09, 2010 4:53 pm
Post
by danielmaximiliano » Fri Jul 18, 2014 2:01 am
Hola Esgici :
gracias por el excelente trabajo, sin dudas es inmejorable el trabajo, solo puedo decirte que para abrir un archivo dentro del sistema de usuario es agregar el protocolo adecuado.
Hello Esgici:
Thanks for the excellent work, is undoubtedly excellent work, I can only tell you to open a file in the user's system is to add the appropriate protocol.
Line 363
c1PrgHRef := "<p> <a href=" + '"' + "File://" + c1PRGFName + '"> Sample ' +;
IF( LEN( aPrgFNames ) > 1, '( ' + NTOC( c1PRGFName:__ENUMINDEX() ) + " )", '' ) +;
" ( " + c1PRGFName + " ) </a> </p>"
Harbour/HMG : It's magic !
Whatsapp. :=
+54901169026142
Telegram Name :=
Posts: 4059 Joined: Wed Sep 08, 2010 1:18 pm
Post
by Pablo César » Fri Jul 18, 2014 2:23 am
WOW Esgici, thank you for your excellent work.
Certainly is a very good tool to make it very fast result to add URL and will it be usefull.
I think I will need to re-edit all topic (all htm files), because is good to revise, to check and missing new ressources. For example in this first topic (Building_HMG_applications.htm here I attached an improved version for your appreciation/evaluation) has part of source code as example on it. This I think shall do it manually because is a brief samples but any way must add others examples a bottom of topic.
But anyway I found your work very good and clever. Thanks for sharing.
Thank you Daniel for your improving.
Building_HMG_applications.rar
(5.2 KiB) Downloaded 311 times
Post
by danielmaximiliano » Fri Jul 18, 2014 2:41 am
Hola Esgici :
estoy tratando de crear codigo HTML para poder compilar el ejemplo actual desde su aplicacion ComboDoc
( Sample 2 ) ( C:\hmg.3.3.1\Samples\Controls\THISWINDOW\demo.prg)
(Build Sample 2)
Whatsapp. :=
+54901169026142
Telegram Name :=
Posts: 1207 Joined: Sat Sep 10, 2011 4:07 am
Post
by bpd2000 » Fri Jul 18, 2014 4:15 am
Thank you Mr. Esgici for the excellent work sharing
Posts: 3420 Joined: Sun Nov 25, 2012 2:44 pm
DBs Used: 1 MySQL - MariaDB 2 DBF
Post
by serge_girard » Fri Jul 18, 2014 7:25 am
Great Work Esgici !
Thx, Serge
Post
by esgici » Fri Jul 18, 2014 12:06 pm
Thanks to all interested friends and nice words
Yes, please improve it !
Everything is for HMG and community
Viva
INTERNATIONAL HMG
Post
by serge_girard » Fri Jul 18, 2014 1:00 pm
Esgici,
cHMGRoot is now hardcoded to C:\hmg...
This maybe retrieved from INI file.
Greetings, Serge
Posts: 1275 Joined: Tue Sep 03, 2013 4:22 am
Post
by Javier Tovar » Fri Jul 18, 2014 3:13 pm
Hello Esguici,
excellent work !
Posts: 5482 Joined: Tue Jul 29, 2008 6:30 pm
Post
by Rathinagiri » Fri Jul 18, 2014 3:51 pm
That is a real break through Esgici.
