RICHEDITBOX
Re: RICHEDITBOX
esgici wrote:
srvet_claudio wrote: ...
is this what you wanted ?
Frankly no :)
I did not think it would be so good :o
Perfect 8-) ( as always )
Thank you very much doc :D
PROCEDURE Main
   aLanguages := { { 'Arabic',     0x0401 },;
                   { 'English',    0x0409 },;
                   { 'French',     0x040C },;
                   { 'Polish',     0x0415 },;
                   { 'Portuguese', 0x0416 },;
                   { 'Turkish',    0x041F },;
                   { 'Persian',    0x0429 },;
                   { 'Azeri',      0x042C },;
                   { 'Spanish',    0x040A } }
   aLangNames := {}
   aLangCodes := {}
   AEVAL( aLanguages, { | a1 | AADD( aLangNames, a1[ 1 ] ), AADD( aLangCodes, a1[ 2 ] ) } )
   cCurr_KLName := GetKeyboardLayoutName()
   nCurr_KLNo := CTON( cCurr_KLName, 16 )
   nInsKLNo := ASCAN( aLangCodes, nCurr_KLNo )  // Installed KBL no
   DEFINE WINDOW Form_Main ;
      WIDTH 600 HEIGHT 480 ;
      MAIN ;
      TITLE "VIVA INTERNATIONAL HMG !"
      @ 50, 20 EDITBOX editbox_1 WIDTH 550 HEIGHT 350 VALUE ""
      @ 20, 20 COMBOBOX cmbLangs WIDTH 550 HEIGHT 350 ITEMS aLangNames ON CHANGE ChangeUILang( This.Value ) VALUE nInsKLNo
   CENTER WINDOW Form_Main
   ACTIVATE WINDOW Form_Main
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROCEDURE ChangeUILang(;
                        nSelected )
   nCurr_KLNo := aLangCodes[ nSelected ]
   ActivateKeyboardLayout( nCurr_KLNo )
RETURN // ChangeUILang()
#pragma BEGINDUMP
#include "HMG_UNICODE.h"
#include <windows.h>
#include <tchar.h>
#include "hbapi.h"
HB_FUNC ( GETKEYBOARDLAYOUTNAME )
   TCHAR cKLID [ KL_NAMELENGTH + 1 ];
   GetKeyboardLayoutName (cKLID);
   HMG_retc (cKLID);
HB_FUNC ( ACTIVATEKEYBOARDLAYOUT )
   HKL hkl     = (HKL)  HMG_parnl (1);
   UINT Flags  = (UINT) hb_parni  (2);
   HKL old_hkl = ActivateKeyboardLayout (hkl, Flags);
   HMG_retnl ((LONG_PTR) old_hkl );
HB_FUNC ( GETKEYBOARDLAYOUTLIST )
   int nCount = GetKeyboardLayoutList (0, NULL);
   if ( nCount > 0 )
   {  int i;
      hb_reta (nCount);
      HKL List [nCount];
      GetKeyboardLayoutList (nCount, List);
      for (i=0; i < nCount; i++)
           HMG_storvnl ((LONG_PTR) List [i], -1, i+1);
HB_FUNC ( LOADKEYBOARDLAYOUT )
   // http://msdn.microsoft.com/en-us/library/windows/desktop/dd318693(v=vs.85).aspx
   TCHAR *cKLID = (TCHAR*) HMG_parc (1);
   HKL hkl = LoadKeyboardLayout (cKLID, Flags);
   HMG_retnl ((LONG_PTR) hkl );
HB_FUNC ( UNLOADKEYBOARDLAYOUT )
   hb_retl ((BOOL) UnloadKeyboardLayout (hkl));
#pragma ENDDUMP
I glad you find useful, I will include these functions in the new release of HMG.
How to display the virtual keyboard ?
Re: RICHEDITBOX
srvet_claudio wrote: ...I will include these functions in the new release of HMG.
It will be very good :)
There is a short key In Start Menu\All Programs and .exe is : %windir%\system32\osk.exe
More, if you close Windows without closing Virtual Keyboard, it will open next startup automatically.
I guess it will be possible to activate it ( by run / shell commands ) within our programs :?
Thanks again for this convenience :)
Regards :D
Re: RICHEDITBOX
Regards :D
That is cool !
EXECUTE FILE GetSystemDir()+"\osk.exe"
Re: RICHEDITBOX
srvet_claudio wrote: That is cool !
Coolest is you !
Thanks to tip 8-)
Added keyboard activation button !
Added also some languges ( of friends )
and some low-level rutine was simplified ( please confirm )
UI_Lang_02.zip
UI Lang select - II
(1.95 KiB) Downloaded 297 times
UI Lang select II screen shoot
A little note for friends :
In order to use this feature, you need install UI languages ( keyboards ) via Control panel. Check installed keyboards in "Language" bar of task-bar.
Re: RICHEDITBOX
Awesome!
Re: RICHEDITBOX
Enjoy !
#define WM_CLOSE 16
#xtranslate VirtualKeyboard.FILENAME         => "OSK.EXE"
#xtranslate VirtualKeyboard.FULLFILENAME     => GetSystemDir()+"\"+VirtualKeyboard.FILENAME
#xtranslate VirtualKeyboard.HANDLE           => _HMG_VirtualKeyboardGetHandle()
#xtranslate VirtualKeyboard.OPEN [ SHOW ]    => EXECUTE FILE VirtualKeyboard.FULLFILENAME
#xtranslate VirtualKeyboard.OPEN   HIDE      => EXECUTE FILE VirtualKeyboard.FULLFILENAME HIDE
#xtranslate VirtualKeyboard.RELEASE          => SendMessage (VirtualKeyboard.HANDLE, WM_CLOSE, 0, 0)
#xtranslate VirtualKeyboard.TITLE            => GetWindowText (VirtualKeyboard.HANDLE)
#xtranslate VirtualKeyboard.TITLE := <arg>   => SetWindowText (VirtualKeyboard.HANDLE, <arg>)
#xtranslate VirtualKeyboard.SHOW             => ShowWindow (VirtualKeyboard.HANDLE)
#xtranslate VirtualKeyboard.HIDE             => HideWindow (VirtualKeyboard.HANDLE)
#xtranslate VirtualKeyboard.IsVisible        => IsWindowVisible (VirtualKeyboard.HANDLE)
#xtranslate VirtualKeyboard.IsOpen           => IsValidWindowHandle (VirtualKeyboard.HANDLE)
#xtranslate VirtualKeyboard.IsRelease        => .NOT. VirtualKeyboard.IsOpen
#xtranslate VirtualKeyboard.IsMinimize       => IsMinimized (VirtualKeyboard.HANDLE)
#xtranslate VirtualKeyboard.IsMaximize       => IsMaximized (VirtualKeyboard.HANDLE)
#xtranslate VirtualKeyboard.ROW    => GetWindowRow    ( VirtualKeyboard.HANDLE )
#xtranslate VirtualKeyboard.COL    => GetWindowCol    ( VirtualKeyboard.HANDLE )
#xtranslate VirtualKeyboard.WIDTH  => GetWindowWidth  ( VirtualKeyboard.HANDLE )
#xtranslate VirtualKeyboard.HEIGHT => GetWindowHeight ( VirtualKeyboard.HANDLE )
#xtranslate VirtualKeyboard.ROW    := <arg> => _SetWindowSizePos ( VirtualKeyboard.HANDLE, <arg>,      ,      ,       )
#xtranslate VirtualKeyboard.COL    := <arg> => _SetWindowSizePos ( VirtualKeyboard.HANDLE,      , <arg>,      ,       )
#xtranslate VirtualKeyboard.WIDTH  := <arg> => _SetWindowSizePos ( VirtualKeyboard.HANDLE,      ,      , <arg>,       )
#xtranslate VirtualKeyboard.HEIGHT := <arg> => _SetWindowSizePos ( VirtualKeyboard.HANDLE,      ,      ,      , <arg> )
FUNCTION _HMG_VirtualKeyboardGetHandle
STATIC hWnd := 0
LOCAL nProcessID, aWin
   IF IsValidWindowHandle (hWnd) == .F.
      hWnd := 0
      aWin := EnumWindows ()
      FOR i = 1 TO HMG_LEN (aWin)
         GetWindowThreadProcessId (aWin[i], NIL, @nProcessID)
         IF HMG_UPPER (VirtualKeyboard.FILENAME) $ HMG_UPPER (GetProcessImageFileName(nProcessID))
            hWnd := aWin[i]
            EXIT
RETURN hWnd
   aLangNames := {}
   aLangCodes := {}
   DEFINE WINDOW Form_1;
      WIDTH 600 HEIGHT 600 ;
      MAIN ;
      TITLE "System Virtual Keyboard";
      ON RELEASE IF (VirtualKeyboard.IsOpen == .T., VirtualKeyboard.RELEASE, NIL)
      @ 410, 280 BUTTON Button_1 CAPTION "On/Off"  ACTION OnOff_VirtualKeyboard()
      @ 450, 280 BUTTON Button_2 CAPTION "Release" ACTION IF (VirtualKeyboard.IsOpen == .T., VirtualKeyboard.RELEASE, NIL)
   CENTER WINDOW Form_1
PROCEDURE OnOff_VirtualKeyboard
   IF VirtualKeyboard.IsOpen == .F.
      IF .NOT. FILE (VirtualKeyboard.FULLFILENAME)
      Inkey (1)   // Wait until the application is loaded
      VirtualKeyboard.TITLE := "HMG Virtual Keyboard"
      VirtualKeyboard.ROW := Form_1.ROW + Form_1.editbox_1.ROW + 50
      VirtualKeyboard.COL := Form_1.COL + Form_1.editbox_1.COL + 20
   IF VirtualKeyboard.IsVisible == .F.
PROCEDURE ChangeUILang( nSelected )
#pragma BEGINDUMP
#include <tchar.h>
#include "hbapi.h"
#include "hbapiitm.h"
   HMG_retc (cKLID);
//        GetProcessImageFileName ( [ nProcessID ] ) --> return cProcessImageFileName
HB_FUNC ( GETPROCESSIMAGEFILENAME )
   typedef DWORD (WINAPI *Func_GetProcessImageFileName) (HANDLE,LPTSTR,DWORD);
   static Func_GetProcessImageFileName pGetProcessImageFileName = NULL;
   if (pGetProcessImageFileName == NULL)
   {   HMODULE hLib = LoadLibrary (_TEXT("Psapi.dll"));
       #ifdef UNICODE
          pGetProcessImageFileName = (Func_GetProcessImageFileName) GetProcAddress(hLib, "GetProcessImageFileNameW");
       #else
          pGetProcessImageFileName = (Func_GetProcessImageFileName) GetProcAddress(hLib, "GetProcessImageFileNameA");
       #endif
       return;   // return NIL
   DWORD ProcessID = HB_ISNUM (1) ? (DWORD) hb_parnl(1) : GetCurrentProcessId();
   TCHAR cProcessFullName [ MAX_PATH ] = _TEXT ("");
   HANDLE hProcess = OpenProcess ( PROCESS_QUERY_INFORMATION, FALSE, ProcessID );
   if ( hProcess != NULL )
   {   pGetProcessImageFileName (hProcess, cProcessFullName, sizeof(cProcessFullName)/sizeof(TCHAR));
       CloseHandle (hProcess);
       HMG_retc (cProcessFullName);
extern PHB_ITEM pArray;
BOOL CALLBACK EnumWindowsProc (HWND hWnd, LPARAM lParam)
   UNREFERENCED_PARAMETER (lParam);
   hb_arrayAddForward (pArray, hb_itemPutNLL (NULL, (LONG_PTR) hWnd));
   return TRUE;
HB_FUNC ( ENUMWINDOWS )
   pArray = hb_itemArrayNew ( 0 );
   EnumWindows ((WNDENUMPROC) EnumWindowsProc, (LPARAM) 0);
   hb_itemReturnRelease ( pArray );
   pArray = NULL;
//        GetWindowThreadProcessId (hWnd, @nThread, @nProcessID)
HB_FUNC ( GETWINDOWTHREADPROCESSID )
   HWND hWnd = (HWND) HMG_parnl (1);
   DWORD nThread, nProcessID;
   nThread = GetWindowThreadProcessId (hWnd, &nProcessID);
   if ( HB_ISBYREF(2) )
        hb_storni (nThread, 2);
   if ( HB_ISBYREF(3) )
        hb_storni (nProcessID, 3);
#pragma ENDDUMP
Re: RICHEDITBOX
srvet_claudio wrote:Enjoy !
Wonderful :!:
Now, the Virtual Keyboard is completly under control :arrow:
Thank a lot doc :)
RICHEDITBOX
Very nice Claudio. Thanks for your sharing.
Re: RICHEDITBOX
Buenisimo Claudio.
Esgici , thanks for sharing.....
Re: RICHEDITBOX
Is there any other software require / any changes require in system, because even after I change language selection but OSK shows only English language
My OS is Windows XP Sp3
