IDE 2.8.6.f blocks ENTER key while compilation time
Can somebody do the test:
Press F5 to compile and run project, ant try use ENTER key in another application: eg editor
Re: IDE 2.8.6.f blocks ENTER key while compilation time
mol wrote:Can somebody do the test:
I can`t reproduce the problem.
What IDE and WIndows version are you using? (I've tested with current IDE and Vista SP1).
Roberto.
and..
Please, in the future, post possible bugs about IDE, in bug reports area. This way will be easier for me.
EDIT: I give priority to messages in bug report area (I have not always enough free time to read all other messages).
TIA.
Roberto.
I don't if this is a bug - I will test it today on my second computer (also win xp prof).
I'm using Windows XP Prof. SP3, IDE 2.8.6.f; hmg 2.9.1
But I'm sure, that is caused by IDE - during compilation of big project, ENTER key has no effect in other applications.
mol wrote:I don't if this is a bug - I will test it today on my second computer (also win xp prof).
Ok.
I have not XP-SP3 installed right now, but I'll install it in the next days, then I'll try to reproduce it.
Thanks for reporting.
Roberto.
I've tried it on my second computer - it looks the same - ENTER does not work ...
