HMG 3.3.0 (Stable) Patch 1
Re: HMG 3.3.0 (Stable) Patch 1
Hi all,
please test the latest changes, when all is ok I will upload a single patch with all sub-patches.
Actual with new RESOURCES:
(Exit image too black)
Would it be better to improve Exit button as before patches:
Please Claudio, explain what have you done on images. :?
Pablo César wrote:Actual with new RESOURCES:
The problem is the background color of the images, always the background color is the first pixel.
RESOURCES2.rar
(86 KiB) Downloaded 901 times
Thank you for your explaination Claudio, now Exit button is perfect !
srvet_claudio wrote:Hi all,
Hi Claudio, is it possible to include in your next patch following items:
Pablo César wrote:Hi Rathi/Claudio,
In this patch was not included following changings required:
- LOG demands at HPDF_INIT
- Proper close tables in HTML
Please note there are URLs to get help of each items.
Regarding fixed main Build.bat file to accept spaces and also in IDE when generate/write in .hbp files for put on quoting each prg module, is it hard to do it, Claudio ?
Pablo César wrote:Also To build prg and folders with spaces was perhaps pushed aside momentarily, but the lack of it hinders.
For example, if we want to create a new DEMO inside of C:\hmg.3.3.0\SAMPLES folder, the IDE displays the following error:
But if manually created and compiled with altered Build.bat, then is compiled and works well.
Re: HMG 3.3.0 - Patch of ToolBarButtons
srvet_claudio wrote:Sorry friends,
please copy the attachment (c_toolbar.c) in c:\HMG.3.3.0\SOURCE
and run BuildAllLib.bat and _BuildAllLib64.bat
ToolBar resuelto... gracias por la pronta resolucion Claudio...
Done, except the IDE.
Muchas gracias Claudio ! No se que haríamos sin ti !
Un fuerte abrazo, amigo !
emzampi
Post by emzampi »
thanks coach Claudio to solve the problem 'print preview'
Claudio, there is a small fix to h_controlmisc.prg with regard to numeric textbox.
When the value is assigned decimals are truncated.
Here is the fix. Change the following line No. 514 with the following:
Line with problem:
        SetWindowText ( c , ALLTRIM(STR(Int(value))) )
Fix:
        SetWindowText ( c , ALLTRIM(STR(value)) )
