HMG 3.3.0 (Stable) Patch 1
HMG 3.3.0 - Patch of ToolBarButtons
Greetings to all friends
I installed the HMG-32bits.3.3.0_Patch and I run (BuildAllLib.bat) this is done the print preview now I get distorted / incomplete as attached
Re: HMG 3.3.0 in 64 Bits (Test Version)
Hi,emzampi wrote:I installed the HMG-32bits.3.3.0_Patch and I run (BuildAllLib.bat) this is done the print preview now I get distorted / incomplete as attached
I'm confirm this strange toolbar's behavior in the print preview after applying the above patch also.
It seems that the source of problem is changes of the function INITTOOLBUTTON in the source c_toolbar.c
- dragancesu
Re: HMG 3.3.0 (Stable) Patch 1
I left an example and how look in program, pictures are BMP
For me the problem with the keyword SEPARATOR works well when there is no
DEFINE TOOLBAR ToolBar_2_1 BUTTONSIZE 60,40 IMAGESIZE 32,32 FLAT BORDER
BUTTON FIRST_2604 ;
CAPTION "First" ;
PICTURE "go_first" ;
ACTION( dbGotop(), Win_2_1.Browse_2_1.Value := RecNo() )
BUTTON PREV_2604 ;
CAPTION "Prev" ;
PICTURE "go_prev" ;
ACTION( dbSkip( -1 ), Win_2_1.Browse_2_1.Value := RecNo() )
BUTTON NEXT_2604 ;
CAPTION "Next" ;
PICTURE "go_next" ;
ACTION( dbSkip(), if ( Eof(), dbGobottom(), Nil ), Win_2_1.Browse_2_1.Value := RecNo() )
BUTTON LAST_2604 ;
CAPTION "Last" ;
PICTURE "go_last" ;
ACTION( dbGoBottom(), Win_2_1.Browse_2_1.Value := RecNo() ) /* SEPARATOR */
BUTTON FIND_2604 ;
CAPTION "Find" ;
PICTURE "edit_find" ;
ACTION Find_2604()
BUTTON NEW_2604 ;
CAPTION "New" ;
PICTURE "edit_new" ;
ACTION ( New := .T., NewRecord_2604() )
BUTTON EDIT_2604 ;
CAPTION "Edit" ;
PICTURE "edit_edit" ;
ACTION If ( RecordStatus_2604(), EnableField_2604(), Nil )
BUTTON DELETE_2604 ;
CAPTION "Delete" ;
PICTURE "edit_delete" ;
ACTION ( RecordStatus_2604(), DeleteRecord_2604(), Nil )
BUTTON PRINT_2604 ;
CAPTION "Print" ;
PICTURE "edit_print" ;
ACTION PrintData_2604()
BUTTON EXIT_2604 ;
CAPTION "Exit" ;
PICTURE "edit_close" ;
ACTION Win_2_1.Release
END TOOLBAR
- hmg33good.jpg (27.25 KiB) Viewed 24705 times
- hmg33.jpg (26.23 KiB) Viewed 24705 times
Sadly, I also confirm AFTER this first patch (HMG-32bits.3.3.0_Patch.zip) ToolBar's buttons are with bug.
BEFORE this patch, was OK.
So we shall wait for Dr. Soto returns and prepare a new patch to correct this bug.
My advise is not to be applied this first patch and wait for new instructions.
Claudio, solo para informacion: la exibicion de los bmp del preview, no están con buena resolucion. Creo que el color negro lo está removiendo.
- srvet_claudio
Sorry friends,
please copy the attachment (c_toolbar.c) in c:\HMG.3.3.0\SOURCE
and run BuildAllLib.bat and _BuildAllLib64.bat
- c_toolbar.rar
- (3.98 KiB) Downloaded 1128 times
- dragancesu
Thank you,
problem with images in the toolbar is resolved
Thank you Dr. Claudio Soto, Toolbar error clear
Hola Claudio, despues de este nuevo c_toolbar.c los botones volvieron pero todavia están con una exibicion diferente.
La imagen del los botones deberia ser como esta:
Que lo que falta hacer ? Es el transparent ?Pablo César wrote:Claudio, solo para informacion: la exibicion de los bmp del preview, no están con buena resolucion. Creo que el color negro lo está removiendo.
- srvet_claudio
You're right,Pablo César wrote:Dear Claudio,
I just tested PNG file at DEFINE CHECKBUTTON (not by "@"):
DEFINE CHECKBUTTON CheckBtn_1
ROW 150
COL 60
WIDTH 78
HEIGHT 78
CAPTION ""
VALUE .T.
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
PICTURE "Printer.png"
END CHECKBUTTON
and is displaying error message: Error BASE/1077 Argument error: .NOT.
So, I checked source code and by knowing there is new TRANSPARENT property is required. So then I added:
ROW 150
COL 60
WIDTH 78
HEIGHT 78
CAPTION ""
VALUE .T.
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
END CHECKBUTTON
IMHO DEFAULT declaration must be needed for transparent argument. I do not know it others controls is also needed.
please copy the attached file to c:\hmg.3.3.0\INCLUDE
PS: Haste is the enemy of perfection !
- i_altsyntax.rar
- (8.69 KiB) Downloaded 1067 times
- srvet_claudio
Hi all,Pablo César wrote:Hola Claudio, despues de este nuevo c_toolbar.c los botones volvieron pero todavia están con una exibicion diferente.
Unzip the attachment folder in c:\HMG.3.3.0\RESOURCES
- RESOURCES.rar
- (85.48 KiB) Downloaded 1104 times
